jc78_2005
colecovision doesnt power up
pretty much sums it up, i know the power supply and rf cable are good to go, when power switch is flipped it does nothing. i know its common for the power switch to be a little flaky, but is it common for the switch to just not work at all? or could my prob be elsewhere? any help is appreciated!
It's the contact paste they used between the switch and the electronics. Mine did the same thing. I took the CV apart (kind of tricky, but not dificult, you just have to work at getting the front cover off), and shot a little WD40 down where the switch meets the electronics beneath it. Worked like a charm.
I use that white DIE ELECTRIC grease,or the white grease that comes in a spray can.
have cleaned the switch very well. retouched solder joints on the switch. clipped and reconnected the power cords where they attach to the board. still nothing.
Do you have a voltmeter or multimeter available? You could then check to see if power is getting beyond the switch to the board.
nope , no voltmeter. i did go ever once again the solder joints where the power cable connects and it fired up , but all i get is like a constant tone. so i dont know, im thinking its goin in the closet lol. thanx for all the info though guys
