BSA Starfire #1 Posted July 3, 2007 Hi all, I have the oportunity to obtain a Romscanner for the VCS , now as far as I can tell it's a unit that plugs into the top of the machine and takes ten game carts that you may then selct between, kinda handy I thought. However the seller says it is missing a wire that goes between the unit and atari, in the pic is the unit, box, some of what look like mounting supports. The bit that plugs into the cart port on the atari also seems to be there. So my question is anyone have any idea what this missing cable is? Hope you can help! Quote Share this post Link to post Share on other sites
YOK-dfa #2 Posted July 3, 2007 Hi all, I have the oportunity to obtain a Romscanner for the VCS , now as far as I can tell it's a unit that plugs into the top of the machine and takes ten game carts that you may then selct between, kinda handy I thought. However the seller says it is missing a wire that goes between the unit and atari, in the pic is the unit, box, some of what look like mounting supports. The bit that plugs into the cart port on the atari also seems to be there. So my question is anyone have any idea what this missing cable is? Hope you can help! IIRC that should be the powerwire. Basically you plug your normal Atari PSU in the romscanner and from there another wire goes to the Atari to supply it with the much needed charged electrons... Quote Share this post Link to post Share on other sites
