Evad97 #1 Posted October 3, 2007 Has anybody ever had any luck with this? (I know that taking them apart was being discussed a while back but I can't seem to find the thread ...) Basically, the foot pedal works fine but I can't make the car steer. I've tried new batteries and I've actually used the colecovision "power pack" (or whatever it's called) to provide power. I've opened the case up and ... well, after that, I'm at a loss. The disk with all the holes is turning when I turn the steering wheel but it's not being read by whatever is supposed to read it. Is it possible that something has broken off? If anybody has advice, or can point me to a thread where this is being discussed, I'd really appreciate it. E. Quote Share this post Link to post Share on other sites
accousticguitar #2 Posted October 4, 2007 That's the exact same problem I have. I hope someone here can help you out. Quote Share this post Link to post Share on other sites
Uzumaki #3 Posted October 4, 2007 I don't have the steering module at hand but if it uses IR emitter and detector pair, it may be clogged with dust. Try cleaning those sensors. Quote Share this post Link to post Share on other sites
Prodos8 #4 Posted October 4, 2007 First, I'd clean the connector on the CV expansion port and the steering wheel. I recommend an old toothbrush with alcohol and scrub the contacts good. Second, the steering wheel controller is basically an overgrown (from what I've read as I've never owned one) 2600 driving controller so the rotary encoder may need a good cleaning as well. It may be possible to spray some sort of contact cleaner from the outside into it to clean it or you may need to take it apart. Anyway, Longhorn Engineer has a good write-up on cleaning a driving controller so it may be useful for this as well. http://www.longhornengineer.com/Howto/Driving Quote Share this post Link to post Share on other sites
Evad97 #5 Posted October 4, 2007 Many thanks for the suggestions and the site ... I'll give these options a try. E. Quote Share this post Link to post Share on other sites
Evad97 #6 Posted October 6, 2007 Thanks for all the suggestions ... unfortunately, I couldn't make it work and finally decided to return it to the shop where I picked it up. As something of an aside, I did discover that the fire button on the atari driving controller works as the gas pedal on the coleco controller. My suspicion is that it might be a relatively simple hack job to make the Atari Controller work with the Colecovision. I'm not prepared to sacrifice mine for the experiment, though ... at least not at this stage, anyway. Thanks again E. Quote Share this post Link to post Share on other sites
Evad97 #7 Posted October 6, 2007 (edited) Whoops ... Double Post. Edited October 6, 2007 by Evad97 Quote Share this post Link to post Share on other sites
AussieAtari #8 Posted October 9, 2007 Does any one know if you can source battery covers for the Driving Controller? Quote Share this post Link to post Share on other sites
