Wickeycolumbus #1 Posted February 15, 2009 After compleating Pong 512 Bytes, I decided I would attempt to cut the ROM size in half to a measly 256 Bytes. It is not down to 256 bytes yet, but it is getting there at only 343 Bytes. Some features had to be cut to slim it down like scoring and sound. This version was tested (and works) on real hardware. Here is the latest binary/source code. Pong256Bytes.bin Pong256Bytes.asm.zip Quote Share this post Link to post Share on other sites
Nukey Shay #2 Posted February 15, 2009 You really should give both players the ability to move. As it stands, if the first player is moving up it negates all other checks. How about... ;NOTE: RAM must have P0_Y immediately followed by ;P1_Y and P0_End immediately followed by P1_End. ;29 bytes...handles all movement lda SWCHA ;get both sticks ldx #2 ;# players to check .check_stick_loop: ldy P0_Y-1,x ;get current Y lsr ;slide off up bit bcs .not_up ;skip if set iny ;...or, bump Y .not_up: lsr ;slide off down bit bcs .not_down ;skip if set dey ;...or, bump y .not_down: lsr ;slide off right/left lsr ; (invalid movement) sty P0_Y-1,x ;Store updated Y pha ;push sticks to stack tya ;do addition now... clc ; adc #24 ; sta P0_End,x ;...to get the ending pla ;get back stick value dex ;bump to next player bne .check_stick_loop ;ends w / x=0, a=0 Quote Share this post Link to post Share on other sites
Nukey Shay #3 Posted February 15, 2009 Oops... Above, sta P0_End,x should be sta P0_End-1,x Quote Share this post Link to post Share on other sites
Wickeycolumbus #4 Posted February 15, 2009 You really should give both players the ability to move. As it stands, if the first player is moving up it negates all other checks. How about... ;NOTE: RAM must have P0_Y immediately followed by ;P1_Y and P0_End immediately followed by P1_End. ;29 bytes...handles all movement lda SWCHA ;get both sticks ldx #2 ;# players to check .check_stick_loop: ldy P0_Y-1,x ;get current Y lsr ;slide off up bit bcs .not_up;skip if set iny ;...or, bump Y .not_up: lsr ;slide off down bit bcs .not_down ;skip if set dey ;...or, bump y .not_down: lsr ;slide off right/left lsr ; (invalid movement) sty P0_Y-1,x ;Store updated Y pha ;push sticks to stack tya ;do addition now... clc ; adc #24 ; sta P0_End,x ;...to get the ending pla ;get back stick value dex ;bump to next player bne .check_stick_loop ;ends w / x=0, a=0 Good Point Now its down to 327 bytes. Pong256Bytes.bin Pong256Bytes.asm_2.zip Quote Share this post Link to post Share on other sites
Nukey Shay #5 Posted February 15, 2009 Don't forget to erase the ADC's up top. The additions are already done in the loop. I suppose that it's a pipe dream to get Pong the smallest game on the console. You could do a "Simon"-ish game less space...no GFX are even needed - just flash a color that corresponds to the direction the stick needs to be moved. By setting up a pseudo-ram cache of stick values, let the game cycle through an increased number of them. If incorrect, the game flashes the correct color with a buzzer. If correct, the index is bumped and the process repeated until the entire cache is used. A "game" of stopwatch would be smaller than that. Quote Share this post Link to post Share on other sites
Wickeycolumbus #6 Posted February 15, 2009 (edited) Don't forget to erase the ADC's up top. The additions are already done in the loop. That routine you wrote is magic I also saved around 6 bytes optimizing the kernel for a total of 305 Bytes. I suppose that it's a pipe dream to get Pong the smallest game on the console. You could do a "Simon"-ish game less space...no GFX are even needed - just flash a color that corresponds to the direction the stick needs to be moved. By setting up a pseudo-ram cache of stick values, let the game cycle through an increased number of them. If incorrect, the game flashes the correct color with a buzzer. If correct, the index is bumped and the process repeated until the entire cache is used. A "game" of stopwatch would be smaller than that. Well its the smallest so far I'll have to try a 128 byte Simon game later. Pong256Bytes.bin Pong256Bytes.asm_3.zip Edited February 15, 2009 by Wickeycolumbus Quote Share this post Link to post Share on other sites
Wickeycolumbus #7 Posted February 15, 2009 I was able to save several random bytes. Size is now 294 Bytes. Pong256Bytes.bin Pong256Bytes.asm_4.zip Quote Share this post Link to post Share on other sites
+Omegamatrix #9 Posted February 16, 2009 (edited) You can save two bytes by doing this: lda #$87 ; 2 sta VBLANK ; 3 asl ; 2 .loopVsync: sta WSYNC ; 3 ;------------------------------------- sta VSYNC ; 3 lsr ; 2 bne .loopVsync ; 2³ Basically it takes the routine in Macro.h and adds a little more to it. Edit: It also leaves A = 0, and you can save another byte a little later with TAY before you load the value for your timer. A little farther down from that #$80 is loaded for VBLANK, after that you can use ASL to have #$00 again instead of loading. When you're testing INPT4 I believe Y=0 at that point and you might be able to do TYA after the BMI. You can a few bytes too with your jumps. When you: ora #%00000010 jmp Store_LR_Status I believe you can: ora #%00000010 bne Store_LR_Status And you should be able to save three more bytes here: lda Ball_X cmp #$FE ;1 bne .Check_Other_X jmp Start_New_Round .Check_Other_X lda Ball_X cmp #160 ;156 bne Done_Update_Score Start_New_Round By going like this: lda Ball_X cmp #$FE ;1 beq .Start_New_Round Check_Other_X lda Ball_X cmp #160 ;156 bne Done_Update_Score .Start_New_Round I look forward to seeing you do this Wickey. It's cool stuff. Edited February 16, 2009 by Omegamatrix Quote Share this post Link to post Share on other sites
Wickeycolumbus #10 Posted February 16, 2009 (edited) I got it down to 259 Bytes Only 4 more bytes to go! ora #%00000010jmp Store_LR_Status I believe you can: ora #%00000010 bne Store_LR_Status I cant do that anymore, because I changed the way the ball logic works (see attached source) And you should be able to save three more bytes here: lda Ball_X cmp #$FE ;1 bne .Check_Other_X jmp Start_New_Round .Check_Other_X lda Ball_X cmp #160 ;156 bne Done_Update_Score Start_New_Round By going like this: lda Ball_X cmp #$FE ;1 beq .Start_New_Round Check_Other_X lda Ball_X cmp #160 ;156 bne Done_Update_Score .Start_New_Round I shortened my routine down to: lda Ball_X bne Check_Other_X jmp Start_New_Round Check_Other_X lda Ball_X cmp #160;156 bne Done_Update_Score Then yours saved me 1 byte, but I was able to shorten yours down to: lda Ball_X cmp #$FE beq Start_New_Round Check_Other_X cmp #160 bne Done_Update_Score Which saved 2 more bytes Edit: Saved 2 more bytes by cutting out the 'cmp #$FE' I look forward to seeing you do this Wickey. It's cool stuff. Thanks Pong256Bytes.bin Pong256Bytes.asm_5.zip Edited February 16, 2009 by Wickeycolumbus Quote Share this post Link to post Share on other sites
Albert #11 Posted February 16, 2009 Very cool to see this in 256 bytes. Can you make the paddles move faster? ..Al Quote Share this post Link to post Share on other sites
Wickeycolumbus #12 Posted February 16, 2009 It is finished! Only 254 Bytes now. Very cool to see this in 256 bytes. Can you make the paddles move faster? ..Al Paddles move faster now Pong256Bytes.bin Pong256Bytes.asm_6.zip Quote Share this post Link to post Share on other sites
+Omegamatrix #13 Posted February 16, 2009 You're on your way to a 16 game multicart in 4K. Great job getting it all to fit, Wickey. See if you can make draw the background without bumps at the top and bottom. Quote Share this post Link to post Share on other sites
roland p #14 Posted February 16, 2009 Nice effort! I wonder what other games can be made with 256b Quote Share this post Link to post Share on other sites
Wickeycolumbus #15 Posted February 16, 2009 You're on your way to a 16 game multicart in 4K. Great job getting it all to fit, Wickey. See if you can make draw the background without bumps at the top and bottom. Done Pong256Bytes.bin Pong256Bytes.asm_7.zip Quote Share this post Link to post Share on other sites
Nukey Shay #16 Posted February 16, 2009 I cant do that anymore, because I changed the way the ball logic works (see attached source) What he meant was that you can use an unconditional branch instead of a JMP when the status register is known. After an ORA involving a non-zero value, the Z flag would be clear...so you can BNE. In that source, you changed it to load a zero directly...but an unconditional branch can still be used there. Instead of BNE, use it's opposite BEQ. You just loaded a zero, so the flag is set. Quote Share this post Link to post Share on other sites
Albert #17 Posted February 16, 2009 Paddles move faster now Great, thanks! Now can you add an AI so I can play against the computer? ..Al Quote Share this post Link to post Share on other sites
Wickeycolumbus #18 Posted February 16, 2009 Paddles move faster now Great, thanks! Now can you add an AI so I can play against the computer? ..Al No Maybe in the 512 Byte version... Quote Share this post Link to post Share on other sites
Albert #19 Posted February 16, 2009 No Maybe in the 512 Byte version... Yeah, I was just joking. ..Al Quote Share this post Link to post Share on other sites
+Propane13 #20 Posted February 18, 2009 Any plans to see "how low you can go?" It will answer the question "what's the smallest playable game size?" Quote Share this post Link to post Share on other sites
Albert #21 Posted February 18, 2009 Any plans to see "how low you can go?" It will answer the question "what's the smallest playable game size?" You could probably make a simpler, non-Pong game that is a fair bit smaller in size.. ..Al Quote Share this post Link to post Share on other sites
Nukey Shay #22 Posted February 18, 2009 Yup...Simon is the smallest example I can think of (aside from Stopwatch which really isn't a game). No gfx needed at all. Maybe not even a display kernel...tho I dunno how real hardware would like it. Just set 1 of six background colors...4 for the directions you need to move, and 2 for a game over/game win indicator. Paddles move faster now Great, thanks! Now can you add an AI so I can play against the computer? ..Al No Maybe in the 512 Byte version... Actually, you could if the "AI" is incredibly dim. Quote Share this post Link to post Share on other sites
vdub_bobby #23 Posted February 18, 2009 Done This is very cool, but... You really really really need more than 1 angle for the ball. Also: you shouldn't allow the 1st player to serve the ball towards the 2nd player. And the ball wraps around the screen when you miss. Not done yet! Quote Share this post Link to post Share on other sites
Wickeycolumbus #24 Posted February 18, 2009 Done This is very cool, but... You really really really need more than 1 angle for the ball. Not going to be possible with only 256 bytes. There is only 1 byte free right now, and is pretty much optimized to the core. I may be able to free at most 4 more bytes. Also: you shouldn't allow the 1st player to serve the ball towards the 2nd player. Why not? And the ball wraps around the screen when you miss. Not done yet! This can be fixed, but requires some tinkering, and is not too much of a problem. If I have time later this week, I will fix that. Thanks for the feedback -Rick Quote Share this post Link to post Share on other sites
vdub_bobby #25 Posted February 19, 2009 Also: you shouldn't allow the 1st player to serve the ball towards the 2nd player. Why not? It allows for cheap points. You miss a shot and, before you are able to get ready (i.e., reposition your paddle near the center) your opponent serves the ball way out of reach and gets a free score. And while I'm being the resident naysayer, why not use paddles instead of joysticks? It probably wouldn't take more code. Quote Share this post Link to post Share on other sites
