Lauren Tyler #1 Posted September 1, 2007 I just found out that EA Games is releasing C&C Gold for free at http://www.commandandconquer.com/intel/def...?id=61#NewsMain The thing is, both the GDI and NOD discs are being released in two seperate .iso files. It says after burning the ISOs (or mounting them I'd think) you have to set the install programs to be Windows 95 compatible to run them. When I tried doing that it says 'SETUP.EXE is not a valid Win32 Application.' Is this a problem with the .iso or something I'm not doing right? I'm doing it according to the document and all. Quote Share this post Link to post Share on other sites
SINGLE TOOTH #2 Posted September 2, 2007 (edited) I just found out that EA Games is releasing C&C Gold for free at http://www.commandandconquer.com/intel/def...?id=61#NewsMain The thing is, both the GDI and NOD discs are being released in two seperate .iso files. It says after burning the ISOs (or mounting them I'd think) you have to set the install programs to be Windows 95 compatible to run them. When I tried doing that it says 'SETUP.EXE is not a valid Win32 Application.' Is this a problem with the .iso or something I'm not doing right? I'm doing it according to the document and all. SO what did you do, burn or mount the iso? Try the other disc, and try not being in win 95 mode. Or try windows 98 mode. What windows you have, XP? I wouldn't think you would have to run the installer in windows 95 compatibility mode. Edited September 2, 2007 by SINGLE TOOTH Quote Share this post Link to post Share on other sites
Lauren Tyler #3 Posted September 2, 2007 I just found out that EA Games is releasing C&C Gold for free at http://www.commandandconquer.com/intel/def...?id=61#NewsMain The thing is, both the GDI and NOD discs are being released in two seperate .iso files. It says after burning the ISOs (or mounting them I'd think) you have to set the install programs to be Windows 95 compatible to run them. When I tried doing that it says 'SETUP.EXE is not a valid Win32 Application.' Is this a problem with the .iso or something I'm not doing right? I'm doing it according to the document and all. SO what did you do, burn or mount the iso? Try the other disc, and try not being in win 95 mode. Or try windows 98 mode. What windows you have, XP? I wouldn't think you would have to run the installer in windows 95 compatibility mode. I've tried running it in every compatibility mode for both disc, no luck. And yes I have Windows XP. Quote Share this post Link to post Share on other sites
shadow460 #4 Posted September 3, 2007 I think you can install C&C Gold (otherwise known as Command & Conquer '95) via DOS. I'm not sure how well that works on XP. I've always installed it via the GUI in 98 and 98SE. Quote Share this post Link to post Share on other sites
Lauren Tyler #5 Posted September 3, 2007 No soap, it just said that it wasn't a valid Win32 Application either. Quote Share this post Link to post Share on other sites
SINGLE TOOTH #6 Posted September 3, 2007 im dl'ing it now, but its going very slowly. Ill see if I can't install it Quote Share this post Link to post Share on other sites
shadow460 #7 Posted September 3, 2007 That's odd. I might have to load up the old CD set I've got at some point and see what happens. Generally when it comes to the first C&C, I just play it on a console. It's slower, but you still have everything there, especially with the PS1 version and the Sony mouse. Quote Share this post Link to post Share on other sites
NE146 #8 Posted September 20, 2007 (edited) This site still up? Figured I wanted to download it today only to find the site seems to be gone.. <edit> woops.. it came back up now. Guess they were rebooting Edited September 20, 2007 by NE146 Quote Share this post Link to post Share on other sites
dendawg #9 Posted September 21, 2007 Have you tried reading this file? Quote Share this post Link to post Share on other sites
