ApolloBoy
The Light Sixer List
Serial #: 548231228
Manufactured by Atari-Wong in Hong Kong
Model: CX-2600 U (PAL)
The paper taped to the shielding is almost too faded to see but it the number is 99 4420020(5) that last number is hard to read as is faded and the tape goes over it.
There is a number on the inside of the lower plastic casing, it is C0 11925-B
Has rear facing speaker slits
Has slot for channel 2 and 3 switch underneath but no switch in it.
Purchased in England by my Father in the early 80s, now resides with me in Brisbane Australia.
Picture of it back when we got it and now, with my original games I had and in the case that we got for it back then too.
10832251_1519696931639562_1072574859_n.j
Edited by Mulletino
  • Like 4
Serial: 83827L
Manufactured in Sunnyvale, striped ribbon cable, no channel select switch, chips dating to early September 1978, heavy shielding.
It's PAL, there's speaker slits, no channel select switch and it also says "25 May" inside it, if that's any good to you. :)
Sears light 6 switch, Dimerco Taiwan, serial nr.81086823
(pretty rare to have a Sears in Europe :D)
I got this one off ebay
though the stupid label keeps peeling off (tried glue stick and "permanent" double sided cello tape so far, whats the trick?)
I recently acquired a Light Sixer -- my first Atari VCS ever! It's in beautiful condition and I'm so happy to finally have one! :lust:
Atari Light Sixer
NTSC
Manufactured in Hong Kong
S.N. 568350128
Has speaker slits
Has channel select switch
Cool thread! Thanks for doing this.
Found a PAL light 6switch "Made in Sunnyvale" with "heavy-parts" - the same as I owned 1979 (UNIMEX-Atari) a rare find in 2017!
post-19659-0-05880600-1493475483_thumb.jpg post-19659-0-58270400-1493475561_thumb.jpg
SN 76332
If you look close you will notice the different border of the switches -not "flat" as the later models.
Atari 2600 Light sixer PAL Sunnyvale Sn 74376 manufactured on 40 8, coming from eBay UK with black screen :(
Edited by Blackgear
Bought one of those repro Chess Piece box from UK, wow, they are of high quality and very well done.
normal_Atari_2600_VCS_Light_Sixer_woody_
Fits the 6 switcher nicely
Edited by high voltage
not one person on here has one w/ a simliar # to mine, do they have tons of sequences or somehing?
no. 475533
Sunnyvale CA
Speaker grills as far as i can tell
Chanel select switch on bottom label and hole w/ no switch
I just got my first 2600 second-hand a couple of weeks ago.
Light Sixer: Sears Tele-games Video Arcade
S/N: 19430 T
Manufactured by Dimerco Electronics in Taiwan
Shell has speaker slots
The paper that was taped to the shielding inside the shell is dated July 16, 1980.
The guy I got it from had no idea if it still worked. The RF switchbox was toast, so I bought an F-type to RCA adapter and tested it out. After adjusting the pots for the RF modulator and color and disassembling/cleaning/reassembling the b/w switch, the unit works perfectly. The outer shell cleaned up very nicely too.
He also included several games, two joysticks (cx-40), and a paddle controller set. Both joysticks look pristine, but one did not register left or down. After taking the joystick apart, the problem was that the wires were very loosely connected to the board. I tried to tighten the clamps on the wires, but they were so brittle they started to break. I decided to just snip off the wire clamps and solder the wires directly to the board inside the joystick. It works perfectly now. The paddle was very jittery, so I disassembled/cleaned/reassembled it and now it works smoothly. I haven't tried the second paddle yet.
Edited by Mr_Tricorder
no. 475533
Sunnyvale CA
so mine i think is from 1978, since its made in sunnyvale?
how come mine is the only one that starts with 475, i swear its light not heavy, i swear its a sunnyvale label, i swear i think i see the "speaker grills", i swear theres no underside channel select switch- do you think mine is from 1980 right before the switched to 4-switch?
Edited by chewy
Light Sixer - Pal - Sunnyvale
Still working too, despite having been stored in my parents garage since I left uni (a long time ago). Needs dusting though.
SN 83245
CO12782U
PAL Sunnyvale Light Sixer, Serial number: 005308.
What year would this be and is it an early one? :)
Edited by adam1977
Forgot to add picture...
Light Sixer
Manufactured for Atari by DIMERCO ELECTRONICS IN TAIWAN
Model No. CX-2600
S/N : 81669067
Green Label
Channel Select hole with a switch inside
