98PaceCar #1 Posted August 5, 2008 I'm looking for a copy of the Boing Ball demo to run on a Mega ST4. I'm doing a comparison demonstration between the Amiga, C64, and ST and wanted to run this as it exists on all 3 platforms. TIA! Quote Share this post Link to post Share on other sites
tjlazer #2 Posted August 5, 2008 I'm looking for a copy of the Boing Ball demo to run on a Mega ST4. I'm doing a comparison demonstration between the Amiga, C64, and ST and wanted to run this as it exists on all 3 platforms. TIA! It's called BOINK: http://pouet.net/prod.php?which=27109 Quote Share this post Link to post Share on other sites
+karri #3 Posted August 5, 2008 I'm looking for a copy of the Boing Ball demo to run on a Mega ST4. I'm doing a comparison demonstration between the Amiga, C64, and ST and wanted to run this as it exists on all 3 platforms. TIA! It's called BOINK: http://pouet.net/prod.php?which=27109 I discussed this demo with R.J. Mical when he visited Finland. He was quite proud of the color lookup trick with the palette for achieving the rotation of the ball. I believe this demo exists also for Atari Lynx. -- Karri Quote Share this post Link to post Share on other sites
Sub(Function(:)) #4 Posted August 5, 2008 I'm looking for a copy of the Boing Ball demo to run on a Mega ST4. I'm doing a comparison demonstration between the Amiga, C64, and ST and wanted to run this as it exists on all 3 platforms. TIA! It's called BOINK: http://pouet.net/prod.php?which=27109 I discussed this demo with R.J. Mical when he visited Finland. He was quite proud of the color lookup trick with the palette for achieving the rotation of the ball. I believe this demo exists also for Atari Lynx. -- Karri Hey if you are going to compare against the C64 version there is also one on the 8bit Atari Ball Demo: Ball_Demo__1985__Motz_.zip Also along the same lines checkout FujiBoink! (for the atari 8 bit) FujiBoink____1986__Park_of_Xanth_.zip Quote Share this post Link to post Share on other sites
98PaceCar #5 Posted August 5, 2008 (edited) I'm looking for a copy of the Boing Ball demo to run on a Mega ST4. I'm doing a comparison demonstration between the Amiga, C64, and ST and wanted to run this as it exists on all 3 platforms. TIA! It's called BOINK: http://pouet.net/prod.php?which=27109 I discussed this demo with R.J. Mical when he visited Finland. He was quite proud of the color lookup trick with the palette for achieving the rotation of the ball. I believe this demo exists also for Atari Lynx. -- Karri Hey if you are going to compare against the C64 version there is also one on the 8bit Atari Ball Demo: Ball_Demo__1985__Motz_.zip Also along the same lines checkout FujiBoink! (for the atari 8 bit) FujiBoink____1986__Park_of_Xanth_.zip Thanks! This is the one! Thanks for the 8 bit version as well! I had originally planned on using my 800XL in the display as well, but this was the only thing I found reference to that was on all 4 platforms. Are there any games or other demos that could work? Right now, my plan is to use the Boing demo, Defender of the Crown, and Maniac Mansion on the 3 computers as well as running the 2 games on a NES system. If I can come up with something that will cover the 8 bit as well I'd prefer to use that over the NES. Edited August 5, 2008 by 98PaceCar Quote Share this post Link to post Share on other sites
oky2000 #6 Posted February 25, 2009 A game that is available on all four of those machines is Gauntlet. Well almost Gauntlet 1 was programmed before the A500 was launched so only the super expensive A1000 was around and we didn't get Gauntlet 1. You could run Gauntlet 2 on Amiga and ST side by side AND then run Gauntlet 1 on C64 and Atari 8bit together. Gameplay is the same, it's just that Gauntlet 2 on the ST is cack compared to Gauntlet 1 and the Amiga version is a shitty port with no changes except what was needed to compile the source on Amiga compiler Quote Share this post Link to post Share on other sites
