Elerach Posted December 7, 2008 Share Posted December 7, 2008 Hey everybody, I recently got a lynx, but im having some problems with it. I have an AC adaptor, and i tried 6 batteries, but no matter what i do, i cant get it to turn on. i tired cleaning the slots, trying different games, e.t.c But no luck...... the cart door wont close all the way but i put the carts in and they *click* like they should. Does anybody have any suggestions on how to remedy this problem? Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 7, 2008 Share Posted December 7, 2008 Pull it apart. Check the solder joins for the various wires that supply power etc. Use a multimeter to check that power is getting through or not. Try a game in it with the thing still apart. Quote Link to comment Share on other sites More sharing options...
Battlezone Posted December 7, 2008 Share Posted December 7, 2008 http://cgi.ebay.it/Atari-Lynx-Back-of-Syst...1713.m153.l1262 Quote Link to comment Share on other sites More sharing options...
Insert Coin Posted December 7, 2008 Share Posted December 7, 2008 Did you, by accident, plug your AC adapter into the headphones connector? Is so, you might have fried the chips and your Lynx is lost forever. Quote Link to comment Share on other sites More sharing options...
Elerach Posted December 7, 2008 Author Share Posted December 7, 2008 I definitely did not plug the AC adaptor into the headphone jack, i know that. i also have no idea what im looking for inside the lynx that might indicate anything is broken. i dont have a multimeter, although i can guess what it does (measures power) I'll take some photos and post them of the insides, and maybe somebody can tell me what is wrong. Quote Link to comment Share on other sites More sharing options...
Elerach Posted December 7, 2008 Author Share Posted December 7, 2008 Ok, here are the pics. Does anybody see anything wrong? anything unusual? Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted December 7, 2008 Share Posted December 7, 2008 my lynx 1 does same thing though i know it needs that ebay item up there From what I know it is a common issue for things like this to happen, mine is soldered right from what I was told but the thing is it still doesn't work right Im in your boat as well, I hope you find out whats going on with yours, Quote Link to comment Share on other sites More sharing options...
+karri Posted December 8, 2008 Share Posted December 8, 2008 Hey everybody, I recently got a lynx, but im having some problems with it. I have an AC adaptor, and i tried 6 batteries, but no matter what i do, i cant get it to turn on. i tired cleaning the slots, trying different games, e.t.c But no luck...... the cart door wont close all the way but i put the carts in and they *click* like they should. Does anybody have any suggestions on how to remedy this problem? Sounds like the old MOS-FET problem. Q12 or was it Q11 in the Lynx I. You can easily try if this is the case by connecting a wire from headphone shield (the ground in for the headphones) to battery minus. It is the job of the MOS-FET component to do this connection to turn on the Lynx. If the Lynx turns on when you put the wire there then you know where your problem is. -- Karri Quote Link to comment Share on other sites More sharing options...
a8maestro Posted January 7, 2009 Share Posted January 7, 2009 Hey everybody, I recently got a lynx, but im having some problems with it. I have an AC adaptor, and i tried 6 batteries, but no matter what i do, i cant get it to turn on. i tired cleaning the slots, trying different games, e.t.c But no luck...... the cart door wont close all the way but i put the carts in and they *click* like they should. Does anybody have any suggestions on how to remedy this problem? Sounds like the old MOS-FET problem. Q12 or was it Q11 in the Lynx I. You can easily try if this is the case by connecting a wire from headphone shield (the ground in for the headphones) to battery minus. It is the job of the MOS-FET component to do this connection to turn on the Lynx. If the Lynx turns on when you put the wire there then you know where your problem is. -- Karri My #1 repair on dead Lynxes is to resolder the three pins on the power adapter jack. Rick D. Quote Link to comment Share on other sites More sharing options...
bradjewell Posted January 21, 2011 Share Posted January 21, 2011 Sorry for bumping a semi-ancient thread.. however, I was wondering if anyone had some of these mosfet laying around and if I could get 1 or 2 so I could fix a lynx I have that has this issue, any help would be greatly appreciated. Regards, Brad Sounds like the old MOS-FET problem. Q12 or was it Q11 in the Lynx I. You can easily try if this is the case by connecting a wire from headphone shield (the ground in for the headphones) to battery minus. It is the job of the MOS-FET component to do this connection to turn on the Lynx. If the Lynx turns on when you put the wire there then you know where your problem is. -- Karri Quote Link to comment Share on other sites More sharing options...
