MFoolsRun #1 Posted October 16, 2007 Hi, Is it possible/likely that I'd be able to find a replacement rubber/foam (whatever it's made of) Virtual Boy eye-shroud thingie? I really don't know the word for it. It's the part that blocks out the surrounding light when you're looking into the VB. I'm looking at one that doesn't have this piece and I'm wondering what the likelihood of acquiring one after the fact might be. Thanks! Quote Share this post Link to post Share on other sites
+SpiceWare #2 Posted October 16, 2007 I suspect somebody at Planet Virtual Boy would know. Quote Share this post Link to post Share on other sites
godslabrat #3 Posted October 17, 2007 I think Nintendo still sells spares. I really should order a few for myself, now that you mention it... Quote Share this post Link to post Share on other sites
MFoolsRun #4 Posted October 17, 2007 Oof. While I was waiting and researching this, the auction ended (I could have sworn I had more time!). Oh'well, better to know for next time than to be stuck with half a system. Thanks for the replies! Quote Share this post Link to post Share on other sites
Ze_ro #5 Posted October 17, 2007 Do you want to replace an existing one, or did you buy a VB without one to begin with? If the latter is the case, then you should know that there's also piece that the foam shielding connects to, and which subsequently snaps onto the Virtual Boy. Without that piece, the foam shielding is useless. For what it's worth, the foam shielding has a part number VUE-010, and the snap-on eye-piece has a part number VUE-012. --Zero Quote Share this post Link to post Share on other sites
MFoolsRun #6 Posted October 17, 2007 Do you want to replace an existing one, or did you buy a VB without one to begin with? If the latter is the case, then you should know that there's also piece that the foam shielding connects to, and which subsequently snaps onto the Virtual Boy. Without that piece, the foam shielding is useless. For what it's worth, the foam shielding has a part number VUE-010, and the snap-on eye-piece has a part number VUE-012. --Zero Thanks for the part numbers. Basically I was wondering if it's possible to get the eyeshield (and snap-on thingie) separately, which opens up the range of Virtual Boys I can look at Quote Share this post Link to post Share on other sites
Richard H. #7 Posted October 20, 2007 There's a brand new one here (item number 330176170409) Quote Share this post Link to post Share on other sites
