Heaven/TQA Posted December 20, 2013 Share Posted December 20, 2013 Great 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted February 5, 2014 Author Share Posted February 5, 2014 2014-02-05 New zero installation distribution of WUDSN IDE for 32-bitI received requests to also provide a 32-bit version of the zero installation distribution. And after figuring out how I can do that without doing everything twice, it's ready for download: wudsn-ide-win32.zip. I have no real 32-bit hardware to test it, so please provide feedback. Thanks also to Timothy, Kevin and Fredrick for the feed und using WUDSN IDE on Mac OS X. I have extended to FAQs accordingly.New FAQs: Why are is the "Assembler" section not visible in the preferences?If the WUDSN IDE specific sections and features are not visible after a successful installation, you are probably using anoutdated Java version. This seems to be a common problem on Mac OS X. Make sure you have Java 1.7 installed and that Eclipse is started using that version. Java 1.6 is out of maintenance since 2013/02. 4 Quote Link to comment Share on other sites More sharing options...
CannibalCat Posted February 6, 2014 Share Posted February 6, 2014 Thank you so much for this! Been using both the 32-bit and 64-bit with no issues so far. 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 14, 2014 Share Posted February 14, 2014 Hi Peter... I reinstalled Eclipse but it does not work. I have Mavericks 1.9.1 and Java 1.7 and installed Eclipse Standard/SDK Version: Kepler Service Release 1 Build id: 20130919-0819 WUDSN Base 1.6.5 and WUDSN IDE 1.6.5 are installed via the Install new software feature and the JAR files are in the plugins folder. But none of the features are visible (like assembler in preferences etc). Ideas? Quote Link to comment Share on other sites More sharing options...
+JAC! Posted February 14, 2014 Author Share Posted February 14, 2014 Most likely Java 1.7 is not acually used when Eclipse started. Please post the "<workspace>\.metadata\.log" file. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 Most likely Java 1.7 is not acually used when Eclipse started. Please post the "<workspace>\.metadata\.log" file. there is no .log? or how can I access the file in OSX? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 (edited) clean install on a macbook air with 1.9.1 does not work either... when installed Eclipse it told me that it needs to download Java 6 SE from Apple... which my iMac did not prompted. Does anybody had it running on OSX Mavericks? as I want to switch from my old Samsung NC10 towards modern dev plattform. Edited February 15, 2014 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 Eclipse Juno 4.2.2 does not work either... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 clipse.buildId=4.3.0.M20130911-1000 java.version=1.6.0_65 java.vendor=Apple Inc. BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE Framework arguments: -product org.eclipse.epp.package.standard.product -keyring /Users/heaven6502/.eclipse_keyring -showlocation Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -keyring /Users/heaven6502/.eclipse_keyring -showlocation !ENTRY org.eclipse.core.net 1 0 2014-02-15 10:05:10.497 !MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences !SESSION 2014-02-15 10:07:23.967 ----------------------------------------------- eclipse.buildId=4.3.0.M20130911-1000 java.version=1.6.0_65 java.vendor=Apple Inc. BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE Framework arguments: -product org.eclipse.epp.package.standard.product -keyring /Users/heaven6502/.eclipse_keyring -showlocation Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 well.... it seems major issue with Eclipse... http://stackoverflow.com/questions/17584350/eclipse-still-using-java-6-as-jre-on-mac-osx Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 15, 2014 Share Posted February 15, 2014 ok... upgraded my NC10 to Win 7 and installed a SSD... now installing your zero installation archive... hopefully I am prepared now for Revision Party need to code stuff... would be good if someone can explain me how he got run the IDE on OSX and 1.9.1 plus Java 7... as most of the coding machines at home are Macs... NC10 is the old one of mine Quote Link to comment Share on other sites More sharing options...
+JAC! Posted June 1, 2014 Author Share Posted June 1, 2014 (edited) Since I got a lot of feedback from Mac Users that getting Java 1.7 up-an running is a pain there, I have created reworked WUDSN IDE and the build process a little. The next version will be compatible with JRE 1.6 again. I just successfully tested on Windows 8/x-64 with JRE 1.6-45. But since I don't even have that (my 10.5.5 can at best run JRE 1.5) I'll need some volunteers for testing on Mac OS. Edited June 1, 2014 by JAC! Quote Link to comment Share on other sites More sharing options...
spookt Posted June 3, 2014 Share Posted June 3, 2014 Since I got a lot of feedback from Mac Users that getting Java 1.7 up-an running is a pain there, I have created reworked WUDSN IDE and the build process a little. The next version will be compatible with JRE 1.6 again. I just successfully tested on Windows 8/x-64 with JRE 1.6-45. But since I don't even have that (my 10.5.5 can at best run JRE 1.5) I'll need some volunteers for testing on Mac OS. I can test Jac. My MBP is running the latest and greatest Mavericks. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted June 11, 2014 Author Share Posted June 11, 2014 (edited) 2014-06-11 WUDSN IDE update 1.6.6 released A new version of the IDE is available via the update site and as zero installation download. When I started recording the 7th part for the Programming the Atari XL/XE video tutorial I found that the graphics editor and hex editor are not as usable as they should be. So I decided to implement some improvements and fixes first. At the same time quite a number of Mac OS X users reported issues with installing Java 1.7 on their machines, making it difficult for them to use WUDSN IDE. Hence I invested quite some time in reworking the code, so it runs properly also with "good old" Java 1.6. Thanks to spookt and flashjazzcat for testing. General This version can run with Java 1.6 (JRE/JDK), so also a vanilla OS X Snow Leopard (10.6), Lion (10.7), Mountain Lion (10.8.x) and Mavericks (10.9) can run it out of the box. Improved handling of relative file paths in source and binary includes. Graphics Editor:All buttons now have icons with tooltips. Enabling of input fields and change detection is consistent now. Typing into any file path of text field updates the dirty indicator immediately, so you see if there are unsaved changes. Toggling the "Shrink" and "Zoom" buttons updates image size correctly now. Line numbers have been added in the script editor. The line with the cursor is highlighted in the script editor. New default converter scripts for converting character sets have been added. Error messages in case of script errors have been improved and the cursor is positioned to the error location in the source. Hex Editor: Performance when opening a file with the HexEditor improved by a factor of 10 to 20. Now a file with 1 MB is opened in far less than 1 second. Allowed maximum file size has been increased to 8 MB. ATR files with 256 bytes boot sectors are now handled correctly becasue they are rather common even though they violate the ATR specification ATR files created from single Atari COM files, so called "k-files", are now detected automatically. For them not only the sectors of the ATR are displayed, but also the segments of the contain Atari COM file are displayed in the outline and the editor. C64-PRG files are now detected automatically. Edited June 11, 2014 by JAC! 5 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 11, 2014 Share Posted June 11, 2014 Increasingly superb. Thanks Peter! Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 22, 2014 Author Share Posted July 22, 2014 (edited) Sneak preview. Started out as a hack yesterday and (again) turned into an underestimated amout of work. But looks cool, I think. The parsing of the compiler output was partly already there in the past, now it starts making sense. Edited July 22, 2014 by JAC! 3 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted July 22, 2014 Share Posted July 22, 2014 Peter... Now you are telling me that WUDSN works with mavericks and I just bought new/old win 7 laptop for coding as my nc10 gets old... Good to see OSX ports and love to see next version Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 22, 2014 Share Posted July 22, 2014 Eclipse works on Windows, Linux and Mac, and so (it follows) does WUDSN IDE. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 22, 2014 Author Share Posted July 22, 2014 (edited) I think Karolj refers to the fact that it is now runs on Mavericks without installation of Java 1.7 (again). Even I failed to make Java 1.7 work there, so I decided to rather re-implement a set of JDK 1.7 proxy classes and go for Java 1.6 compatibility again than entering "installation hell". Edited July 22, 2014 by JAC! 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 22, 2014 Share Posted July 22, 2014 I think Karolj refers to the fact that it is now runs on Mavericks without installation Java 1.7 (again). Ah - thanks Peter, and sorry Karolj! Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted July 23, 2014 Share Posted July 23, 2014 Yup. I never got WUDSN run on Mavericks... so glad I can update now and see if it works on my Macbook Air Quote Link to comment Share on other sites More sharing options...
popmilo Posted July 27, 2014 Share Posted July 27, 2014 Hi Peter,wonder if you can maybe help ? I have Wudsn 1.6.5 installed and just tried to update it and it failed. Maybe it has something to do with my Eclipse updated recently to Luna 4.4 release ?Here is the error: An error occurred while collecting items to be installed session context was:(profile=epp.package.standard, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). No repository found containing: osgi.bundle,com.wudsn.ide.asm,1.6.6 No repository found containing: osgi.bundle,com.wudsn.ide.asm.compilers,1.6.6 No repository found containing: osgi.bundle,com.wudsn.ide.asm.compilers.test,1.6.6 No repository found containing: osgi.bundle,com.wudsn.ide.base,1.6.6 No repository found containing: osgi.bundle,com.wudsn.ide.dsk,1.6.6 No repository found containing: osgi.bundle,com.wudsn.ide.gfx,1.6.6 No repository found containing: org.eclipse.update.feature,com.wudsn.ide.feature,1.6.6 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 27, 2014 Author Share Posted July 27, 2014 Maybe it has just forgotten about the update site. Check if "http:// www.wudsn.com/update" is there in the "Available Sites". If that doesn't help just try to uninstall the WUDSN IDE feature and install it again from the update site www.wudsn.com/update explicitly. 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted August 8, 2014 Author Share Posted August 8, 2014 (edited) With the help from Mark Simonson (creator of the Atari TTF fonts), one of the long planned features might finally become reality: True Atari Font in the Hex Editor with all special and inverse characters. Including the choice, between ASCII, ATASCII and screen code. Edited August 8, 2014 by JAC! 7 Quote Link to comment Share on other sites More sharing options...
retro_otaku Posted August 18, 2014 Share Posted August 18, 2014 I just wanted to say thanks for WUDSN. I just started to learn how to program the Atari this weekend and I got my first assembly program to run in about half an hour. So, thanks! 3 Quote Link to comment Share on other sites More sharing options...
