flashjazzcat
30 Pin SIMM upgrade
I've got an STE on the way with 1MB fitted (presumably 4x256K SIMMs). I want to buy 4x1MB SIMMs for it, but is there anything to worry about when choosing modules? Do they HAVE to be 70ns, non-parity? I read somewhere that the STE isn't picky about which SIMMs you use (as long as they're all the same, I imagine).
Almost anything will work so long as they are the same and are Fast Page Mode SIMMS, NOT EDO.
That's great - thanks for the info! :)
520STE just arrived, with 1MB (4x256K) of RAM. In reasonable condition but a little green around the gills, so I'll be doing the peroxide treatment on it. Pretty nice for £6.49!
Edited by flashjazzcat
Wow! Not bad at all! STEs are fairly rare in the states. I soldered a 4mb 72 Pin Simm (thanks to Techie Allison's great instructions) into my 520ST but I Still wish I had the other enhancements of an STE.
Very good deal, glad you snagged it!
@puppetmark; do you have a link to the instructions?? I have a 520ST that would love to be upgraded, and I am a sucker for a cute machine. Especially when it begs.
This has indeed proved to be one very sweet purchase indeed. :D It was quite green when it arrived yesterday, but needed only two hours' peroxide treatment to get it looking like this:
Compare with the SFTM (at the top of the picture) which is still yellow after eight hours treatment:
Anyway, I'm wondering what these jumpers are on the motherboard. Normal? (note piggy-backed 74LS164):
And the only fly in the ointment (DMA chip needs replacing):
what is the procedure for cleaning up the casing if it's yellowed? :twisted:
Described here and on the wiki here.
Things went wrong when I tried this on the STFM (the plastic bloomed and the end results generally weren't startling), but the STE has been a dream. Note that this time I used plain 40vol peroxide gel: no additives, Oxy, thickener or anything else.
Curious to know what that mod is...
Try here:
http://www.logicsays.com/atari/72simm/
Some of the connection points for the 520ST are in different locations than the STFM but they are all there. I removed all the RAM chips from the motherboard and used the space for the SIMM. Also, you need a fast page SIMM and not EDO.
Try here:
I have some fastpage ready for it, pulled from a pc. Thanks!
Nathan
Try here:
Nathan
Good luck, Its a lot of soldering but well worth it. Allison's advice not to do too much at a time is good advice. I think it took me about 2 weeks till it was all done.
Can anyone tell me what those jumper leads are for? :)
It appears that this is a baud rate enhancement Mod. it basically uses a shift register to double the standard baud rate of the ST serial port. I think it requires the use of a CPX module to take advantage of it. There were several versions of this kind of mod and I am not sure which one this is. I have instructions for a couple of these and it doesn't quite match.
*EDIT*
After some more research, it appears this might be a factory fix of some kind for this revision of the STE. This thread shows this chip on the Atari STE schematics yet there isn't a place for it on the motherboard. So this may have been added to later motherboard revisions:
http://www.atari-forum.com/viewtopic.php?f...506&p=21537
Edited by puppetmark
*EDIT*
Most definitely done in the factory. Just received a stock STe a few days ago and after opening it, it had the same leads. Curious what it fixed, if anything.
Yay! Just received four 1MB SIMMs in the post bought for £1.50 from ebid (useful cheque-only alternative to ebay with much computer stuff on it). Popped them in the STE and they work perfectly. Now I have TOS 2.06, 4MB, good DMA chip... just waiting for Satandisk and am good to go! :D
