LYNXGUY #1 Posted December 3, 2007 I recently got a huge bundle (10 pack boxes) of 5.25 inch floppy disks from EBAY for 99 cents and I would like to know if they are compatible with ATARI computers. SONY MD-2HD BASF 2S/HD MS-DOS IBM FORMATTED 3M DS,HD IBM AT COMPATIBLE AND COMPAC 386 AND MOST OTHER DS,HD DRIVE SYSTEMS MAXELL MD/2D COMPATIBLE WITH IBM PC,PC XT,AND OTHER COMPATIBLE 5 1/4" DOUBLE SIDED, DOUBLE DENSITY DRIVES KODAK 2S*2D COMPATIBLE WITH IBM PC, PC-JR, XT, HP-85,86,87 & 125, WANG, EPSON QX-10 AND OTHER DOUBLE SIDED, SOFT SECTORED PC SYSTEMS MEMOREX 2S/2D COMPATIBILITY COMMODORE, HP, IBM AND OTHERS 3M DOUBLE SIDED, HIGH DENSITY COMPATIBLE WITH MAJOR MANUFACTURERS COMPUTER SYSTEMS Quote Share this post Link to post Share on other sites
Bryan #2 Posted December 3, 2007 You will be able to use the 2D disks, but not the HD ones. Quote Share this post Link to post Share on other sites
LYNXGUY #3 Posted December 3, 2007 If anyone can use my HD disks I have 8x 10packs and I will except any REASONABLE offer for them, either 1 ten pack or multiple 10 packs. Quote Share this post Link to post Share on other sites
LYNXGUY #4 Posted December 6, 2007 Please someone make an offer as I do not want to get stuck with 8 ten packs of floppy disks Quote Share this post Link to post Share on other sites
Fröhn #5 Posted December 6, 2007 5.25" HD disks can only be used in HD drives which usually only appear in old IBM-compatible PCs. For all those 8 bit homecomputers (C64, Atari XL/XE, VIC20 etc etc) they are useless. Quote Share this post Link to post Share on other sites
jhillestad #6 Posted January 18, 2008 Please someone make an offer as I do not want to get stuck with 8 ten packs of floppy disks $1.05 ? That leaves you a 6 cent profit and the DD disks free! Sound reasonable ? Quote Share this post Link to post Share on other sites
Clint Thompson #7 Posted January 18, 2008 I thought at one point I remember reading an article saying you can format HD to DD? I know this may not work in the 8bit world of things but just saying... I remember this in Dos for dummies or something? Quote Share this post Link to post Share on other sites
+Larry #8 Posted January 18, 2008 I thought at one point I remember reading an article saying you can format HD to DD? I know this may not work in the 8bit world of things but just saying... I remember this in Dos for dummies or something? How about "maybe" for an answer? There is a very good section on floppies here: http://en.wikipedia.org/wiki/Floppy_disk On a PC with a HD controller and drive, this is no problem (although later writing to that disk with a DD drive may cause problems). The reason is that they were designed to be able to do this operation. The problem with doing the DD format with a DD controller on a HD disk is that the magnetic media is fundamentally different. In general, it takes a stronger recording signal to properly magnetize/align the HD media. So (again, in general) you end up with a disk that may have very short longevity of the data. Having said that, these factors vary from disk manufacturer to manufacturer based on the magnetic formulations that they used for the media. I have seen it successful with some disks and not with others. (And likewise the corollary HD format on a DD Disk). But if you value your files, it is not recommended. -Larry Quote Share this post Link to post Share on other sites
