27ace27 #1 Posted October 25, 2008 have you ever tried plugging a video touch pad into a DB-9 connector, rigging stuff up to it and pressing buttons to make the stuff work, just to have it not work when small things do? well the reason is the contacts on the rubber keypad. they give a lot of resistance. so what yoou need to do is open it up, and put a little bit of glue on the rubber contacts, then place a small bit of tinfoil, just enough to cover the contact, on the contact, then press down, and when that has been done, you have a video touch pad that could (possibly) switch house current! (I wouldn't recommend it) Quote Share this post Link to post Share on other sites
