Sign in to follow this
Sydtech
Atari 2600 color fade?
I have an original "heavy sixer" 2600 console, and I've noticed some strange behavior with it: after I've had the console on and running for a while, the colors will suddenly go off. I've noticed this mostly with Activision games - Pitfall II is the worst. The greens will go kind of a muted brown, etc. This is during gameplay, and is NOT the built-in color shift that happens when the console is idle for a while.
Is this a problem with my console, or with the Activision carts?
Thanks,
Scott
(Atarian since '77)
Nope, the TV's fine with everything else.
I'm trying to narrow it down to the console (was there ever a color drift problem with these?), the Pitfall II cart (was there a shielding or heat issue with Activision carts?), or maybe even the switchbox (although I've tried a few)...
Thanks,
Scott
My guess is it is either your power supply is going bad or the voltage regulator in your atari is going bad.
I have heard people complaning from the same symptom you are describing and it was one of the above two problems.
Do you have a different power supply to test it with?
Nah, I've got the same problem on my 4 switch woody. If I play for an extended period of time the colors start to shift a bit.
I heard once that it was a problem with the RF cable. I have no idea, its not so bad that I can't play, so I'll leave it alone for now
Hopefully someone here can lock the problem down and tell us how to fix.
I think - and I had the same problem with my sixer - it is the adjustable resistor (short: AR) inside your console.There are two ARs (RF and Sound)inside the 2600. Just open the system, look to the left and use a small hexagonal recess wrench to justage the colors. The system must be connected to the TV. If you are really cool, you will make a hole into the button-casing - so you can allways justage the 2600 while it is closed. Make sure the AR is clean and not oxidated. Clean it with contact-spray...
This will help!!! Make it. It is not the power supply or anything like this!!!
Look here in the button-left corner. This is the AR to clean and to adjust. It is signed with the word "color".
http://www.atariage.com/2600/archives/sche...c_2600_Low.html
