Sign in to follow this
SoLo2
Atari 5"1/4 and PC-MSDOS compatible. FAT format.
Hello!
I did post this to "atari.org"
a while ago. As I had nearly
no answer, but I still think
using a de-facto standard
floppy format is interesting
for the XL scene and users...
I would like to know of
any Atari programmers,
if there exists any
DOS for XL that can
read&write PC MSDOS
compatible 5"1/4 diskettes.
Is this possible?
Does the hardware permit
such compatibility?
Anyways, it would be
interesting to know if
there is any DOS for
Atari XL that uses a
FAT file system. I think
it would be possible to
program a DOS that uses
nearly equal FAT disk
configuration.
Very nice would be,
to use with emulators
in Windows/Unix, to
mount disk images and
add/delete files.
Greetings,
SoLo2
Visit: bits.atari.org
Greetings again,
SoLo2
The problem with using a FAT type system is that the sector links are kept in the FAT.
Therefore, when doing file read or creating a new file, you need to keep the entire FAT in RAM, otherwise you'll have time wasting seeks all the time.
Assuming an ED 1050 disk of 1040 sectors and FAT12, that equates to about 1600 bytes more RAM that the DOS would have to use.
You'd probably also need file buffers equal to the cluster size, so there's another 512 bytes for each file which can be OPEN at a time - for any sort of useable filing system you want that to be at least 3.
ed: actually for 512 byte clusters, that would equate to 1040/4 = 260 clusters. May as well use FAT8 and sacrifice the sectors > 1024 or use them for something else.
Or, reduce cluster size to 256 or 128 - smaller file buffers needed but the FAT size gets bigger again.
End result - a DOS that uses almost 3K more than a standard one. But, in some ways FAT would be more efficient than Atari's DOS from a programming point of view, so the actual FMS code might be shorter.
But, standard 810 and 1050s don't read DOS disks. Not sure about the XF551 and others. Also, floppies are out of favour anyway - it's pointless spending money on old tech just to have some PC compatability when there are much better solutions like Hard Drives and SD card readers about (and they use FAT anyway, IIRC).
Edited by Rybags
I recall that Happy/Hyperdrive and laser 1050 upgrade's had the capability of reading PC disks (as long as you had the software, which xcame with the happy/laser upgrades)
The compatibility of the hardware would only be possibly for 180K disks and maybe 360s for later drive mechs.
All up, a lot of trouble to go to if you don't already have a "Happy" solution, and not really worth any effory since 5.25 has been dead on the PC for a long time.
Not to mention the existence of much better alternatives like APE, SIO2SD and the various IDE interfaces around.
A FAT 16 driver is planned for a future release of the SpartaDOS X. Don't know, if this year, though.
Well, one can argue that Atari DOS 3 was actually an attempt to provide a FAT like filing system - it is very similar to FAT, the sector links are kept in a separate sector (DOS 2 would call that
the VTOC, but for DOS 3 it is the FAT), and four sectors are combined in a block to fit the FAT into one sector, so you get the typical 512 bytes/sector FAT uses.
Needless to say, DOS 3 never became very popular. For various reasons, of course, but the sector waste - for the small Atari disks - was one.
Greetings,
Thomas
Hello!
Assuming the XL floppy drive uses
1040 sectors of 128Bytes each:
FAT8 has space for 256 clusters
FAT8 and 128Bytes/cluster:
1040 clusters... too BIG for FAT8
FAT8 and 256Bytes/cluster:
520 clusters... again too BIG for FAT8
FAT8 and 512Bytes/cluster:
260 clusters... again bigger than FAT8
but loosing 4 clusters = 2048Bytes....
256 clusters, 4 sectors of 128Bytes each cluster
1Byte/link = 256Bytes = 1/2 cluster for the FAT
may keep 2 copies of the FAT in the same cluster
FAT8 and 1024Bytes/cluster (old Linux size):
256*1024Bytes = 256K capacity per floppy
FAT of size 256Bytes again, this time it occupies
1/4 of a cluster and so 4 copies may be kept,
4 copies is very secure, but sadly, they are
stored in the same cluster.
Only 133 clusters in a 1050XL floppy disk.
FAT10 and 128Bytes/cluster:
1040 clusters .... too BIG for FAT10
or else there may be 16 sectors lost:
1024 * 10bits = 10240bits = 1280Bytes = 10 clusters FAT
FAT10 and 256Bytes/cluster:
1024 * 10bits = 10240bits = 1280Bytes = 5 clusters FAT
1024clusters * 256Bytes/cluster = 256K per floppy disk
520 clusters in a 1050 XL floppy disk
FAT10 and 1024Bytes/cluster:
1024clusters * 1024Bytes/cluster = 1MB per floppy! :)
260 clusters in a 1050 XL floppy disk
FAT11 is the minimum for
1040 clusters or sectors of 128Bytes each
int(log2(1040))=11 bits
not to loose 16sectors :)
FAT12 and 128Bytes/cluster:
this FAT has space for upto 4096 links
12bits * 4096links = 6144Bytes = 48 clusters! FAT
for the 1050 floppy only 1040links*12bits = 13 clusters! FAT
FAT12 and 256Bytes/cluster:
4096clusters*256Bytes=1 MegaByte max. per disk
24clusters for a 4096links FAT
7clusters for 1040links FAT of a 1050XL drive
FAT12 and 1024Bytes/cluster:
4096clusters*1K = 4 MegaBytes max. per disk
FAT16 and 128Bytes/cluster:
this FAT has space for upto 65536 links
16bits * 65536links = 131072Bytes = 1024clusters for the FAT!
65536clusters * 128Bytes = 8 MegaBytes max. per disk
1040links * 16bits = 2080Bytes = 17 clusters for FAT
FAT16 and 256Bytes/cluster:
65536clusters * 256Bytes = 16MegaBytes max. disk capacity
and 512clusters to store the FAT
1040links * 16bits = 2080Bytes = 9 clusters for the FAT
FAT16 and 1024Bytes/cluster:
64Mega Bytes max. disk space
128 clusters to store the FAT
3 clusters FAT for a 1050 XL floppy
This was more or less a synthesis of what
Rybags said in the previous post.
Of interest are the FAT12 and FAT16 which
are compatible with the MS-DOS world.
And for normal floppies the FAT12 and
256Bytes/cluster solution which manages
floppies of upto 1MB. It uses 7 clusters for FAT.
For more advanced floppies, like the modern
HHD PC floppies of 1.44MB, FAT12 and
512Bytes/cluster.
This last was also the sector size for Atari ST
computers, which were PC MSDOS FAT compatible:
2 sides * 80 tracks * 10 sectors * 512Bytes = 800 K
FAT16 wouldn't fit at once in the XL's memory.
This FAT needs 128K of RAM for 64K links ! :)
But if using a reduced cluster number of 1040, then
3K are required for the FAT, when using 128Bytes/cluster.
Or less, if using 1024Bytes/cluster only 260Bytes of
FAT in RAM memory.
FAT16 with full 128K FAT may be read as necessary
from disk or memory cards, because these are very
fast and XL files are very little, and maybe are wholly
contained in 1 or 2 FAT clusters (see Linux "inodes").
Of course, a mass storage abstracted from the
used file system, would require only the file name or
URL to load the data. This is more useable; faster,
reliable and consumes less RAM in the little XL! :)
This is the actual approach.
I would use the FAT8 with big clusters of
1024Bytes, as realizing how each XL program
may fit perfectly in only 1K, and still there's room
for 133 such little files in a 1050 floppy.
FAT8 fits in one 6502 page. 4 copies fit in 1
1024Bytes cluster, for safety.
Greetings,
SoLo2
I agree its kinda pointless to do that now where many people don't even use their 3.5 disks at 1.44MB. I am actually surprised that when Tramiel took over Atari, he didn't start using the same 3.5in drives that go into PCs and just build an interface instead of the XF551. At that point, they could have built them cheaper than what it was costing to build those costume 1050 and 551 drives. Any serious Atari user probably would use both drives and transfer their stuff to 3.5 higher density disks to save space and the 3.5 disks were more durable.
But around 1990, hard drive technology became more feasible and more suited for needs. Too bad Atari never officially upgraded the 8-bit into a 16bit machine with better speed and graphics. Instead Atari dropped the whole thing in the early 1990s.
One advantage of FAT over the Atari DOS 2.x filesystem is that when deleting or seeking inside a file, you don't have to read it from the beginning just to know which sectors it uses. Also, sequential reads can go right from the device to RAM, without having to tweak the last bytes of each sector (same deal for writes).
Certainly doable with 128KB or more of RAM, and while floppies aren't really appealing, it would be nice to directly read and write FAT-formatted hard drives and CF/SD cards and be rid of the 16MB partition limit. The trouble would be all the ill-behaved programs that do their own disk ops or expect the FMS to fit into a tiny little area of RAM and use all the rest.
For sure.
Deleting or overwriting a file would need maybe 8 sector reads and a few writes rather than having to scan the entire file.
What we really need is a DOS that just works for 64K and better machines, and has 90%+ of it's code sitting under the OS. In that case, having FAT support could be done with much less concern for the extra couple of K RAM for buffering that it might need.
Didn't later versions of spartadros and mydos have support for 16meg plus partitions (i recall hearing that spartadros went upto 48meg partitions
Hello!
Then all this discussion is true.
FAT for XL is feasible only if
the floppy drive and diskettes
can be written and read raw,
The drive doesn't have any
static or hard saved values in
the magnetic medium. Does it?
No "hard" protections, I mean.
Bye bye,
SoLo2
p.s. I edited this message a
little bit as I couldn't understand
my own English... :)
Edited by SoLo2
Sounds like SpartaDOS! Especially SpartaDOS X.
This is exactly SpartaDOS X, except that SDX is yet better. Namely, on 64K machines it may sit under the OS, but on a 128K+ machines it can keep its code and buffers in the extended RAM. So that your concern about buffers occupying the main RAM doesn't really apply.
@carmel_andrews: to 32 MB actually. And the filesystem format has been extended so that it can theoretically go up to 4 GB. But this has not yet been implemented. In MyDOS the 16 MB barrier is unbreakable.
Edited by drac030
Yes, the Happy MS-DOS software could only do single sided 180K disks. And it wasn't very reliable because of the well known 300/288 RPM issue.
