ClausB #1 Posted August 30, 2008 25 years ago I dissected a friend's 5200 and noted how it differed from my Atari 400. I also disassembled the ROM and compared it to the 400/800 OS. I then used the info to convert the 5200 PacMan cart to run on the 400/800. From those notes I wrote this article for ANALOG magazine: http://www.atarimuseum.com/videogames/cons...nv_to_5200.html My question to all of you is this: Which game conversions were done using the info in that article? 3 Quote Share this post Link to post Share on other sites
classics #2 Posted August 30, 2008 I referenced it pretty heavily the first few times. So I guess that would be... nearly all of them? :-) Steve Quote Share this post Link to post Share on other sites
carmel_andrews #3 Posted August 30, 2008 25 years ago I dissected a friend's 5200 and noted how it differed from my Atari 400. I also disassembled the ROM and compared it to the 400/800 OS. I then used the info to convert the 5200 PacMan cart to run on the 400/800. From those notes I wrote this article for ANALOG magazine:http://www.atarimuseum.com/videogames/cons...nv_to_5200.html My question to all of you is this: Which game conversions were done using the info in that article? So, it was you that wrote that article...I thought it was Quote Share this post Link to post Share on other sites
Curt Vendel #4 Posted August 30, 2008 I have the source code to 800 Desert Falcon, anyone want to port it over to the 5200? I also have the sources to 800 Galaxian, it would be awesome if someone would write a Galaga conversion to it for the 800, then port it over to the 5200 as well... Any takers? Curt 25 years ago I dissected a friend's 5200 and noted how it differed from my Atari 400. I also disassembled the ROM and compared it to the 400/800 OS. I then used the info to convert the 5200 PacMan cart to run on the 400/800. From those notes I wrote this article for ANALOG magazine:http://www.atarimuseum.com/videogames/cons...nv_to_5200.html My question to all of you is this: Which game conversions were done using the info in that article? Quote Share this post Link to post Share on other sites
carmel_andrews #5 Posted August 30, 2008 Nothing personal curt...DF on the A8 was a pile of cack, i can't see the 5200 version being any better unless it was done to mimic the 7800 version (which was the best of the versions available) 1 Quote Share this post Link to post Share on other sites
+Allan #6 Posted August 30, 2008 Nothing personal curt...DF on the A8 was a pile of cack, i can't see the 5200 version being any better unless it was done to mimic the 7800 version (which was the best of the versions available) True but there still might be useful parts of the code that could be used. Allan Quote Share this post Link to post Share on other sites
ClausB #7 Posted August 30, 2008 I have the source code to 800 Desert Falcon... I also have the sources to 800 Galaxian...Would you happen to have the source code to Star Raiders to share? Well, I can dream, can't I? Quote Share this post Link to post Share on other sites
Rybags #8 Posted August 30, 2008 Have you done any more towards your Star Raiders HD effort? I think if the game could be reverse-engineered, there would be potential for some good enhancements. 1 Quote Share this post Link to post Share on other sites
+Allan #9 Posted August 30, 2008 Somebody want to start a thread about a new Star Raiders and what could be added to it within a 8-bit real-world game? Allan Quote Share this post Link to post Share on other sites
Curt Vendel #10 Posted August 30, 2008 Yes I do, but I have been asked not to release it. Curt I have the source code to 800 Desert Falcon... I also have the sources to 800 Galaxian...Would you happen to have the source code to Star Raiders to share? Well, I can dream, can't I? Quote Share this post Link to post Share on other sites
carmel_andrews #11 Posted August 31, 2008 You can't beat Star Raiders...It can only be equalled 1 Quote Share this post Link to post Share on other sites
MrFish #12 Posted August 31, 2008 Nothing personal curt...DF on the A8 was a pile of cack, i can't see the 5200 version being any better unless it was done to mimic the 7800 version (which was the best of the versions available) If the miserable scrolling routine was fixed it would probably be a decent game. Quote Share this post Link to post Share on other sites
carmel_andrews #13 Posted August 31, 2008 perhaps they could borrow the routine from Blue max/BM 2001 or panther...might make for a better game Quote Share this post Link to post Share on other sites
ClausB #14 Posted September 2, 2008 25 years ago I dissected a friend's 5200 and noted how it differed from my Atari 400. I also disassembled the ROM and compared it to the 400/800 OS. I then used the info to convert the 5200 PacMan cart to run on the 400/800. From those notes I wrote this article for ANALOG magazine:http://www.atarimuseum.com/videogames/cons...nv_to_5200.html Unfortunately, there were some typos in the published article. I sent them a clean printout and a floppy disk with the proofread article in some Atari format. They said they could not convert the disk to their typesetter so they manually retyped it and filled it full of typos. When I sent a letter to the editor with corrections and updates, they edited out the corrections! The typos survive on the Web copies too. Here are some I noticed: "POKEY's registers are all addressed at page $EB in the 5200 as opposed to $D2 in the 400/800." That should be page $E8, but luckily any page from $E8 through $EF will address POKEY. "The even pots (POT0-POT6) give the horizontal positions of range from 1 to 228;" That seemingly poor English is really the start of one sentence grafted to the end of another. Between "of" and "range" should be something like "the joysticks and the odd pots give the vertical positions. The position values". In the cartridge pinout table, pin 9 should be "-Enable 80-BF", not "Enable 80-8F", and pin 10 should be "-Enable 40-7F". I recall their were more typos, but that's all I can find now. Has anyone else found others? Quote Share this post Link to post Share on other sites
R.Cade #15 Posted September 11, 2013 Is it possible to make a cartridge for the 5200 that contained the missing ROMs (reworked) and could boot from a disk drive and run games that way? It seems that you could, since the serial port signals exist on the expansion connector. Quote Share this post Link to post Share on other sites
+Allan #16 Posted September 11, 2013 Is it possible to make a cartridge for the 5200 that contained the missing ROMs (reworked) and could boot from a disk drive and run games that way? It seems that you could, since the serial port signals exist on the expansion connector. You would need to develop a new operating system. Plus just like an Atari 400, you would need more RAM for the DOS, which would have to be written as well. Not impossible but a lot of work. You could do things with the serial lines. Atari was developing a computer keyboard and a musical keyboard. Allan Quote Share this post Link to post Share on other sites
kiwilove #17 Posted September 23, 2013 I do have a request for a mod for Star Raiders - which I think was needed from day one. That is to not have the green screen present, during actual combat - as I always liked the black starfield illusion (of travelling through deep space) to be present during gameplay. Perhaps the text window could be 'green' to signify the shields are on. I think this mod will add to the overall enjoyment of the game. Of course, if someone wanted to update the game entirely - it would be to change it from a low res graphics mode to a higher one - with much improved graphics. And it would be a real challenge to do that, without a slow down for the gameplay, etc etc. Harvey 1 Quote Share this post Link to post Share on other sites
+playsoft #18 Posted September 30, 2013 25 years ago I dissected a friend's 5200 and noted how it differed from my Atari 400. I also disassembled the ROM and compared it to the 400/800 OS. I then used the info to convert the 5200 PacMan cart to run on the 400/800. From those notes I wrote this article for ANALOG magazine: http://www.atarimuseum.com/videogames/cons...nv_to_5200.html My question to all of you is this: Which game conversions were done using the info in that article? I used it for my two recent ports thank you. 1 Quote Share this post Link to post Share on other sites
wt808 #19 Posted October 4, 2013 I do have a request for a mod for Star Raiders - which I think was needed from day one. That is to not have the green screen present, during actual combat - as I always liked the black starfield illusion (of travelling through deep space) to be present during gameplay. See the patched rom attached to post #8 here: http://atariage.com/forums/topic/181833-star-raiders-hack-wanted/ Quote Share this post Link to post Share on other sites
ClausB #20 Posted October 16, 2013 Cool! You're welcome. I used it for my two recent ports thank you. Quote Share this post Link to post Share on other sites
Lynxpro #21 Posted October 18, 2013 Yes I do, but I have been asked not to release it. Curt I was under the impression most thought the 5200's version of Star Raiders was the best 8-bit version out there, including over the original A8 version... Quote Share this post Link to post Share on other sites
baktra #22 Posted May 18, 2018 Better late than never. I ported the Curse of the Lost Miner game to Atari 5200 using the guide back in 2015. 1 Quote Share this post Link to post Share on other sites
