Gunstar #1 Posted July 6, 2007 When I load Jungle Jag, the screen sits too low and a lot is cut off at the bottom. when I use the screen adjust on the menu screen to compensate, after starting the game Jungle jag and all the enemies "walk" on air about an inch off the "platforms." If I don't adjust the screen, they walk on the platforms, but of course a couple of inches are cut off the bottom of the screen and I can't see everything to play. Is this normal for everyone? Is there a way to correct this? Quote Share this post Link to post Share on other sites
walter_J64bit #2 Posted July 6, 2007 When I load Jungle Jag, the screen sits too low and a lot is cut off at the bottom. when I use the screen adjust on the menu screen to compensate, after starting the game Jungle jag and all the enemies "walk" on air about an inch off the "platforms." If I don't adjust the screen, they walk on the platforms, but of course a couple of inches are cut off the bottom of the screen and I can't see everything to play. Is this normal for everyone? Is there a way to correct this? I din't think they tested the NTSC setting, I get the same thing. Quote Share this post Link to post Share on other sites
Gunstar #3 Posted July 7, 2007 When I load Jungle Jag, the screen sits too low and a lot is cut off at the bottom. when I use the screen adjust on the menu screen to compensate, after starting the game Jungle jag and all the enemies "walk" on air about an inch off the "platforms." If I don't adjust the screen, they walk on the platforms, but of course a couple of inches are cut off the bottom of the screen and I can't see everything to play. Is this normal for everyone? Is there a way to correct this? I din't think they tested the NTSC setting, I get the same thing. Ahh, o.k. Well, I guess I'll have to mod my Jag with a switch to change between 50/60Hz, since I have it hooked up to my SC1224 RGB monitor, I can run it in PAL or NTSC modes. Quote Share this post Link to post Share on other sites
Atari Dogs #4 Posted July 7, 2007 I get the same thing. It seems the game is only about three screens wide. Is that right? Quote Share this post Link to post Share on other sites
EmOneGarand #5 Posted July 7, 2007 It has a screen adjust option,you hold down a button and then you can move the screen. Somewhere on the title screen it's listed. Quote Share this post Link to post Share on other sites
Gunstar #6 Posted July 7, 2007 It has a screen adjust option,you hold down a button and then you can move the screen. Somewhere on the title screen it's listed. That's were the problem starts. Please read my original post more carefully. Quote Share this post Link to post Share on other sites
Orion_ #7 Posted July 7, 2007 from the readme: -works on PAL 50Hz Jaguar, there is no warranty that it will works on NTSC 60Hz Jaguar. (sorry, I only have a PAL Jaguar and a 50Hz TV) and if anybody wants to correct this bug, please do so, I remind you that the complete source code is available. Quote Share this post Link to post Share on other sites
