candle Posted April 14, 2009 Author Share Posted April 14, 2009 Drac030 has written S: handler for 80 column mode, there is CP/M terminal emulator basing on this handler written by Trub If You limit Yourself to composite video, the You'll see only output from real GTIA chip, VBXE is capable ONLY of RGB output, and yes - it does mean that You may use Atari sc1224 with Your XE. VBXE is transparent to any other expansions, especially PBI devices Using composite output with 640x200 display, or 80 chars text mode would be quite useless, as video bandwidth in that mode is verry limited, it also would add some complexity and cost to VBXE board, and its already highly packed tiny board with components on top and bottom side Quote Link to comment Share on other sites More sharing options...
ataridano Posted April 14, 2009 Share Posted April 14, 2009 Drac030 has written S: handler for 80 column mode, there is CP/M terminal emulator basing on this handler written by Trub Cool! I read a little about the CP/M terminal, but didn't see much mention about the S: handler. I've got an Indus that I'm thinking I might want to add a little memory to..... If You limit Yourself to composite video, the You'll see only output from real GTIA chip, VBXE is capable ONLY of RGB output, and yes - it does mean that You may use Atari sc1224 with Your XE. VBXE is transparent to any other expansions, especially PBI devicesUsing composite output with 640x200 display, or 80 chars text mode would be quite useless, as video bandwidth in that mode is verry limited, it also would add some complexity and cost to VBXE board, and its already highly packed tiny board with components on top and bottom side Time to start looking for a SC1224 I guess, I think the VBXE might make the 8-bit a better computer than the ST So it sounds like the GTIA is still present in the computer still providing the composite output. I know that it would be useless for higher res [though I was surprised that my a1000's composite out gave a nice 80 column screen] just wondering if output went both ways. So is it safe to assume that the RGB output shows 100% of what the GTIA does plus the new features? I'd be interested in one or two depending on the cost (and assuming NTSC isn't a problem). Quote Link to comment Share on other sites More sharing options...
candle Posted April 14, 2009 Author Share Posted April 14, 2009 99.9% - PAL tricks doesn't work (HIP/TIP mode looks a bit grayish, but this is it - nothing more) i'll make photo latter on to visualise this Quote Link to comment Share on other sites More sharing options...
jvas Posted April 14, 2009 Share Posted April 14, 2009 I wonder if there is need for another production run of VBXE graphics adapter for 8 bit atariAlthough names says XE it can be used in any atari having ANTIC/GTIA and FREDDY chips on board for FREDDY-less machines clock divider must me used I want at least one! Quote Link to comment Share on other sites More sharing options...
+rdemming Posted April 15, 2009 Share Posted April 15, 2009 It sounds like a very interesting upgrade. From what I understand ANTIC/GTIA graphics is combined with the VBXE graphics but it is not clear to me how the graphics is combined. Is the video output of the GTIA chip combined with the VBXE video output? Or is the GTIA chip shadowed/emulated in the VBXE boards and is the ANTIC output processed by the VBXE board and combined with the VBXE video output? - ANTIC chip is located on board in DIP2IDC connector adapter, so vbxe can be removed in any point of time - no soldering required What is a DIP2IDC connector? Does it mean you have to de-solder the ANTIC chip first or is it put on top of the ANTIC? Robert Quote Link to comment Share on other sites More sharing options...
+StaxX28 Posted April 15, 2009 Share Posted April 15, 2009 Hi, very interesting by this video board. I want to mount it to my 800XLf (Secam Rose) with internal MyIDE, Warp+ 32-in-1 OS... there is problems of compatibility with that ? Thanks Quote Link to comment Share on other sites More sharing options...
candle Posted April 15, 2009 Author Share Posted April 15, 2009 StaxX28: check clearance with board dimension (in first post) it mounts on offset, so IDC connector (2 rows of pins on picture) is located next to antic rdemming: As You propably know, ANTIC and GTIA have their own internal bus (AN0 to AN2) and VBXE listen to that bus and do what its told to do as it was the GTIA, this bus is 4 times slower than VBXE internal bus, so VBXE has plenty of time to do its own stuff If You don't have the ANTIC chip socketed, then You have to socket it using precise type socket, DIP2IDC adapter is small board with socket and IDC female header where You plug in VBXE - there is no other way around this Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 15, 2009 Share Posted April 15, 2009 didn't see much mention about the S: handler. The S: handler is required by the terminal, so if you're going to play with Indus CP/M, you'll hear about the S: handler sooner or later Btw. I posted some pics generated by Turbo BASIC XL using this handler, and zaxon's film posted here also uses that one. This is basically a toy that allows you to open one of the new modes and draw in 256 colors using standard BASIC commands (like PLOT, DRAWTO, and FILLTO, CIRCLE in TBXL). Currently I am working on a real E: device handler, so that you can use 80-column screen editor to write programs in BASIC, as a DOS console etc. Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted April 15, 2009 Share Posted April 15, 2009 (edited) For the DIP adapter is something like this is what is meant, or is it something more complicated? Forgive me, but this is far outside my knowledge. I'm willing to make the effort, somehow I will put this together..... ; ) Edited April 15, 2009 by AtariNerd Quote Link to comment Share on other sites More sharing options...
candle Posted April 15, 2009 Author Share Posted April 15, 2009 i'll try to visualise this. stay tuned d Quote Link to comment Share on other sites More sharing options...
+rdemming Posted April 16, 2009 Share Posted April 16, 2009 For the DIP adapter is something like this is what is meant, or is it something more complicated? Forgive me, but this is far outside my knowledge. I'm willing to make the effort, somehow I will put this together..... ; ) I believe it is more like the connector/adapter on the left of the picture below. In the adapter you will put a band cable and press the two halfs together to fix the cable. The band cable will go to the VBXE board. Then you remove the ANTIC and plug this thing in the ANTIC socket. Finally you put the ANTIC on top of the connector/adapter. Robert Quote Link to comment Share on other sites More sharing options...
candle Posted April 16, 2009 Author Share Posted April 16, 2009 please, don't belive, or guesss - its not Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted April 16, 2009 Share Posted April 16, 2009 (edited) I believe it is more like the connector/adapter on the left of the picture below. In the adapter you will put a band cable and press the two halfs together to fix the cable. The band cable will go to the VBXE board. Then you remove the ANTIC and plug this thing in the ANTIC socket. Finally you put the ANTIC on top of the connector/adapter. Robert Right or wrong in this instance, it seems like a useful way to modify our boards, making them more flexible for repair or modified use. I had a similar idea today. Edited April 16, 2009 by AtariNerd Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 18, 2009 Share Posted April 18, 2009 sorry for double post :/ anyway commodore 1084 or philips 83something-ii are perfectly capable of displaying vbxe signals, but i'm using lcd tv with scart cable. Component RGB is much more common in the US. Would you expect that it would work with it? -Larry Quote Link to comment Share on other sites More sharing options...
candle Posted April 18, 2009 Author Share Posted April 18, 2009 do You mean Y Pb Pr signals? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2009 Share Posted April 18, 2009 It's different to RGB. YPbPr contains the luma (Y) and Blue/Red differentials. RGB contains the individual colours without alteration. But, some equipment allows the use of either signal type and can be selected via menu. e.g. one of my DTV boxes has SCART out and you can select whether it sends YPbPr or RGB. Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 18, 2009 Share Posted April 18, 2009 (edited) do You mean Y Pb Pr signals? Yes. I guess I should also ask if it could be function with some type of VGA converter? Edited April 18, 2009 by Larry Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted April 18, 2009 Share Posted April 18, 2009 (edited) Unfortunately, direct RGB, the SCART variants (well VGA is not too uncommon on older equiptment), etc never really caught on in NA, except for a few high-end manufacturers. He'll likely need a VGA/ RGB to Component converter. Just realized I've been here for six years.. and what do I have to show for it? Edited April 18, 2009 by AtariNerd Quote Link to comment Share on other sites More sharing options...
candle Posted April 18, 2009 Author Share Posted April 18, 2009 fortunatly, rgb to ybpbr conversion is not that complicated but sorry to hear that, as You're using same chips inside Your tv sets as european folks, and not having those connection outside is really worrying here even worst Crap from china has scart with rgb connected, and ypbpr signals are on a bit higher class equipemnt - a bit only, because most new lcd/pdp panels i've seen has one, even if this is 20" low res (like 640x480 or 800x600) 4:3 low end lcd it might have ypbpr inputs integrated in scart don't worry though there is RGB to VGA adapter in plans, and all needed signals will be provided to convert RGB into something else (composite, s-video, or ypbpr) Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 18, 2009 Share Posted April 18, 2009 fortunatly, rgb to ybpbr conversion is not that complicatedbut sorry to hear that, as You're using same chips inside Your tv sets as european folks, and not having those connection outside is really worrying here even worst Crap from china has scart with rgb connected, and ypbpr signals are on a bit higher class equipemnt - a bit only, because most new lcd/pdp panels i've seen has one, even if this is 20" low res (like 640x480 or 800x600) 4:3 low end lcd it might have ypbpr inputs integrated in scart don't worry though there is RGB to VGA adapter in plans, and all needed signals will be provided to convert RGB into something else (composite, s-video, or ypbpr) Thanks, Candle! -Larry Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2009 Share Posted April 18, 2009 SCART + RGB is only really common in Europe. It's pretty rare here, and is kinda superseded anyway since component and HDMI are becoming almost standard. Quote Link to comment Share on other sites More sharing options...
candle Posted April 18, 2009 Author Share Posted April 18, 2009 its true, but here all devices have at least one, mostly 2 scarts and one or two hdmi ports - and if they have hdmi, they also have ypbpr input, so i don't get it - really Quote Link to comment Share on other sites More sharing options...
candle Posted April 20, 2009 Author Share Posted April 20, 2009 i did a little lame slideshow for vbxe, it lacs almost everything that slideshow should have, but... here it is boot from d1, and load slide.com maybe someone who already got vbxe make a movie from it? users not having vbxe won't see a thing Quote Link to comment Share on other sites More sharing options...
zaxon Posted April 21, 2009 Share Posted April 21, 2009 http://www.youtube.com/watch?v=vH8mgxzwLwI Movie from slideshow. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 21, 2009 Share Posted April 21, 2009 I hope to have a VBXE2 one day. Been following the VBXE discussions since it was just talk. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
