Sign in to follow this
godzillajoe
Why change from 6 switch to 4 switch?
What was the reasoning behind Atari going from the 6 switch to the 4 switch VCS with the difficulties on the back?
Technical reasons? Cheaper to produce?
Other?
Edited by godzillajoe
My guess is cheaper to produce moving the bigger toggle difficulty switches to the rear with a couple little plastic ones had to be cheaper also probably same reason they stopped the more robust Heavy Sixer to go with a lighter less materials Light sixer.
Not fact but just an opinion
If you open up the original six-switch you'll see that it actually has two boards, one flat in the case and one for the console switches running diagonally. The 4-switch has a single PCB mounted diagonally serving both roles with the difficulties in the rear. Eliminating the outermost switches allowed them to make this single board narrower.
