6 digit scoring help needed
Cafeman
; ****************** A D D P O I N T S *********
;NOTE : score is high byte first
;treat score like a variable
;routine can also add values >255
;put point value in POINTHI/POINTLO
AddPointsRoutine
SED
CLC
LDA ScoreLo ;(SCOREHI+1)
ADC PointsLo
STA ScoreLo
LDA ScoreHi
ADC PointsHi
STA ScoreHi
lda #$00
adc ScoreHi2;doesn't work -- fix! it rolls at 9,999! 4/24
CLD
rts
There's my code. But the adc SchoreHi2 doesn't work, as though the carry isn't still set. You see I'm adding to PointsLo, then adding with carry to PointsHi. That works. But then I try to add 0 to ScoreHi2 (digits 5 and 6 in the score), hoping that the AddWithCarry will in fact add 1 to it when the prior add crosses FF to 00. It doesn't work!
Any ideas?
Not used BCD much, but, apart from the obvious that you are not storing Scorehi2 in this example, it should work. Where is Scorehi2 in memory - Maybe it's getting overwritten by something else? Just try moving it somewhere else, see what happens.
Duuh! My bad...you are not actually saving ScoreHi2 before the CLD is called. Try this...
SED
CLC
ADC PointsLo ;Add lower 2 digits of points
STA ScoreLo
LDA ScoreHi
ADC PointsHi ;Add upper 2 digits of points + carry from previous
STA ScoreHi
LDA ScoreHi2
ADC #$00 ;this will contain only the carry from the above, if any
STA ScoreHi2
CLD
RTS
BTW where is ScoreHi2 located? ScoreHi-1? A short routine can be made to contain the addition and display of the score in one go by using the X register as an offset.
LOL.
BTW another solution is to forgo variables for the score altogether and add digits directly to the numbers in screen memory. You can use AND to test the bits for a carry and to strip invalid values away. In this manner you would not use decimal mode.
Yup! If you need an example, look into my disassembly of River Raid at The Dig!
Since #points is limited to 4 digits, you could also replace the last 5 lines of that routine with this slightly shorter version:
Previous:
LDA ScoreHi2
STA ScoreHi2
CLD
RTS
Alternate:
BCC 03 ;(02 if ScoreHi2 is in zero page)
INC $ScoreHi2
CLD
RTS
This alternate method will also fit into the same amount of space originally used.
OH MYYYY...
I cannot believe that I stared at that for so long and didn't realize the obvious -- I wasn't storing the accumulator back into HiScore2. DUHHHHHHHHHHHHHHHHHHHHHH....
I may just delete this thread to cover my tracks.
 :ponder:
Yes, for shame, how could you miss such a thing! I know the accumulator is the same thing as the A register at least :) 0100 is a nibble :)
have a grand $E7 .BYTE day!
