VideoFever1982 #1 Posted January 18, 2008 I have a Double Dragon when it's turned on, just comes up with a yellow screen. Any ideas on what it could be? Quote Share this post Link to post Share on other sites
Crazy Climber #2 Posted January 18, 2008 Did you check all the basics (loose PCB, etc..) Quote Share this post Link to post Share on other sites
VideoFever1982 #3 Posted January 19, 2008 Did you check all the basics (loose PCB, etc..) Yes....i got it real cheap as broken and also i know when it was turned on, the wires weren't hooked up correctly to the power supply and we got 2 or 3 snaps from the board so i don't know. It was yellow beofre that and it still is so god only knows what is gone on it Quote Share this post Link to post Share on other sites
Crazy Climber #4 Posted January 19, 2008 Did you check all the basics (loose PCB, etc..) Yes....i got it real cheap as broken and also i know when it was turned on, the wires weren't hooked up correctly to the power supply and we got 2 or 3 snaps from the board so i don't know. It was yellow beofre that and it still is so god only knows what is gone on it Have you tried running a different jamma board in it to see if your board has a problem? Quote Share this post Link to post Share on other sites
Dr Galaga #5 Posted January 20, 2008 I have had a few problems with loose connections of the video signal to the monitor. Be very safe/careful if you try this. With the game on, and with someone in front looking at the monitor, wiggle the connector on the monitor where the video signal goes in to it from the PCB. If you can not reach this safely, use a plastic screwdriver (NOT METAL). If this does not work, try adjusting the blue level on the monitor. Quote Share this post Link to post Share on other sites
VideoFever1982 #6 Posted January 25, 2008 Did you check all the basics (loose PCB, etc..) Yes....i got it real cheap as broken and also i know when it was turned on, the wires weren't hooked up correctly to the power supply and we got 2 or 3 snaps from the board so i don't know. It was yellow beofre that and it still is so god only knows what is gone on it Have you tried running a different jamma board in it to see if your board has a problem? Its the only jamma i have right now. Quote Share this post Link to post Share on other sites
VideoFever1982 #7 Posted January 25, 2008 I have had a few problems with loose connections of the video signal to the monitor. Be very safe/careful if you try this. With the game on, and with someone in front looking at the monitor, wiggle the connector on the monitor where the video signal goes in to it from the PCB. If you can not reach this safely, use a plastic screwdriver (NOT METAL). If this does not work, try adjusting the blue level on the monitor. As for the board itself, i know it has a problem because it did this on another monitor Quote Share this post Link to post Share on other sites
Crazy Climber #8 Posted January 26, 2008 I have had a few problems with loose connections of the video signal to the monitor. Be very safe/careful if you try this. With the game on, and with someone in front looking at the monitor, wiggle the connector on the monitor where the video signal goes in to it from the PCB. If you can not reach this safely, use a plastic screwdriver (NOT METAL). If this does not work, try adjusting the blue level on the monitor. As for the board itself, i know it has a problem because it did this on another monitor If the Board is the problem just purchase a new one, I have seen DD boards go as cheap as $20 on Ebay. Quote Share this post Link to post Share on other sites
