Sign in to follow this
Crazy Climber
Anyone know if Gauntlet 2 Cabinets can play Gauntlet 1 boards?
Just wondering...Klov says that if you play a Gauntlet 2 board in a Gauntlet 1 cabinet it will not work past level 6 due to some sort of protection built in. I was just wondering if the same is true vice versa? It would be cool to own a Gauntlet 2 cabinet but be able to play both boards in it. If anyone knows this it would be totally cool :cool: Thanks everyone :)
I think that they meant Gauntlet 2 ROMs on a Gauntlet board won't work due to copy protection (the slapstic). However, if you use the cracked ROMs you can do it. You can even put both Gauntlet 1 and 2 on the same board and choose between the two with the flip of a switch (I've personally done this myself and it works fine).
A Gauntlet 2 board in a Gauntlet cabinet will definitely work with no problem.
Edited by djpubba
