Sign in to follow this
RSS Bot
Wickeycolumbus' Blog - 6502 menomics
Its Friday! No more fricken school!!!!!!
well any way, this is a list of 6502 menomics for all of the people that are learning 6502 assembly language with me out there.
Load/Store Operations:
LDA Load Accumulator
LDX Load X Register
LDY Load Y Register
STA Store Accumulator
STX Store X Register
STY Store Y Register
Register Transfers:
TAX Transfer accumulator to X
TAY Transfer accumulator to Y
TXA Transfer X to accumulator
TYA Transfer Y to accumulator
Stack Operations:
TSX Transfer stack pointer to X
TXS Transfer X to stack pointer
PHA Push accumulator on stack
PHP Push processor status on stack
PLA Pull accumulator from stack
PLP Pull processor status from stack
Logical:
AND Logical AND
EOR Exclusive OR
ORA Logical Inclusive OR
BIT Bit Test
Arithmetic:
ADC add with Carry
SBC Subtract with Carry
CMP Compare accumulator
CPX Compare X register
CPY Compare Y register
Increments and Decrements:
INC Increment a memory location
INX Increment the X register
INY Increment the Y register
DEC Decrememt a memory location
DEX Decrement the X register
DEY Decrement the Y register
Shifts:
ASL Arthmetic Shift Left
LSR Logical Shift Right
ROL Rotate Left
ROR Rotate Right
Jumps and Calls
JMP Jump to another location
JSR Jump to a subroutine
RTS Return from subroutine
Branches:
BCC Branch if carry flag clear
BCS Branch if carry flag set
BEQ Branch if zero flag set
BMI Branch if negative flag set
BNE Branch if zero flag clear
BPL Branch if negative flag clear
BVC Branch if overflow flag clear
BVS Branch if overflow flag set
Change the values of specific status flags:
CLC Clear carry flag
CLD Clear decimal mode flag
CLI Clear interrupt disable flag
CLV Clear overflow flag
SEC Set carry flag
SED Set decimal mode flag
SEI Set interrupt disable flag
System Functions:
BRK Force an interrupt
NOP No Operation
RTI Return from Interrupt
I hope that you all found this entry helpful!!!!
I noticed that some people have downloaded QUADRAT 1.0. I have newer versions that do a lot more things that i am wondering if i should post or not. Some new versions include features to: solve the falling object model, fint the discrimint, find the axis of symmatry, find the Y-intercept, and more.
If you liked QUADRAT 1.0 and would like to see better versions, please reply in a comment, or eMail me at [email protected]
http://www.atariage.com/forums/index.php?a...;showentry=3218
