If anyone wants to try. Give my bbs a call er telnet to it. I
on your pc telnet:\\stguild-bbs.dyndns.org
or if you have a lantronx box
atdt stguild-bbs.dyndns.org,23
I couldn't connect...
Hey Sniper, I tried just now and it never would connect either.
Just gave me a "trying <ip address>...."
Well it is back up as a test, if anyone wants to try to connect. I may just leave it up!
stguild-bbs.no-ip.org
Edited by sniperstorm
Hey buddy - long time no "hear"... :)
I tried it just now, with "telnet stguild-bbs.no-ip.org",
but I couldn't connect. Just a blank screen in my shell.
Thanks!
EDIT - Nevermind, got in just now! :)
I have a lantronix MSS100 I use with my a8, can someone tell me how to set it up to use with a 1040 STe?
Same general concept. You're using it to connect between your serial port
and your LAN. You can then telnet in or out, with the appropriate software.
Well I'm brand new at ST, so I guess I need to figure out the correct connection to the serial port, is it a direct connection? or does it need a null modem cable?
Also what is a good, easy to use software programe for connection to a BBS?
Its a normal serial port cable that goes from the Lantronix to the serial port
on the ST. You'll have to match up the ends, but its industry standard stuff.
Your LAN cable plugs into the Lantronix. No null-modem cable needed.
I've only used the Lantronix to *receive" calls with my BBS. I had to make several
changes in the Lantronix settings to do this. I'm not sure about what, if any,
changes you would need to do just to dial out. Speed will of course, have to be
the same for both the ST and the Lantronix - prob. duplex settings, stuff like that.
There are a couple of Telnet programs for the ST. I think you should also be able to
use any good Telecomms program that lets you get to a screen where you can actually
type the commands in, directly to your device.
HTHs.
PS Think I found one - try "TAZ".
taz_100.zip
HTHs.
taz_100.zip
Thanks for the info... Seems I just need to find some adaptors all my cables are 9pin serial...
(Edited message follows...)
Edited by doctorclu
Got in and joined
BBS Express! ST - Version 1.98a
Serial Number: 990101
hkjml
Hehehe... this is good stuff. Suggestion here "Running on an Atari..."
To Board #
Love the ASCII art! Only suggestion here for board #3 would be "Your life"
Wanted to post but guess I have to wait till I'm validated. The place looked neat though. Where can I find a copy of the BBS software? That might be the BBS system I would like to run.
Edited by doctorclu
Same as mine Doc, BBS Express! ST... :)
HTHs.
taz_100.zip
I pulled out the Lantronix tonight and relaized that I use a null adaptor when using it with my P:R: connection on the a8, so I'm guessing I DO need a Null Modem Adaptor/Cable for the ST too
Hmm, I've got an 800XL, but no P:R: connection, so I can't really comment on
that.
However, I can tell you that there is -no- null adaptor or null cable on my
Mega ST4, hooked up directly to the Lantronix UDS1100.
that.
Well, guess I need to hook it up and see waht I get :)
BBS is not responding when I connect and hit enter.
Check and see if the BBS is hanging.
Is tehre any reason why these ST BBS Express boards cannot be more responsive on connection (rather than requiring the enter key to be hit, or to give notice the enter needs to be hit?)
Is there any reason why these ST BBS Express boards cannot be more responsive on connection (rather than requiring the enter key to be hit, or to give notice the enter needs to be hit?)
The Lantronix should be able to do that Doc, but I've not found it in the manual (yet).
I'll have to dig that out and give it another try. It surely would be more user friendly.
I was just so happy when I got mine working at all, I didn't want to touch anything else.
The BBS went offline due to a power outage, its back up. I will validate people tomorrow.
It is strange, the 8-bit Atari BBS's come right up with a prompt. The Grove (another ST BBs) I think is run under emulation.
So the actual hardware Atari ST BBS's are requiring a carriage return before anything happens.
I advertised this BBS on a BBS promotion group, the immediate response was "There is nothing to do when I get there" I thought the guy was just being negative so I stated that and how I thought such negative comments were not helping BBS promotion to which he banned me from his site.
Looking back, he probably got to the BBS and got a blank screen (for reasons mentioned above.) Of course naturally the guy was not worth associating with in the end, but I think some confusion could have been avoided if the BBS came right up to a prompt. Or if the guy (who is supposedly a BBS guru) tried hitting the enter key for a response when nothing happened.
Oh well. Anyway, hope that can be ironed out.
okay so tonight I realized I have no idea how to use ST terminal software. on the a8 I just pull up IceT and enter the terminal from the menu and the lantronix comes up with LOCAL~> and I can telnet from there, so can someone with a lot of patience walk me through using TAZ to be able to dial into the BBS
(would also like to be able to telnet into IRC)
Anyone? I know there are some gurus in here :)
I could talk you through it. Honestly though, if you can get the term program talking to the Lantronix (making sure all the baud is the same and so forth) you can work the Lantronix from the ST like you do the Atari 8.
As for the telnet into IRC... there is a list I have up on a BBS that links to all the Atari BBS's (except the ST Guild at the moment)
telnet://rdfig.net (Prison Board BBS)
Log in
hit return till you get to the main menu
X for internet
A for Atari
Select the Atari IRC option.
