NML32 Posted February 5, 2009 Share Posted February 5, 2009 Hi all, I have an Atari 2600 Jr. that the Reset and Select buttons don't work. I tested with the Atari Test cart to confirm this. I ordered a new Reset/Select strip and still not working. I took a piece of wire and touch the lead for each reset and select, this worked. I was wondering if anyone had any ideas why the the original and new strip doesn't work before I resort to sodering switches in place. Thanks Quote Link to comment Share on other sites More sharing options...
NML32 Posted February 9, 2009 Author Share Posted February 9, 2009 No sugestions. I guess I need to make a trip to Radio Shack for two push buttons and soder them in place. What a poor design using the mylar strips. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted February 9, 2009 Share Posted February 9, 2009 What a poor design using the mylar strips. I agree. I too used common panel-mount push buttons on one of my Jr. to replace the broken mylar strip. Quote Link to comment Share on other sites More sharing options...
NML32 Posted February 9, 2009 Author Share Posted February 9, 2009 (edited) I just finished adding my push buttons for the reset and select. While I had it apart I cleaned all the other switches. Edited February 9, 2009 by NML32 Quote Link to comment Share on other sites More sharing options...
Rik Posted February 9, 2009 Share Posted February 9, 2009 Yeah i agree that plastic film design is pathetically cheap ass.Disappointing,cus the jr. is an otherwise cool machine,a little tricky to put back in the slot after opening the case up for cleaning or whatever. Quote Link to comment Share on other sites More sharing options...
tremoloman2006 Posted February 10, 2009 Share Posted February 10, 2009 What a poor design using the mylar strips. I agree. I too used common panel-mount push buttons on one of my Jr. to replace the broken mylar strip. nice work - love the all black jr. too! Quote Link to comment Share on other sites More sharing options...
BigO Posted February 10, 2009 Share Posted February 10, 2009 I just finished adding my push buttons for the reset and select. While I had it apart I cleaned all the other switches. That doesn't look entirely horrible. (I wish I'd seen this sooner, I know I have the parts you need that I pulled from a working Jr. with a badly mangled case. ) Is there no way to put a low profile tactile switch under those original "buttons" instead of drilling through-holes for a panel mount switch? Quote Link to comment Share on other sites More sharing options...
Stan Posted February 10, 2009 Share Posted February 10, 2009 How frequently do they break? Is it a matter of how much use it gets or are they just crap? Quote Link to comment Share on other sites More sharing options...
pinball22 Posted December 7, 2009 Share Posted December 7, 2009 Bumping an old thread, but I've just picked up a Jr. at a flea market that has this same problem. I pulled the mylar thing out of the slot on the board and put it back in and it still doesn't work. I'm a little confused about how adding switches works... there are some sort of squishy buttons in there that make a connection to the mylar, I guess? If I put different switches there, won't I need to wire them to that connector on the board somehow? If so, how? Can you get a replacement for the mylar ribbon? And if so, how do you get the plastic apart on the switches to put it in? Quote Link to comment Share on other sites More sharing options...
