yuppicide #1 Posted November 10, 2008 Never had this happen before.. when I hit F12 to do a screenshot in Stella on Windows it exits right out. My screenshot file is there, but it's 0kb size. I remapped the key to something else and it does the same thing. Quote Share this post Link to post Share on other sites
+stephena #2 Posted November 12, 2008 (edited) Never had this happen before.. when I hit F12 to do a screenshot in Stella on Windows it exits right out. My screenshot file is there, but it's 0kb size. I remapped the key to something else and it does the same thing. This was a problem with previous releases, but I thought it was fixed in the newest version. If you're not already using version 2.6.1, try that one. Otherwise, make sure you have a valid snapshot directory in the underlying operating system (ie, it exists, you have write permission to it, etc), and make sure Stella points to it (from Options -> Config Files -> Snapshot path). I'd also like to hear your results, since even if the path doesn't exist, Stella shouldn't just die like that. EDIT: Also, if you don't mind, please forward me your stella.ini file, and state the location of the 0KB file that was created. Also, which ROM were you taking a snapshot of, and was it in software or OpenGL mode?? Edited November 12, 2008 by stephena Quote Share this post Link to post Share on other sites
