Adamant Posted June 3, 2009 Share Posted June 3, 2009 Hello. While spending some time in the US a while ago, I picked up a Colecovision system with some games. The system worked perfectly on my American TV, but having brought it back to Europe, I can't get it to work. I get the signal, but it jumps really bad and makes it impossible to play. All my other American and Japanese consoles work well. Any idea what I can do to get it working? Quote Link to comment Share on other sites More sharing options...
youki Posted June 3, 2009 Share Posted June 3, 2009 Hello.While spending some time in the US a while ago, I picked up a Colecovision system with some games. The system worked perfectly on my American TV, but having brought it back to Europe, I can't get it to work. I get the signal, but it jumps really bad and makes it impossible to play. All my other American and Japanese consoles work well. Any idea what I can do to get it working? It could be a power supply problem. Do you use the original powersuplly with a converter or do you use the european power supply with your US Colecovision? And are you sure you TV is multistandards NTSC / PAL (/SECAM) ? Quote Link to comment Share on other sites More sharing options...
mimo Posted June 3, 2009 Share Posted June 3, 2009 Probably a problem with a PAL tv trying to use an NTSC signal. Some of these older systems do not conform to modern standards. Can you try running it through a video recorder or try a different tv? RF is usually a problem, in the past I have resorted to s-video mods for my NTSC consoles. Modern TVs seem more forgiving on AV/s-vid than RF If you suspect the PSU I have a euro one that I may be tempted to sell Quote Link to comment Share on other sites More sharing options...
Adamant Posted June 3, 2009 Author Share Posted June 3, 2009 It could be a power supply problem. Do you use the original powersuplly with a converter or do you use the european power supply with your US Colecovision? And are you sure you TV is multistandards NTSC / PAL (/SECAM) ? I use the original power supply with the same converter I use for my other American consoles. My TV is multistandard, yes - my other foreign consoles work fine. Probably a problem with a PAL tv trying to use an NTSC signal. Some of these older systems do not conform to modern standards. Can you try running it through a video recorder or try a different tv?RF is usually a problem, in the past I have resorted to s-video mods for my NTSC consoles. Modern TVs seem more forgiving on AV/s-vid than RF If you suspect the PSU I have a euro one that I may be tempted to sell I will look into this, thanks. Quote Link to comment Share on other sites More sharing options...
Spector Posted June 5, 2009 Share Posted June 5, 2009 I use the original power supply with the same converter I use for my other American consoles. My TV is multistandard, yes - my other foreign consoles work fine. I'm currently waiting on a Colecovision from America and am wondering about what converter to get - could you tell me the name of the converter you are using? Quote Link to comment Share on other sites More sharing options...
mimo Posted June 5, 2009 Share Posted June 5, 2009 I got this one which works fine Quote Link to comment Share on other sites More sharing options...
