godzillajoe #1 Posted June 14, 2007 So I tried using my Wico stick with Strat-O-Gems recently and the fire button is really bad, you press it and the gems rotate positions twice sometimes. Can this be "fixed" I got it from Best. Do they fix stuff like this or should I just crack it open and do it myself? Quote Share this post Link to post Share on other sites
Prodos8 #2 Posted June 15, 2007 They're always a bit mushy on these sticks as they use a leaf type switch. Just open her up and and clean the contacts (made of copper which can tarnish) on the switch with alcohol. You can also gently bend the switch apart a bit to get better spring response if its sticking like you said. Quote Share this post Link to post Share on other sites
