Sign in to follow this
CV Gus
Paddles.
Well, after some success in repairing the Roller Controller for the old CV, I tried my hand at fixing the paddle problem on the 7800.
The problem was simple: they didn't work. For players 1 and 2; nothing- for 3 and 4, it was nothing and extremes: the object jumped from one side to the other. Also, the really bad side affected the other (implying a common problem).
So, to the best of my ability, using what equipment I have, I traced the schematic, and tested each component. Capacitors (looking for a shorted one), resistors, etc. My multimeter is not precise enough to accurately test such things, but it can compare them- if any one is different, it was probably defective.
Couldn't find nuthin'.
Lo and behold- players 3 and 4 (right jack) now worked fine, as did player 2. Player one did not work at all- wait- it did- no- not.
Re-solder the pin on the jack.
All four work fine, now.
It was several bad solders!
How old is your 7800? I wanna know so I know how long I've got until mine starts getting ring cracks.
Ring cracks around the controller port pins is pretty common on both the 7800 and the 2600. If I'm having controller problems with a system, that's always where I start (well, other than trying a known good controller...). It's just wear and tear from the constant plugging/unplugging of the controller, so it shouldn't matter how old the system is - just how much use it's had. It only takes a minute to resolder them - so don't worry about it. When it starts getting flakey - then you can go in there and fix it.
-Ian
-Ian
Obviously true, but you'll note that this was the problem for Player One, mainly- most of the trouble vanished after I desoldered/resoldered those components. So it was elsewhere, too. Did they rush them out, to better compete against the CV?
The schematics helped indirectly. Now it works.
