Sign in to follow this
SpiceWare
SECAM palette for Stella
There's a group order for Medieval Mayhem in progress over in France. One of them mentioned their Atari was a SECAM model, so I was curious what Medieval Mayhem would look like:
PAL cartridge on SECAM Atari
NTSC cartridge on SECAM Atari
The dragon turned out blue and the castles are psychedelic , but other than that they look fine. I'd purposely made each player have a different luminance so they'd look different on the small 5" B&W TV I did a couple tests on; because of this, I got lucky and each player has a unique color. In fact, they're really close - just purple and blue swapped corners.
I also got real lucky due to some feedback in my blog . The original colors were darker, which would have rendered one player and part of the castle walls invisible when played on a SECAM system:
In order to make these tests, I needed a SECAM palette for Stella. I check the ever handy Tia Color Charts and threw together a little VB app during lunch to create the palette - here's the results:
stellaSECAM.zip
To confirm I did it right, I planned to test with River Raid; but, I couldn't find the SECAM version of the ROM. The colors of the PAL version match what alex_79 posted, so I think my palette is correct.
For those interested, here's the code:
Private Sub cmdMakePalette_Click()
 Dim iFileNum As Integer
 Dim i As Integer
 Dim c As Integer
 Dim Colors(1 To 8) As String
 ' SECAM Colors from http://www.qotile.net/minidig/docs/tia_color.html
 Colors(1) = "000000" ' black
 Colors(2) = "2121ff" ' blue
 Colors(3) = "f03c79" ' red
 Colors(4) = "ff50ff" ' purple
 Colors(5) = "7fff00" ' green
 Colors(6) = "7fffff" ' cyan
 Colors(7) = "ffff3f" ' yellow
 Colors(8) = "ffffff" ' white
 iFileNum = FreeFile
 Open "C:\Program Files\Stella\stella.pal" For Output As #iFileNum
 For i = 1 To 16 * 2 ' 16 colors, 2 palettes
For c = 1 To 8
  Print #iFileNum, Chr$(CLng("&H" & Mid(Colors(c), 1, 2)));
  Print #iFileNum, Chr$(CLng("&H" & Mid(Colors(c), 3, 2)));
  Print #iFileNum, Chr$(CLng("&H" & Mid(Colors(c), 5, 2)));
Next c
 Next i
End Sub
Edited by SpiceWare
In order to make these tests, I needed a SECAM palette for Stella. I check the every handy Tia Color Charts and threw together a little VB app during lunch to create the palette - here's the results:
stellaSECAM.zip
This is great! I was hoping Stella would eventually get a SECAM palette. :)
Michael
Any idea where I need to put the palette for the Mac? At the office I just dropped it in C:\Program Files\Stella\stella.pal. I've tried putting it in the StellaOSX2.3.5, the ROMs direction, and even opened up the "package" and tried a few folders in there.
stellaSECAM.zip
Michael
It should be easy to add this for the next release, whenever that may be.
According to the manual, the file would be placed in the same location as the properties file (stella.pro). In the case of OSX, this would mean "$HOME/.stella/stella.pal". For the next release, I hope to improve on this, and add an entry to the GUI where one can select the path of this file (and likewise for the properties file).
