Goochman #1 Posted November 9, 2007 Ok, My SIO2USB unit arrived yesterday and I loaded a few ATRs on it for testing. I committed to this thing awhile back and during the wait things changed like the Euro which prob wouldve kept me from buying this, but having said that the Unit looks great and the box has a very 80's feeling to it I put a few atrs like DROL and Ultima II on the unit with and without a directory. I plugged the unit into my upgraded 130XE (320K ram, 32n1 OS, MyIDE internal - classics has made a fortune here ) and the screen lit up blue! The navigation is a bit clunky and the display doesnt have alot of chars so you will want to make sure your atr names are not long I was able to navigate the root and directories so you will ba able to manage your files according to your own style I was able to switch OS from 130XE Rev C to 800 OS B and the unit had not trouble - Drol and Ultima II ran fine - disk swapping for U2 and saving worked like a champ! This is a really neat unit - only real drawback is navigating if you have alot of atr's you want loaded - but otherwise works well. I have 1 reqest that I am not sure is possible or not - it would be great if you could 'mount' a directory as a drive so you can put .xex's in it to play from. This would reduce the need to swap alot of .atrs in and out for some things. Great job guys! Quote Share this post Link to post Share on other sites
cas #2 Posted November 9, 2007 I have 1 reqest that I am not sure is possible or not - it would be great if you could 'mount' a directory as a drive so you can put .xex's in it to play from. This would reduce the need to swap alot of .atrs in and out for some things. Technically, it is possible. I'll forward your request to Thomas Grasel, the Firmware developer. Carsten Quote Share this post Link to post Share on other sites
jdh #3 Posted November 10, 2007 Great news, I've got a pre-order in for one of these. Early Christmas present hehehe Ok, My SIO2USB unit arrived yesterday and I loaded a few ATRs on it for testing. I committed to this thing awhile back and during the wait things changed like the Euro which prob wouldve kept me from buying this, but having said that the Unit looks great and the box has a very 80's feeling to it Quote Share this post Link to post Share on other sites
Marius #4 Posted November 11, 2007 I have 1 reqest that I am not sure is possible or not - it would be great if you could 'mount' a directory as a drive so you can put .xex's in it to play from. This would reduce the need to swap alot of .atrs in and out for some things.Great job guys! I read so many things like that... but WHY aren't you using a 16MB ATR loaded with ALL those XEX or other binaries? I'm almost never using another ATR.... always the same "16MB-1.ATR" loaded with games (and demos). It boots with a binary loader. All games are sorted like "arcade" "shoop'm'up" "walk and jump" etc. You really should consider to try that. Good luck Marius Quote Share this post Link to post Share on other sites
gambler172 #5 Posted November 11, 2007 Hi Guys The SIO2USB is a really nice thing.But sometimes i have a small problem.When mounting an ATR,i want to swar this ATR to another disk and it does not work.I tried this with the "Another World demo" and "Goldhunter".I mount the file,but if i want to swap it to disk 1,nothing happens. Maybe anyone can help.I use a normal Atari 800 XL and the Disk 1 was empty,when i wanted to swap the file to it. greetings Walter Quote Share this post Link to post Share on other sites
+CharlieChaplin #6 Posted November 11, 2007 Well, why not ask the developers ?!? Afaik it is possible to swap two drives / two ATR images... but err, do not know if it is possible to swap an ATR (eg. mounted as D2:) with an "empty" drive or a real Atari drive... and err afaik the SIO2USB supports only ATR images, no XFD images, no *.XEX/*.COM files... Since you speak german and the developers also, it might be much easier to ask them in your own language... -Andreas Koch. Quote Share this post Link to post Share on other sites
cas #7 Posted November 12, 2007 (edited) Hi GuysThe SIO2USB is a really nice thing.But sometimes i have a small problem.When mounting an ATR,i want to swar this ATR to another disk and it does not work.I tried this with the "Another World demo" and "Goldhunter".I mount the file,but if i want to swap it to disk 1,nothing happens. Maybe anyone can help.I use a normal Atari 800 XL and the Disk 1 was empty,when i wanted to swap the file to it. greetings Walter Hi Gambler, Hi all SIO2USB Users, from the fine user manual: 1.3.3. Technical Support Technical support is available via email: <support-email-address> (please take a look in your Handbook) Please remember that the developer are hobbyists but not a company. Please do not contact the developers via phone. Please send in your questions via email or use the web-address. Carsten Edited November 12, 2007 by cas Quote Share this post Link to post Share on other sites
Goochman #8 Posted November 12, 2007 I have 1 reqest that I am not sure is possible or not - it would be great if you could 'mount' a directory as a drive so you can put .xex's in it to play from. This would reduce the need to swap alot of .atrs in and out for some things.Great job guys! I read so many things like that... but WHY aren't you using a 16MB ATR loaded with ALL those XEX or other binaries? I'm almost never using another ATR.... always the same "16MB-1.ATR" loaded with games (and demos). It boots with a binary loader. All games are sorted like "arcade" "shoop'm'up" "walk and jump" etc. You really should consider to try that. Good luck Marius Awhile back I started to do this to fill out my MyIDE, however with 64 file folder limitations and eratic mass copying I gave up - care to share you 16mb images with us Quote Share this post Link to post Share on other sites
