jrok #1 Posted February 27, 2009 (edited) I'm trying to incorporate acceleration/friction in "Shower Scene" to mimic a slippery shower floor, and I'm running into some trouble. If anyone can help it would be much appreciated. Basically, I can get objects to slide in a positive direction, but am unsure how to do negative operations. The ideal end result would start the object at zero acceleration, increasing velocity towards a maximum value (top speed) on joystick inputs, and decelerating to zero at a slower rate (the friction value) when the joystick isn't read. Also, if the object has built momentum in one direction when the opposite joystick input is read, it shouldn't instantly change directions but rather should decay to zero first before it begins to accelerate in the opposite direction. I hope that makes some sort of sense to someone out there Here's what I have: include fixed_point_math.asm dim playerX = a.b dim player_dir = c dim velX = d.d playerX = 40.0 player0y = 55 player_dir = 0 velX = 0.0 Main COLUP0 = $0E COLUP1 = $0E if player_dir = 2 then velX=velX+0.125 if player_dir = 1 then velX=velX+0.125 if player_dir = 0 && velX>0 then velX=velX-0.0625 playerX = playerX + velX drawscreen player0x = playerX gosub Move goto Main Move if joy0right then player_dir = 2 if joy0left then player_dir = 1 if !joy0left && !joy0right then player_dir = 0 goto Object return Object player0: %11111111 %11111111 %11111111 %11111111 end return I've tried certain things like negating the value of velX and creating deceleration values, but nothing has worked so far. Thanks in advance for any insight. Cheers, Jarod. slide.bas EDIT: I guess it would help if I could even spell "acceleration." Sorry. Edited February 27, 2009 by jrok Quote Share this post Link to post Share on other sites
jrok #2 Posted February 27, 2009 Okay, so I think I figured out the friction operation: include fixed_point_math.asm dim playerX = a.b dim player_dir = c dim velX = d.d playerX = 40.0 player0y = 55 player_dir = 0 velX = 0.0 const leftborder = 22 const rightborder = 130 Main COLUP0 = $0E COLUP1 = $0E if joy0right && player_dir = 2 then velX=velX+0.125 if joy0left && player_dir = 1 then velX=velX-0.125 playerX = playerX + velX drawscreen player0x = playerX gosub Move goto Main Move if joy0right then player_dir = 2 if joy0left then player_dir = 1 if !joy0left && !joy0right && player_dir = 2 && velX>0 then velX=velX-0.0625 if !joy0left && !joy0right && player_dir = 1 && velX>0 then velX=velX+0.0625 goto Object return Object player0: %11111111 %11111111 %11111111 %11111111 end return Of course, this seems a little sloppy to me... it seem like there should be some sort of div/mult operation that would handle this more efficiently. Also although the movement seems okay, I'm having trouble establishing boundaries for the object to "bounce off of." I've tried doing a directional shift when the object X requals or exceeds the constants "leftborder" and "rightborder", but the object always seems to cruise right through. Any ideas would be much appreciated. Thanks! slide.bas Quote Share this post Link to post Share on other sites
supercat #3 Posted February 28, 2009 The basic approach for acceleration in Toyshop Trouble was something like: (pseudo-code) target_speed = 0 if joystick is left then if firebutton then target_speed = -8 else target_speed = -3 endif if joystick is right then if firebutton then target_speed = 8 else target_speed = 3 endif if current_speed < target_speed then current_speed = current_speed + 2 if current_speed > target_speed then current_speed = target_speed else if current_speed > target_speed then current_speed = current_speed - 2 if current_speed < target_speed then current_speed = target_speed endif A key question in your acceleration logic is going to be whether you can manage enough animation frames to keep the character's feet on the ground. If so, different approaches will be required. Quote Share this post Link to post Share on other sites
MausGames #4 Posted February 28, 2009 I always do this by setting a variable to 50, and subtracting from 50 when the player pushes left, and adding to 50 when the player pushes right. Then adding code so that the closer the variable gets to 0 or 100, the faster the player moves in that direction. When neither is being pushed, the variable moves back toward 50. This also means that the faster the player is moving in one direction, the longer it takes to decelerate and change directions. Quote Share this post Link to post Share on other sites
jrok #5 Posted February 28, 2009 (edited) EDT: OK I fixed the bounce decay now. I just replaced: if playerX<=leftborder then velX=-velX if playerX>=rightborder then velX=-velX with if playerX<=leftborder then velX=-velX : player_dir=1 if playerX>=rightborder then velX=-velX : player_dir=0 It works pretty much as I expected. However, there is a nasty fatal bug that pops up every once in alwhile, where the object gets stuck at either edge, constantly swtiching direction and inverting velocity. slide.bas slide.bas.bin I think I'm getting closer here, but I still can't resolve the "bounce" and "top speed" operations. I wrote the following based on the assumption that if I inverted the object's velocity on a wall collision, then the object would bounce off at an equivalent rate of speed, then decay naturally to zero. It seems to invert the speed just fine, but it doesn't decay. Also, I can achieve top speed in the positive direction just fine. I thought that negative top speed could be defined as and integer between 128 and 254, but it doesn't seem to work. include fixed_point_math.asm dim playerX = a.b dim player_dir = c dim velX = d.d playerX = 40.0 player0y = 55 player_dir = 0 velX = 0.0 const leftborder = 22 const rightborder = 130 Main COLUP0 = $0E COLUP1 = $0E if joy0right && player_dir = 1 then velX=velX+0.125 if joy0left && player_dir = 0 then velX=velX-0.125 playerX = playerX + velX drawscreen player0x = playerX if playerX<=leftborder then velX=-velX if playerX>=rightborder then velX=-velX gosub Move goto Main Move if joy0right then player_dir = 1 if joy0left then player_dir = 0 if !joy0left && !joy0right && player_dir = 1 && velX>0 then velX=velX-0.0625 if !joy0left && !joy0right && player_dir = 0 && velX>0 then velX=velX+0.0625 goto Object return Object player0: %11111111 %11111111 %11111111 %11111111 end return Edited February 28, 2009 by jrok Quote Share this post Link to post Share on other sites
