Sign in to follow this
Bowser N64
Building N64 Controller to USB Converter
Anyone think it possible to maybe modify my N64 controller and like solder a USB connector to the end of the cable, where my controller cable was?
To go from N64 to usb, you'll need some active logic - in this case, a microcontroller. You can also actually interface one to the parallel port with very little hardware - there's a kernel module that will support it. I did this with an NES controller several years ago. I also have no clue if there would be a Windows driver for it - I was using it with Linux.
It's not a simple rewire job. If you do a bit of searching, I know there is info out there to build an adapter to USB - but you'll need to know a fair amount of electronics to build one. It will involve a microcontroller, and the programming thereof.
-Ian
The more relevant question is - why bother?
N64 controllers must be almost the most unreliable things out there. PS1 controllers cost next to nothing, and USB adaptors for them are cheap.
The N64 emulators really would be better using the original controller. The N64 controller was so different from a layout perspective that I've had a difficult time getting another usb controller to work properly.
-Ian
I see.
Well, unless you just for some reason want to literally wire a 64 controller to work in a USB port, you could just get an adaptor, like the Joybox, I got one for the computer that will let you use 64, game.cube, x-box, and PSX/2 controllers on the USB port. Those are easy to find (I picked it up at walmart, and they still had them last I checked) and are cheap, I paid $10 for mine. Just check Amazon or Ebay for Nintendo 64 to USB adaptor, and you should find many makes and models of the things.
That sounds REALLY far fetched that Wal Mart would have that In Store.
I've seen them carry the ps2 and xbox to usb plugs, it stands to reason that a few stores got deluxe versions that handle more systems. But yeah, it doesn't sound like something walmart would carry at all, I was a bit surprised.
