Sign in to follow this
ApolloBoy
Mega Man clone on the 8-bit: Is it possible?
I was originally thinking of programming a Mega Man-style game called "Cordoba Chronicles" for the 7800 (the details of which can be found on my AA blog), but now I've decided to move it to the 8-bit instead. I figured I should try doing it for the 8-bit since I've become focused on that platform lately, and it would be easier to develop for than the 7800. So could it be possible on the 8-bit?
In my opinion this kind of game should be possible on the atari, with extensive use of software sprites, like in One Moon and Two Suns (WIP, see
) project. With smaller sized sprites it might even run in 160x200, plus, there is always an option to reduce fps to 25/30 while still maintaining smooth enough action.
Cool, so on a semi-related note, what's a good (and common) assembler for the 8-bit?
I've been looking into MAC 65 recently but I can't seem to figure it out. I'm used to SuperMON 64 on the C64, so can anyone put up a good tutorial for MAC 65?
Just curious, how well do Action! and Turbo BASIC XL work for games? I'm thinking I should try my hand at a couple other languages before I settle on using assembly through MAC/65.
I can't speak for using Action, but in terms or game creation the only chance IMHO to achieve anything significantly decent is 100% assembler. Turbo Basic XL is excellent and a good place to practice and learn and run tests etc but you should progress to assembly. I would recommend MADS, it's well worth getting into.
I've tried using MADS and ATASM, but I can't seem to get either to work. MADS automatically closes and ATASM says it can't open the test code and then exits. Is there a good crossassembler for OS X out there?
here in the forums there is a Mac OS X port of MADS....
..and here it is
There is a post further on in the same thread from me with an example of compiling with ATasm.
All three are command line utilities so you need to run them in a Terminal.
@OP: If you need any help getting them going on OSX drop me a PM.
Edited by spookt
With regard to MADS, there isn't a gui with the program, the executable is purely a dos based compiler which you are best using via a batch file, you can use any text editor on the pc/mac to write your source. There are a few nice editors around suited to the job but you could also simply use MS notepad. If you were windows based, you can start a command prompt manually to run the mads executable to view the options, it'll simply close if you run the exe under windows. Edited by Tezz
have you seen Space Harrier XL? If that can be done as well as it is.. Mega Man would be a breeze.
Yes, I've seen Space Harrier XE and I'm really impressed by it. But hopefully once I get around to it on my break, I'll pick up learning 6502 assembly again and start some coding (hopefully).
