Grazey #1 Posted September 7, 2008 Hi, I finally hooked up my NetusBee to my router. But I haven't got a clue what to do next. I'm trying to connect my PC (Win XP) with my MegaSTE. I've managed to ping my ST from the PC so the connection is working. But now I'm stuck. My ST has got normal TOS so how do I transfer files over to my PC (and vice versa) , someone mentioned I need to use a FTP client but that doesn't seem to work. My ST is 192.168.0.2 on my router. I tried to connect to this in CuteFTP it it doesn't work. Any ideas? Cheers GRZ Quote Share this post Link to post Share on other sites
Shredder11 #2 Posted September 7, 2008 Wow someone who actually has managed to receive one of these interfaces! Now if only I could find one too... Quote Share this post Link to post Share on other sites
Fletch #3 Posted September 8, 2008 Silly question, but do you have an FTP server on your PC? If you don't there is nothing to connect to. Fletch Hi, I finally hooked up my NetusBee to my router. But I haven't got a clue what to do next. I'm trying to connect my PC (Win XP) with my MegaSTE. I've managed to ping my ST from the PC so the connection is working. But now I'm stuck. My ST has got normal TOS so how do I transfer files over to my PC (and vice versa) , someone mentioned I need to use a FTP client but that doesn't seem to work. My ST is 192.168.0.2 on my router. I tried to connect to this in CuteFTP it it doesn't work. Any ideas? Cheers GRZ Quote Share this post Link to post Share on other sites
SFX Group #4 Posted November 6, 2008 Hi, I finally hooked up my NetusBee to my router. But I haven't got a clue what to do next. I'm trying to connect my PC (Win XP) with my MegaSTE. I've managed to ping my ST from the PC so the connection is working. But now I'm stuck. My ST has got normal TOS so how do I transfer files over to my PC (and vice versa) , someone mentioned I need to use a FTP client but that doesn't seem to work. My ST is 192.168.0.2 on my router. I tried to connect to this in CuteFTP it it doesn't work. Any ideas? Cheers GRZ I'm an thernet engineer so this should be easy.............. If you can PING from both ways (ST to PC and PC to ST) then 99% of your work is done... I think the easiest and safest way to do this will be load a FTP server on to XP (make sure you turn the firewall OFF until you have this working), you can download any good FTP server (GUILDTFTP i think is still working) then load an FTP client on to the ST with ST software, now i am unsure if this exsists so thets your next step. Once you have both set up, then you can use your ST to access the XP FTP server using the ST software to connect to the XP box via IP (ftp;//xxx.xxx.xxx.xxx:port). Many Thanks Ashley Quote Share this post Link to post Share on other sites
