super_dos_man #1 Posted February 16, 2007 (edited) in conkers bad fur day, I am on the angry pitchfork level and I cant kill the last haystack! y not? it jumps over all of the pitchforks and ive been trying to kill it for 2 hours. please help thanks, Tim Edited February 16, 2007 by super_dos_man Quote Share this post Link to post Share on other sites
SpendTooMuchOnAtari #2 Posted February 17, 2007 I never did finish that game and don't recall this but did come up with this, I don't know if this is what you are looking for but I'll give it a shot: Mad Pitchforks-------------- When you walk in the barn, it shows a bunch of piles of hay and a paint can and brush fighting with Franky the pitchfork. Make your way over to where they are and the pitch fork will begin to follow you around trying to poke you. Get a hay thing in between you and Franky, so that when Franky attacks you, he he kills the hay thing. Once al of them are defeated, Franky will go hang himself. Go to around where the door is and there is a switch in the corner, pull it to make the King bee fall out from the rafters. Then go out side, once you leave, it will show a huge hay thing jump down from the rafters.When you get outside, take a right to get into a cut scene with the bee... - Copyright 2002 Ryan Kavanagh If this doesn't help, try this link for more info: LINK I hope this helps but perhaps someone who played all the way through will be able to respond better and give a more personal answer. Good Luck super_dos_man Quote Share this post Link to post Share on other sites
SpendTooMuchOnAtari #3 Posted February 17, 2007 I also just saw this when I was closing out the window where I got the info: Once you cut the noose of Franky the Pitchfork, drop down to the barn floor and meet up with him. After some arguing amongst the pot and brush, the pitchfork agrees to help you get rid of that huge monster haystack. Hop onto the pitchfork's back and go after the haystack. To jump, press A, to stab, press B. The only way you can possibly stab the haystack is if you attack it from behind or in the side. When you're facing it, it'll just punch you away. After two stabs, it'll reveal it's true form: a robot similar to the terminator. Stab it once more and you'll drop down into the basement area of the barn where you must continue the fight, only now it's tougher. Circle around the room as the bot fires missiles at you, and jump when they come near so you don't get knocked off of the pitchfork. If you get smashed or crushed by the bot, you'll lose two pieces of your energy bar, and one piece for being hit by a missile. Hide behind one of the three pipes in the room to find extra chocolate pieces as well as to have a missile break it open, spewing water out. Hide behind the waterfall to lure the bot near it, which will electrocute him back into the center of the basement. Go up to him and jump when the red button on his back comes near you, then press B when the lightbulb appears to press it. This will cause damage to the bot. Repeat the following process two more times to defeat him. - Copyright 2001 Dallas Scott. Maybe this helps more? Quote Share this post Link to post Share on other sites
