iratanam #1 Posted June 15, 2008 I dug my old NES out of storage (just so the kids wouldn't be hogging up the comp's playing with Nestopia all the time) and it will power on when I press in the power button, but the power goes back off instantly. It didn't do this before I put it in storage about 10 years ago, any ideas? Thanks Quote Share this post Link to post Share on other sites
thegamezmaster #2 Posted June 15, 2008 Does the power button stay off or does it blink on and off. If so the game connector is bad. The NES is notorious for that. Otherwise if you can try another compatible power supply. Good luck Quote Share this post Link to post Share on other sites
iratanam #3 Posted June 15, 2008 Does the power button stay off or does it blink on and off. If so the game connector is bad. The NES is notorious for that. Otherwise if you can try another compatible power supply. Good luck It blinks, so I guess I gotta find a new connector. Quote Share this post Link to post Share on other sites
kroogur #4 Posted June 15, 2008 http://www.nintendorepairshop.com/default.asp I have not used these folks yet but when i need to i will give them a try. Maybe someone else has used them? Quote Share this post Link to post Share on other sites
shadow460 #5 Posted June 15, 2008 Got a world championship cart? If not, you're like the rest of us mere mortals. I don't have exact instructions, but benheck.com does. Disabling the lockout chip will stop the blinking. You still need a new connector, but this will make things easier in the short term. Quote Share this post Link to post Share on other sites
iratanam #6 Posted June 16, 2008 I took it apart and took the cart connector off of the MoBo and cleaned it really good (didn't help needless to say.) I do have the top off still and I can get it to work if I fidgit with the cart . Gonna order a new connector. Quote Share this post Link to post Share on other sites
iratanam #7 Posted June 17, 2008 Thanx for the help. I won't have to buy a new 72 pin connector after all. I cut pin 4 on the lockout chip, and that took care of the problem. At least for now it has. Quote Share this post Link to post Share on other sites
bacteria #8 Posted June 20, 2008 Disabling the lockout chip certainly helps to make the system read a cartridge (and also allow the NES to play any region carts), however due to the stress the cart slot takes when a game is inserted and popped down in the toaster, some of the pins in the cart slot can get recessed a bit - careful lifting with a small screwdriver should help to resolve this and make better contacts with your games. Quote Share this post Link to post Share on other sites
