spookt
Complete PL65 Manual
Hey - gotta love providence. I was patiently scanning through this a page at a time on my flatbed when guess what rolls up in the office? A brand spanking new colour copier / fax / digital sender / laser printer ! OK, I entrusted the manual to the sheet feed, tapped in my email address and ... presto PDF file. (Well actually 14 PDF files with 10 pages in each - need to find that setting and change it) And no bleed through ! :)
So after stitching it together and having made a quick check here at last is the complete PL65 Programming Manual:
PL65.pdf
Happy reading !
Edited by spookt
Oops, uploaded this in a hurry. Didn't realise it was 6Mb ! Here's a zipped version (roughly half the download size):
PL65.pdf.zip
WOW, this language looks cool! I wish that I had known about this language when it came out!
& the editor looks like it would be great...
Can someone post the ATR of the last version? I presume that there is a non-copy protected version out there, right?
Are there any additional toolkits, user contributed libraries, or example source listings out there?
It's here.
I have an original disk from the same collection as the manual but it's bad - boots to the menu but the editor doesn't load :(
If anyone wants a label scan for that true authentic looks gimme a shout ;)
I don't believe it. I'm not alone!! :D
I've got the original disk and a happied backup somewhere (both still worked last time I tried them). Unfortunately it looked like my parents threw out the manual before I could retrieve it, so I'm sooo happy someone else has scanned it.
And how the hell did I miss this old thread? Didn't know that someone had actually cracked PL65, presumably from one of the uncracked/half cracked disk images I posted some time ago?
PL65 is my favourite 8-bit language. The compiler is a little slow because it seems to work its way compiling a function/procedure at a time before saving it, producing a compound file as it goes. If anyone could come up with a tool to convert the compound file into one contiguous block so that it could be run from a ROM cart then that would be :cool: 0
If anyone seriously wants to have a go at the language and needs any help then feel free to PM me. Although I haven't access to my 8-bits at the minute, I used this language so much that I should be able to remember most of it. It was my first introduction to pointers, long before I came across C/C++. :)
Edited by Tickled_Pink
@ spookt: Thanks a lot for scanning the manual! I'd never heard of this language before. I assumed I had the disk for it, but alas not to be. Good to see that the program has been cracked already. I didn't catch the thread about that being done before either.
The language looks great. On first review, it looks to be much better than Turbo-BASIC XL. No line numbers, PMG Library, Assembly functions, better constructs/functionality, etc.
@ Tickled_Pink: In the PL65 Cracked thread, the author of the language claims to have written a defragmenter for the executables. Unfortunately he says, "God knows if you would ever find this".
BTW: Now I know why you said, "I can't vote. My primary language has never been any of those." in the Programming Languages Poll. I thought you were making a joke, as I had assumed I hadn't forgotten any major languages (arrogant). You may soon have more company in your language choice. ;)
Edited by MrFish
OPTION-ESC...
Finally now I know how to exit the editor!!!
:D
Many thanks spookt for taking the time to scan this manual...
The guy who made the post wasn't the author (and didn't claim to be). I remember writing a letter to Noahsoft once and got a reply from someone with an Eastern European surname.
I might have a stab at doing a similar program myself. Wanted to do one for years but never got around to it. As it's all just stripping headers, it can't be too difficult to do.
Spookt: many thanks for PDFing and posting the manual.
Tickled_pink: yes, I cracked and posted PL65 using one of your images -- for which, thank you.
Now we can all enjoy what is surely the most obscure of the available 8-bit languages...
How did you crack it in the end? Do you remember what you did? When I made my attempt I only half did the job - I could get the compiler to load and run, but anything I tried compiling with it wouldn't run.
I had problems with compiled programs not running with the cracked PL65 version from the other thread.
What I found is that there is code (Location $3637) that runs when you press 1 to start the compiler, this code does a checksum of the copy protection code. Since the copy protection code was modifed to bypass the bad sector check the checksum no longer matches. This in turn triggers code at $3649 that XORs the first $80 bytes of the runtime with $AA rendering the compiled program unusable.
The version in the attached ATR has all of the code mentioned above removed and produces compiled code that runs now. :)
pl65fix.zip
Completely bookmarked now... EDIT: i forgot to say, text searchable too...
PL65___Manual.pdf
Excellent! Thanks. I was intending to go back and do that this week but you've saved me some work. :)
Yes, compiled programs run now. Great work! Many thanks.
Edited by MrFish
That's great. I suspected that something was affecting the runtime code rather than the user compiled program.
Nice to see a few interested people downloading the manual too. :)
BTW: Can't remember if this is in the manual, but here's a little tip. If you're finding the compilation process a little slow and just want to do some syntax checking, just type in the source filename and press return for all the others the compiler prompts for. That way it'll just read the source, compile it, but won't save anything to disk.
I've done a little reversing of the compiler, and it seems it has at least one bad bug. Use of the builtin variables like XSAVE, PUSH etc. will fail because there is a bug in the table scanner, it's off by one. So references to STACK will work, but nothing after that should be found. The compiler code is so odd that I remain convinced that it was written itself in either PL65 or something like it. For sure it was not written in Action!, it doesn't have any of the watermarks you'd see if that was used.
Wow - I just found out about this language today! Have there been any familiar programs that were developed on this language?
Hi Friends!
I bring to your kind attention and to your free disposal Memory Allocation Library for PL65 compiler.
It is fully working.
Just to ensure the clarity of the text I added some primitive functions to work with free-list in structs/records oriented manner.
You know of course that PL65 lacks of structs and records.
To my great surprise, this innovation made programming much easier.
Here are the code of library itself and program for debugging.
ALLOC.LIB
! ALLOC.LIB Memory allocation library
!       for PL65 compiler            !
! First-fit algorythm for malloc/free
! by Evgeny Zolotarev (aka 576XE),2017
CONST NULL=0,FRED=1,USED=0
CONST MEMSTART=$4000,MEMEND=$BC00
CONST MEMSIZ=MEMEND-MEMSTART
CONST METALEN=6,BYTSZ=1,INTSZ=2
POINTER gpP INT gpV BASED gpP
POINTER freList
FUNC getFlag(INT adr)
BEGIN gpP=adr END gpV
FUNC getSize(INT adr)
BEGIN gpP=adr+2 END gpV
FUNC getNext(INT adr)
BEGIN gpP=adr+4 END gpV
PROC setFlag(INT adr,flag)
BEGIN gpP=adr gpV=flag END
PROC setSize(INT adr,size)
BEGIN gpP=adr+2 gpV=size END
PROC setNext(INT adr,next)
BEGIN gpP=adr+4 gpV=next END
PROC memInit()
BEGIN
  setFlag(freList,FRED)
  setSize(freList,MEMSIZ-METALEN)
  setNext(freList,NULL)
END
PROC split(POINTER fits INT size)
  POINTER new INT blkSiz
BEGIN
  blkSiz=METALEN+size
  new=fits+blkSiz
  setFlag(new,FRED)
  setSize(new,getSize(fits)-blkSiz)
  setNext(new,getNext(fits))
  setFlag(fits,USED)
  setSize(fits,size)
  setNext(fits,new)
END
FUNC alloc(INT nBytes)
  POINTER curr,result
BEGIN
  IF (getSize(freList)=0) THEN
    memInit()
    WRTLN("Memory initialized") CR()
  ENDIF
  curr=freList
  WHILE ((getSize(curr)<nBytes OR getFlag(curr)=USED) AND getNext(curr)<>NULL) DO
    curr=getNext(curr)
    WRTLN("- Search for fitting block...")
  ENDWHILE
  IF getSize(curr)=nBytes THEN
    setFlag(curr,USED)
    result=curr+METALEN
    WRTLN("+ Exact fitting block allocated")
    RETURN result
  ENDIF
  IF getSize(curr)>nBytes+METALEN THEN
    split(curr,nBytes)
    result=curr+METALEN
    BASE=16
    WRTSTR("Block $") WRITE(result) WRTSTR("-$") WRITE(result+nBytes)
    WRTSTR(" size=") BASE=10 WRITE(getSize(curr)) WRTLN(" allocated")
    RETURN result
  ELSE
    result=NULL
    WRTLN("- No sufficient memory to allocate")
  ENDIF
END result
PROC merge()
  POINTER curr
  INT size,next
BEGIN
  curr=freList
  WHILE getNext(curr)<>NULL DO
    IF (getFlag(curr) AND getFlag(getNext(curr))) THEN
      size=getSize(curr)+getSize(getNext(curr))+METALEN
      setSize(curr,size)
      next=getNext(getNext(curr))
      setNext(curr,next)
    ENDIF
    curr=getNext(curr)
  ENDWHILE
END
PROC free(POINTER ptr)
  POINTER curr
BEGIN
  IF ptr>=MEMSTART AND ptr<=MEMEND THEN
    curr=ptr
    curr=curr-METALEN
    setFlag(curr,FRED)
    merge()
    WRTLN("+ Block freed, space merged")
  ELSE
    WRTLN("Please provide a valid allocated pointer")
  ENDIF
END
! End of Library
ENDFILE
ALLOC.PRG
INCLUDE TERMINAL.LIB
INCLUDE ALLOC.LIB
MAIN()
  POINTER p,r,k
  POINTER q,w
BEGIN
  freList=MEMSTART
  p=alloc(100*INTSZ)
  q=alloc(250*BYTSZ)
  r=alloc(1000*INTSZ)
  free(p)
  w=alloc(700)
  free(r)
  k=alloc(500*INTSZ)
  CR() WRTLN("Allocation and deallocation")
  WRTLN("are done successfully!")
END
And here is the result of allocations and deallocations of memory with related atr.
ALLOC in use
PL65 Compiler SpDOSx33a 360.atr
There is no simple way without using of monitor to find the beginning of heap, but you can use an arbitrary value after looking at XREF table.
You can freely delete debugging messages, of course
Best wishes from Moscow.
ez
Hi there, atx4us.
As I can remember KED - (PL65 full featured editor) was written in PL65.
Also I know that KrisCross by Simon Trew was written in PL65 too.
Hello, friends.
Recently I wrote simple bank-switching routine in PL/65.
! BANKS.PRG                          !
!   Using 130XE Extended Banks in    !
!     PL65 Programming Language      !
! Evgeny Zolotarev,(aka 576XE), 2020 !
!- CONSTANTS & VARIABLES:
BYTE PORTB=$D301
INT bkNum
!- DUMMY array representing ---------!
!- selected BANKs slice ------------!
BYTE bkMem[$4000]=$4000
!- Bank Selector Values -------------!
!- Emulator ONLY(Sic.) Atari 576XE --!
BYTE bkSel[33]
DATA $91,
  $81,$83,$85,$87,$89,$8B,$8D,$8F,
  $A1,$A3,$A5,$A7,$A9,$AB,$AD,$AF,
  $C1,$C3,$C5,$C7,$C9,$CB,$CD,$CF,
  $E1,$E3,$E5,$E7,$E9,$EB,$ED,$EF;
! String VAR  to store in all BANKS
STRING inp$[4+27]
  DATA "==> User DATA from Bank #00";
! Set string as VAR for appending
STRING out$[4+27]
  DATA "                           ";
!- PROCEDURES:
!- Clear Screen Procedure -----------!
PROC clrScr()
  CONST clr=255
BEGIN WRTSTR(CHR$(125)) END
!- Wait for Any Key Pressed ---------!
PROC anyKey()
  CONST none=255
  BYTE CH=764
BEGIN
  WRTSTR("Wait for a Key...") CR()
  WHILE CH=none DO ENDWHILE
  CH=none
END
!- Place bkSel Tags into PORTB ------!
PROC setBank(INT bkNum)
  CONST bkMask=%10010001 BYTE bkTag
BEGIN
  bkTag=bkSel[bkNum]
  LDA PORTB AND bkMask OR bkTag STA PORTB
END
!- Writes to Bank -------------------!
PROC writBk()
BEGIN
  FOR bkNum=1 TO 32 DO
    WRTSTR("Writing to BANK #") WRITE(bkNum) CR()
    IF bkNum<10 THEN
      inp$[25,25]=STR$(0) inp$[26,26]=STR$(bkNum)
    ELSE inp$[25]=STR$(bkNum) ENDIF
    out$=inp$
    setBank(bkNum)
    MOVE(.out,LEN(out$),.bkMem)
  NEXT
END
!- Reads from Bank ------------------!
PROC readBk()
BEGIN
    WRTSTR("Reading BANK #") WRITE(bkNum) CR()
    setBank(bkNum)
    MOVE(.bkMem,LEN(out$),.out)
    WRTSTR(out$) CR()
  NEXT
END
MAIN()
BEGIN
  clrScr() anyKey() writBk()
  anyKey() clrScr() readBk()
END
! >>> EOF <<< !
This routine uses 576KiB RAM extension scheme of
emulator ONLY!
It works perfectly while traversing EXTMEM only i.e. [1..32]
but if I try to traverse from MAIN bank to EXTMEM [0..32]
it simply clears the screen for a moment and skips one
or two strings of output or crashes.
Nevertheless the DATA in all banks stays written firmly.
I can see it reading emulator's monitor.
The routine itself is clear and understandable but I still
can not glue what's wrong.
PL65 SD_X33A.atr
Obviously you can use all codes at your disposal :)
zen
Edited by 576XE
33 minutes ago, Preppie said:
unfortunatly the disk won't load
Post an ATR. Perhaps it can be repaired.
And with a lot of luck it is a different version.
