JacobZu7zu7 #1 Posted February 14, 2007 Hey, this is a general question about games 'still sealed', if they should be cleaned with the q-tip method? Are they good to go, or is it best to clean away the years? Same question it a used Atari, should the circut board inside be cleaned? ok, thanks. Quote Share this post Link to post Share on other sites
shadow460 #2 Posted February 14, 2007 Test 'em first, and if they don't work, clean 'em. Cleaning can't hurt anyway, though. Quote Share this post Link to post Share on other sites
jaybird3rd #3 Posted February 14, 2007 As a general rule, I tend to clean the card-edge fingers on every cartridge I get, new or not, and I'm always amazed at the amount of residue that I'm able to clear away even on new-in-the-box cartridges. Dirt and other material doesn't just come from use; the chemicals and other materials used in manufacturing the printed circuit boards seem to slowly leech out onto the surface over the years, and as shadow460 says, cleaning doesn't hurt anyway. I use one side of a cotton swab dipped in alcohol to wipe both sides of the board, drying them immediately afterward with the other side of the swab to clear away any residue. Quote Share this post Link to post Share on other sites
joeybastard #4 Posted February 14, 2007 As a general rule, I tend to clean the card-edge fingers on every cartridge I get, new or not, ... I do that too, I thought it was just a little OCD I had Quote Share this post Link to post Share on other sites
shadow460 #5 Posted February 15, 2007 I actually clean most cart inside and out. If I'm buying a cart with an exposed screw, a lot of times I'll take it apart and clean the inside too. That's OCD for ya. Quote Share this post Link to post Share on other sites
+RandomPerson #6 Posted February 15, 2007 I have had games NIB be opened to find the contacts did have 20 years worth of corosion on them. Mind you it's like 1 in every 30 or 40 I open that have this issue but it does happen. Like Shadow said test it first. Don't fix it if it ain't broke. Quote Share this post Link to post Share on other sites
JacobZu7zu7 #7 Posted February 16, 2007 Cool, I think I'll test them, and clean 'em. Should be easy, with 'Still Sealed' games that is. Quote Share this post Link to post Share on other sites
Rik #8 Posted February 16, 2007 (edited) Hey, this is a general question about games 'still sealed', if they should be cleaned with the q-tip method? Are they good to go, or is it best to clean away the years? Same question it a used Atari, should the circut board inside be cleaned? ok, thanks. Use the "SPONGE TIPPED CLEANERS" instead of the Q-TIPS cus they wont leave cotton residue on the cleaning surface,get then at any pharmacy,also use "ELECTRONIC CONTACT AND HEAD CLEANER",that stuff is expensive,but has no water in it like rubbing any% isopropyl alcohol does,if you dont want to spend the money ,just use the q-tip iso alc method,im VERY fussy with my stuff,so i use only the best stuff.As far as sealed games go,the contact points still corode and oxidize while in the package,especially with the shrink wrap intact,if you ever open up a sealed game and it doesnt work,just clean the contacts and %99 of time, game will then work,its happened to me a couple of times. Edited February 21, 2007 by Rik Quote Share this post Link to post Share on other sites
Classic Pac #9 Posted February 16, 2007 No alcohal...it has been my eperiance you just have to reclean them later. I use WD-40 and I find I only have to do it once, WD-40 not only cleans but it protects the contacts. Quote Share this post Link to post Share on other sites
Atari Punk 78 #10 Posted February 17, 2007 (edited) Won't WD-40 get the game kind of oily and damage the inside of an Atari? I'm not willing to risk a 30 year old system. Edited February 17, 2007 by Atari Punk 78 Quote Share this post Link to post Share on other sites
+RandomPerson #11 Posted February 17, 2007 Won't WD-40 get the game kind of oily and damage the inside of an Atari? I'm not willing to risk a 30 year old system. Yes, wd-40 has oils that do leave residue. It's more of a lube not a cleaner. Stick to 90 percent. Quote Share this post Link to post Share on other sites
Atari Punk 78 #12 Posted February 17, 2007 Yeah, I feel safer with 90 percent. It dries up quickly and leaves no residue. Quote Share this post Link to post Share on other sites
Rik #13 Posted February 21, 2007 (edited) No disrespect to the suggestion,but, wd-40 is used to loosen RUSTED METAL,do what you Like,i WOULDNT TRY IT,l'll stick to contact cleaner.But i see wd-40 as more of a lube and rust disolver,and cleaner for grease,tar,on engine parts,industrial applications,seems a little to extreme for electronics,but hey ,if it works for you ,great.Just the smell of it is enough of a deterent for me.But some will think my suggestions are EXTREME,so its all good,whatever works for you. Edited February 21, 2007 by Rik Quote Share this post Link to post Share on other sites
EricBall #14 Posted February 21, 2007 No disrespect to the suggestion,but, wd-40 is used to loosen RUSTED METAL,do what you Like,i WOULDNT TRY IT,l'll stick to contact cleaner.But i see wd-40 as more of a lube and rust disolver,and cleaner for grease,tar,on engine parts,industrial applications,seems a little to extreme for electronics,but hey ,if it works for you ,great.Just the smell of it is enough of a deterent for me.But some will think my suggestions are EXTREME,so its all good,whatever works for you. WD-40 should not be used as a lubricant. It's designed to evaporate. It's best to leave WD-40 for it's original purpose - Water Displacement. Quote Share this post Link to post Share on other sites
Rik #15 Posted February 22, 2007 (edited) No disrespect to the suggestion,but, wd-40 is used to loosen RUSTED METAL,do what you Like,i WOULDNT TRY IT,l'll stick to contact cleaner.But i see wd-40 as more of a lube and rust disolver,and cleaner for grease,tar,on engine parts,industrial applications,seems a little to extreme for electronics,but hey ,if it works for you ,great.Just the smell of it is enough of a deterent for me.But some will think my suggestions are EXTREME,so its all good,whatever works for you. WD-40 should not be used as a lubricant. It's designed to evaporate. It's best to leave WD-40 for it's original purpose - Water Displacement. I went by whats labeled on the can,it states it is to be used to lube hinges,wheels,rollers,chains and gears,which i have, and its actually done a SUPERB job.Works wonders on squeeky door hinges. Edited February 22, 2007 by Rik Quote Share this post Link to post Share on other sites
