mimo
How to remove yellowing from an old Atari case
On 8/12/2020 at 7:28 AM, Mclaneinc said:
Sadly after all the prep I was put off retrobrighting but its my own fault. Now you would think a huge plastic box covered in foil and UV led's popping out everywhere would be hard to miss but I put a C64 breadbin top half in and forgot about it despite it being under my feet (almost). When I took it out I was saddened to see that where the pillars the screws going into inside the top half were showing white circles on the outside of the case. So whereever the screws go into the top half there were light circles showing the size of the pillar inside...Bloody weird and very annoying.
So I did the bottom half and took much more care (ie didn't forget about it) and it came out ok but the top and bottom don't exactly match (top is lighter), its minor but you can see it close up..
I'm still going to do my USA Snes as its can't look any worse and fingers crossed it will be fine..
I'm just catching up on your progress Paul as I've not been online for a few days with this heatwave. Sorry to hear that you had a mishap with the liquid, how long did you leave the case top in? I've been in two minds about whether to risk my breadbin case so I'm certainly put off now, I'm not sure that mine is discoloured at all as the beige is the same inside and out. There's too many variants of the case to judge the shade of the plastic from memory although I do remember my one from the mid eighties being pretty much the same colour. I'm not too worried about the Amiga cases and the light XL case sections, as I feel they will fair well in the liquid. The lower quality XE cases are another concern though.
Hi Tezz, my top lid was 18hrs, as said I forgot about it..Well I checked it initially and then lost track of time...
The bottom was fine and certainly looks more right than the dark brown its had become..
My next test in the USA SNES the bottom is completely the wrong colour, it should be a bluey grey but its beige, looking online it seems to be a common issue..It looks wrong so I can't possibly make it worse (hopefully) and its a test to see if I continue with the treatment on other cases..
I'm pretty sure it was just my silly mistake on the C64 top..From all the reading its the most safe way to avoid streaking etc..Just keep a regular eye on it :)
Also my tub got pretty warm which I know accelerates the retrobrighting, wasn't too hot but warm enough..
Edited by Mclaneinc
Really nice Thomas, looks like it went swimmingly...
What is the hack on the last pic?
Is it the changing the impedance on the KB one?
Thanks, really happy with it. I even managed to keep the stickers on the underside of the cases intact. Though the aluminium model badges could do with some love.
That bodge was done before I got the system (which I'm guessing was 1988?), so I assume it's factory or my uncles attempt to improve the display output as it's attached to the RF modulator. I'm sure more knowledgeable people on here can let us know.
I've a bunch of parts coming from from the UK and Poland to upgrade the internals and finish it off.
Really sorry to hear about that mishap!
These things happen and it's totally my own silly fault...
More mod's, an Ultimate 1MB?  (Totally recommended and get the Flashjazzcat version of the bios, can be flashed on later though)
Whatever the mods are, you have fun there Thomas..
Edited by Mclaneinc
yes, U1MB ordered, along with a proper AV cable. Also, some cheap and cheerful ram chips from ebay to get it up to 64kb too.
I will try, a lot to learn (and re-learn!).
hopefully you have better luck on your next retro-brightening attempt.
I retrobrighted a Commodore 1702 monitor, and it showed some irregularities until I wiped the whole case liberally with baby oil.  The lanolin in the baby oil might really help your top (and bottom) case.
It's cheap and easy; give it a try - I think you'll be pleased.
