Andromeda Stardust #1776 Posted July 19, 2015 Since the problem seems to happen only on TG-16, and TG-16 is electrically identical to PCE other than being larger with components spread out further. They are fairly confident the issue is related to TG-16 design somehow. The whiz over there will need more time to rule out everything from shit 5v regulator to excessively long bus before finding out the cause of the issue. Not quite electrically identical. Besides the swapped data bus lines (which is a physical not electrical problem), US released games all have region coding in them that makes them incompatible with PCE. Ironically, all PCE games lack this region code, and will run flawless on a US TG with an adapter. The Turbo Everdrive auto patches the US ROMs to strip region coding so any region protection when run on a PCE is moot. It could be an issue with the toggle switch which I have heard is easily damaged, so it's best to set this switch and not touch it again. I've had no issues with my Everdrive and I assume people who do could just as easily be the result of bad ROMs. Once I installed my No Intro set onto the 2Gb Micro SD, everything worked flawlessly. Krikzz is adding RAM and some other features to the Turbo ED v2 to enable a couple of obscure Japanese ROMs to work, and potential future support for CD system card BIOS. Also the new Turbo ED v2 is RAM based instead of flash, so future enhanced Hucard homebrew (currently non existent) can use the upper bank of it's own ROM as extra RAM. Since my TurboGrafx has no CD attachment (screw paying $400 for a CD-ROM drive that may or may not fail in a couple years) and there are no Hucard homebrew apps yet that use the RAM based storage, I don't see the need to update my Turbo ED. Also the 3D printed case is confirmed not to fit due to placement of the components. I'm not entirely sure, but it is possible that the RAM based storage could create issues if any poorly programmed games send write commands to the ROM bus. The write would be successful unlike on real hardware, and cause wrong values in the ROM resulting in bugs or crashes. Quote Share this post Link to post Share on other sites
PsychedelicShaman #1777 Posted July 22, 2015 The Action Max DVD is available again, at the time of this post there looks to be about 7 spots left. Action Max: A standard edition Action Max Collection DVD is now being produced with all 5 action max games. You can purchase it through this AA Marketplace thread. Quote Share this post Link to post Share on other sites
billysastard #1778 Posted August 12, 2015 funny thing is, I finally found a wondermagic last year but it did not have the power supply, but I bought it thinking that would be no problem. turns out the power supply is some really fucked up requirement that none of the generic radio shack types can match.... very frustrating. if anyone knows how to get power to the wondermagic, let me know. I'm baffled by it. i always used an official original sega megadrive psu on mine and that worked just fine assuming the genesis psu is the same spec it should power yours just fine (also used the same psu on the visoly/bung flashers for the gb, gba and ngpc). Quote Share this post Link to post Share on other sites
Dreammary #1779 Posted August 16, 2015 I really only only a FlashBoy+ (for Virtual Boy) but I'd really enjoy purchasing others for my various consoles one day. Quote Share this post Link to post Share on other sites
AW127 #1780 Posted August 17, 2015 Good and long list of different products. Good work. Some suggestions i have: - maybe some of the FPGA-products, which also use SD-Cards could be added also the the list. Like for example the Minimig (Mini-Amiga) and so on - the HxC Floppy Emulator should not only be mentioned in the Atari-ST category, but also in Amiga and Amstrad category of the list. Because in the meantime with newest firmware, it runs nearly 100% of all Amiga-software and is very famous in Amiga forums - the Gotek Floppy Emulator (also called Cortex Floppy Emulator) can also be used now on different retro-systems. There exist an Amiga-firmware for it since some time and recently there exist also versions of the HxC-firmware which can be flashed on the Gotek, so you can use it this hardware now on Amiga, Atari-ST and Amstrad too Quote Share this post Link to post Share on other sites
Mmm #1781 Posted August 17, 2015 Good and long list of different products. Good work. Some suggestions i have: - maybe some of the FPGA-products, which also use SD-Cards could be added also the the list. Like for example the Minimig (Mini-Amiga) and so on - the HxC Floppy Emulator should not only be mentioned in the Atari-ST category, but also in Amiga and Amstrad category of the list. Because in the meantime with newest firmware, it runs nearly 100% of all Amiga-software and is very famous in Amiga forums - the Gotek Floppy Emulator (also called Cortex Floppy Emulator) can also be used now on different retro-systems. There exist an Amiga-firmware for it since some time and recently there exist also versions of the HxC-firmware which can be flashed on the Gotek, so you can use it this hardware now on Amiga, Atari-ST and Amstrad too I don't agree. None of the above are flashcarts or multicarts. Fpga system clones are not a flashcart for the original console. HXC is a floppy emulator and so is gotek. Besides you are only citing computers and most of the flashcarts and multicarts are for consoles. Quote Share this post Link to post Share on other sites
goldenegg #1782 Posted August 17, 2015 Besides you are only citing computers and most of the flashcarts and multicarts are for consoles. Not true at all. Check out the second post in this thread. It specifically focuses on solutions for computers. Quote Share this post Link to post Share on other sites
Greg2600 #1783 Posted August 17, 2015 As long as the device will operate on the original hardware, it's appropriate here. PS: I've seen on the Krikzz forum that Igor identified the issue between his V2 Turbo Everdrive and TG-16 systems. Something to do with a longer bus on NA systems vs. PC-Engine. He summarized the versions as follows: TED V2.1 (FW 1.1) - some working, some are not, better than V2.2 TED V2.2 (FW 1.2) - most carts are not working properly on US TG16 TED V2.1 (FW 1.3) - always pass tests! TED V2.3 (FW 1.4) - prototype board, but all tests passed! *Make note that firmware is NOT user updateable, and his FPGA can only be flashed once. Therefore, any version that has an issue, cannot be fixed. You'll have to send it back for an exchange once he verifies his newest prototype does resolve the problems. Quote Share this post Link to post Share on other sites
+remowilliams #1784 Posted August 17, 2015 Got my Rhea and installed it, fantastic! Just needs a menu selector now Quote Share this post Link to post Share on other sites
AW127 #1785 Posted August 17, 2015 (edited) I don't agree. None of the above are flashcarts or multicarts. Fpga system clones are not a flashcart for the original console. HXC is a floppy emulator and so is gotek. Besides you are only citing computers and most of the flashcarts and multicarts are for consoles. Yes it`s true, that these are not multicarts or flashcarts, but in the list are even now lots of Floppy-Emulators mentioned. There are alot computers mentioned, have you read the list completely? Look, there is the SD2IEC, the 1541Ultimate, Chameleon and so on in the list now. When these are mentioned, why not mentioning all Floppy-Emulators? Then we would have a complete list. And because of FPGA-systems - the Chameleon is also a FPGA-system, which can run a C64-core alone, without a real C64. So when the Chameleon is mentioned, why not mentioning the Minimig too? Especially because the firmware for the original Minimig-board is very compatibel in the meantime, because of lots and lots of updates. Would be great to have a complete list. But i agree, that the name of the thread then is not 100% correct and should be "Flashcart, Multicart, Floppy-Emulators and FPGA List". Edited August 17, 2015 by AW127 Quote Share this post Link to post Share on other sites
Mmm #1786 Posted August 17, 2015 Not need to change the topic,,,i was wrong. But mention a fpga as a system i think it's not useful for this topic. Hxc emulates floppies for an enormous number of computers. Quote Share this post Link to post Share on other sites
Andromeda Stardust #1787 Posted August 18, 2015 (edited) As long as the device will operate on the original hardware, it's appropriate here. PS: I've seen on the Krikzz forum that Igor identified the issue between his V2 Turbo Everdrive and TG-16 systems. Something to do with a longer bus on NA systems vs. PC-Engine. He summarized the versions as follows: TED V2.1 (FW 1.1) - some working, some are not, better than V2.2 TED V2.2 (FW 1.2) - most carts are not working properly on US TG16 TED V2.1 (FW 1.3) - always pass tests! TED V2.3 (FW 1.4) - prototype board, but all tests passed! *Make note that firmware is NOT user updateable, and his FPGA can only be flashed once. Therefore, any version that has an issue, cannot be fixed. You'll have to send it back for an exchange once he verifies his newest prototype does resolve the problems. Dang dude, I really dodged a bullet with my TED v1.2... There have been similar issues getting DSP to work on the newer Super Everdrive v2 which don't use donors. I'm glad I bought my SED v2 and harvested my own DSP chip, prior to the new version coming out... Edited August 18, 2015 by stardust4ever 1 Quote Share this post Link to post Share on other sites
Greg2600 #1788 Posted August 18, 2015 Dang dude, I really dodged a bullet with my TED v1.2... | There have been similar issues getting DSP to work on the newer Super Everdrive v2 which don't use donors. I'm glad I bought my SED v2 and harvested my own DSP chip, prior to the new version coming out... It's surprising, because Krikzz has been exceedingly careful about releasing buggy hardware. That being said, the inability to update the firmware is an awful design choice on his part. I haven't heard of the DSP issues, but I stopped following SED development once I got the SD2SNES. Quote Share this post Link to post Share on other sites
Andromeda Stardust #1789 Posted August 19, 2015 (edited) It's surprising, because Krikzz has been exceedingly careful about releasing buggy hardware. That being said, the inability to update the firmware is an awful design choice on his part. I haven't heard of the DSP issues, but I stopped following SED development once I got the SD2SNES. No offence, but until they get FPGA implementations of SA-1 and FX working in SD2SNES, or someone comes out with a flashcart that does, my SED v2 with real DSP1 is good enough for me. IMO, krikzz is trying to fix a product that ain't broken. I can understand that to an extent because improved features means more sales. But he may be stretching himself too thin. I have everything save for Game Gear and SMS, and my Everdrive MD handles SMS just fine... The only flash cart I opted for premium option was 64ED v3, which supports save backup even after forgetting to reset, RTC (useless to me), and perhaps the coolest perk of all, NES ROM support. Edited August 19, 2015 by stardust4ever Quote Share this post Link to post Share on other sites
goldenegg #1790 Posted August 19, 2015 IMO, krikzz is trying to fix a product that ain't broken. The new Turbo Everdrive is built with a new lower power chips which will be needed for future flash carts, like the one he's making for GBA. It should actually provide better compatibility with systems which can't properly power other flash carts. There's no way for Krikzz to validate his carts of every model of system, so there's always going to be a certain amount of field testing by buyers. In the case of moving to the new chip for the Super Everdrive, it's to stop having to take components from original carts. I'm not a huge fan of rendering original carts unplayable, so I'm happy to see a move in this direction. Quote Share this post Link to post Share on other sites
XC-3730C #1791 Posted August 19, 2015 Any word on a new Atari Jaguar flash cart? Sent from my SAMSUNG-SM-N910A using Tapatalk Quote Share this post Link to post Share on other sites
Andromeda Stardust #1792 Posted August 19, 2015 Any word on a new Atari Jaguar flash cart? Sent from my SAMSUNG-SM-N910A using Tapatalk Pepé Le Pew? Quote Share this post Link to post Share on other sites
Greg2600 #1793 Posted August 19, 2015 No offence, but until they get FPGA implementations of SA-1 and FX working in SD2SNES, or someone comes out with a flashcart that does, my SED v2 with real DSP1 is good enough for me. IMO, krikzz is trying to fix a product that ain't broken. I can understand that to an extent because improved features means more sales. But he may be stretching himself too thin. I have everything save for Game Gear and SMS, and my Everdrive MD handles SMS just fine... The only flash cart I opted for premium option was 64ED v3, which supports save backup even after forgetting to reset, RTC (useless to me), and perhaps the coolest perk of all, NES ROM support. I have no qualms with using the SED over the SD2SNES, especially given the price difference! Ironically I didn't go for the N64 v3 because the v2 was so much cheaper, and I'm fine with holding down reset for now! The new Turbo Everdrive is built with a new lower power chips which will be needed for future flash carts, like the one he's making for GBA. It should actually provide better compatibility with systems which can't properly power other flash carts. There's no way for Krikzz to validate his carts of every model of system, so there's always going to be a certain amount of field testing by buyers. In the case of moving to the new chip for the Super Everdrive, it's to stop having to take components from original carts. I'm not a huge fan of rendering original carts unplayable, so I'm happy to see a move in this direction. Krikzz should have fully tested the TED v2 on a US TG-16. I believe he's had one for awhile, and that's a big share of his customer-base. That was a big omission on his part. I'm fine with field-testing, but you can't have that AND a FPGA which cannot be field-updated with new firmware. You leave the customer up a creek without a paddle. Quote Share this post Link to post Share on other sites
goldenegg #1794 Posted August 19, 2015 Krikzz should have fully tested the TED v2 on a US TG-16. I believe he's had one for awhile, and that's a big share of his customer-base. That was a big omission on his part. I'm fine with field-testing, but you can't have that AND a FPGA which cannot be field-updated with new firmware. You leave the customer up a creek without a paddle. He didn't have one, as he was using a PAL model as there wasn't expected to be a difference. Even if he did have one, some carts worked and others didn't. He could have easily had a system and run successful tests with it. Quote Share this post Link to post Share on other sites
Andromeda Stardust #1795 Posted August 19, 2015 Is there some reason why the FPGA cannot be updated? I assume Kirkzz has some hardware method of flashing it internally. Maybe Jtag or something similar. Other flash carts had a special ROM you could use to flash the Bios. N8 had an NES ROM with mapper 255. Quote Share this post Link to post Share on other sites
7800fan #1796 Posted August 19, 2015 Is there some reason why the FPGA cannot be updated? I assume Kirkzz has some hardware method of flashing it internally. Maybe Jtag or something similar. Other flash carts had a special ROM you could use to flash the Bios. N8 had an NES ROM with mapper 255. He used the cheaper one-time programmable. Which means it's locked to whatever code he used. Quote Share this post Link to post Share on other sites
Andromeda Stardust #1797 Posted August 20, 2015 So write once and done? That sucks... Quote Share this post Link to post Share on other sites
billysastard #1798 Posted August 20, 2015 The only flash cart I opted for premium option was 64ED v3, which supports save backup even after forgetting to reset, RTC (useless to me), and perhaps the coolest perk of all, NES ROM support. i hate to point this out but the ed64 v2 (and 2.5) both happily run nes roms (on a us n64, for some reason they play in b&w on a pal system) and don't forget if you use the alternate firmware you can also run gb, msx and game gear (but for the sake of your ears mute your sound for gg games). Quote Share this post Link to post Share on other sites
Andromeda Stardust #1799 Posted August 20, 2015 But still, ROMs load sooo fast on the N64 v3, it's ridiculous. Conker's Bad Fur Day takes like a couple seconds. Why do I have to justify buying the premium version anyway? Quote Share this post Link to post Share on other sites
XC-3730C #1800 Posted August 20, 2015 How well do NES and Gameboy games run on an N64 ED? Sent from my SAMSUNG-SM-N910A using Tapatalk Quote Share this post Link to post Share on other sites
