Herbarius #1 Posted June 12, 2009 Hello, I just aquired the 32 in 1 Game Cartridge for the Atari 2600. It works, but I have noticed the colors in most games are quite off... E.g. The Court in Activision Tennis is blue, not green. Could this be the NTSC version (I'm from Germany, therefore normally it's PAL)? I thought this cartridge was only released in Europe, so why should there be a NTSC version at all? Or maybe colors have been altered in some of the games like they altered graphics in some? I can't test it in Stella because it won't work (you can only play Fun with Numbers). Or could something be wrong with the cart after all? I also noticed the picture wasn't quite as clear as I'm used to from other games, maybe this has something to do with it/could help you determine what's with the colors. Also the cart, when in the VCS, seems to be veeery sensitive to touch, one little bump and it's Hello there, colored bars! Quote Share this post Link to post Share on other sites
+Omegamatrix #2 Posted June 12, 2009 Your cart is normal in that the screen is blue in the Atari 32 in 1. I've never looked at the .bin, but usually this happens when a game gets converted from one format (NTSC,PAL,etc..) without fixing the colors. The regular PAL version of Tennis does have correct colors (green court). Sorry your cart is so sensitive to the touch. Quote Share this post Link to post Share on other sites
Herbarius #3 Posted June 12, 2009 (edited) Thanks for you quick reply. Now I know they propably just have been lazy converting the games... maybe it was kind of a rush job May I asked how you managed to get it emulated? Have you made modifications to the ROM file or sliced it into the seperate games somehow? Sorry your cart is so sensitive to the touch. Any suggestions on how I could improve that? Edited June 12, 2009 by Herbarius Quote Share this post Link to post Share on other sites
+stephena #4 Posted June 12, 2009 Hello,I just aquired the 32 in 1 Game Cartridge for the Atari 2600. It works, but I have noticed the colors in most games are quite off... E.g. The Court in Activision Tennis is blue, not green. Could this be the NTSC version (I'm from Germany, therefore normally it's PAL)? I thought this cartridge was only released in Europe, so why should there be a NTSC version at all? Or maybe colors have been altered in some of the games like they altered graphics in some? I can't test it in Stella because it won't work (you can only play Fun with Numbers). Or could something be wrong with the cart after all? I also noticed the picture wasn't quite as clear as I'm used to from other games, maybe this has something to do with it/could help you determine what's with the colors. Also the cart, when in the VCS, seems to be veeery sensitive to touch, one little bump and it's Hello there, colored bars! I haven't really played with this BIN very much in Stella, but I know it isn't working correctly. Is there any documentation on how the cart should work (ie, how do you select the multiple games)? Quote Share this post Link to post Share on other sites
Herbarius #5 Posted June 12, 2009 Is there any documentation on how the cart should work (ie, how do you select the multiple games)? Yes, normally you would switch the Atari off and on again, and it will be a different game. There is some kind of "register" in the cartridge that gets incremented each time you power it up, so this is possible. Somewhere I found a description written by someone who replaced this "register" with DIP switches, so he could select the games with them. Quote Share this post Link to post Share on other sites
+Omegamatrix #6 Posted June 12, 2009 (edited) May I asked how you managed to get it emulated? Have you made modifications to the ROM file or sliced it into the seperate games somehow? The cart's been dumped before. Here it is: 32_in_1.zip Edit: and yes the games have been split so they would work in an emulator. Any suggestions on how I could improve that? You might try cleaning the contacts on the cartridge, or your consoles port itself. Other then that there is not much you can do except try the cartridge in a different 2600, if you have one. I haven't really played with this BIN very much in Stella, but I know it isn't working correctly. Is there any documentation on how the cart should work (ie, how do you select the multiple games)? I believe it switches games each time it's powered on. Is that correct Herbarius? Edited June 12, 2009 by Omegamatrix Quote Share this post Link to post Share on other sites
Herbarius #7 Posted June 12, 2009 (edited) The cart's been dumped before. Here it is:Attached File 32_in_1.zip ( 59.26K ) [...] I believe it switches games each time it's powered on. Is that correct Herbarius? Yes, that's correct. However, in Stella you can't do this (or can you?), that's why I asked how you got it emulated. EDIT: Sorry, didn't download the file and check what it is. It's a seperate BIN for every game. What I knew was a single .bin file which would only give you Fun with Numbers, nothing else. Edited June 12, 2009 by Herbarius Quote Share this post Link to post Share on other sites
+Omegamatrix #8 Posted June 12, 2009 The cart's been dumped before. Here it is:Attached File 32_in_1.zip ( 59.26K ) [...] I believe it switches games each time it's powered on. Is that correct Herbarius? Yes, that's correct. However, in Stella you can't do this (or can you?), that's why I asked how you got it emulated. The file I posted above has all the games split individually. I edited my post above, as I missed that question the first time. Quote Share this post Link to post Share on other sites
YOK-dfa #9 Posted June 12, 2009 Any suggestions on how I could improve that? Throw your cart away and get a new one. 32-in-1 is probably the most common Atari 2600 PAL cart... Quote Share this post Link to post Share on other sites
Thomas Jentzsch #10 Posted June 12, 2009 The 32in1 card is a thrown together piece of garbage production wise. E.g. they often used badly hacked NTSC games instead of the correctly converted PAL versions. Quote Share this post Link to post Share on other sites
+stephena #11 Posted June 12, 2009 The cart's been dumped before. Here it is:Attached File 32_in_1.zip ( 59.26K ) [...] I believe it switches games each time it's powered on. Is that correct Herbarius? Yes, that's correct. However, in Stella you can't do this (or can you?), that's why I asked how you got it emulated. Well, if that's all there is to it, I'd just need to find what register is storing this value, and have Stella update it every time the ROM is loaded. The latter part is quite easy; figuring out where it's stored is the hard part. Quote Share this post Link to post Share on other sites
Eckhard Stolberg #12 Posted June 12, 2009 The cart's been dumped before. Here it is:Attached File 32_in_1.zip ( 59.26K ) [...] I believe it switches games each time it's powered on. Is that correct Herbarius? Yes, that's correct. However, in Stella you can't do this (or can you?), that's why I asked how you got it emulated. Well, if that's all there is to it, I'd just need to find what register is storing this value, and have Stella update it every time the ROM is loaded. The latter part is quite easy; figuring out where it's stored is the hard part. It's just a counter in the cartridge for the higher address line which is buffered by a capacitor. When you turn the console off for a while, the cartridge always starts with the first game. If you really want to support the 32-in-1 cart with it's own bankswitching scheme, you could simply load the next 2K part of the ROM image into the VCS memory map every time someone hits CTRL-R to reload the ROM in Stella. Quote Share this post Link to post Share on other sites
+stephena #13 Posted June 12, 2009 The cart's been dumped before. Here it is:Attached File 32_in_1.zip ( 59.26K ) [...] I believe it switches games each time it's powered on. Is that correct Herbarius? Yes, that's correct. However, in Stella you can't do this (or can you?), that's why I asked how you got it emulated. Well, if that's all there is to it, I'd just need to find what register is storing this value, and have Stella update it every time the ROM is loaded. The latter part is quite easy; figuring out where it's stored is the hard part. It's just a counter in the cartridge for the higher address line which is buffered by a capacitor. When you turn the console off for a while, the cartridge always starts with the first game. If you really want to support the 32-in-1 cart with it's own bankswitching scheme, you could simply load the next 2K part of the ROM image into the VCS memory map every time someone hits CTRL-R to reload the ROM in Stella. Of course; I realized this just after I typed the response. I was thinking of finding a register in the ROM itself, when I realized that it's in another piece of hardware in the cart. It has nothing to do with patching the ROM code at all. Quote Share this post Link to post Share on other sites
+stephena #14 Posted June 12, 2009 (edited) OK, proper support for this is now added to Stella, which will be included in the next release. It works as Eckhard suggested above. Starting the ROM always defaults to the first game (as if it's been unplugged for some time), but while the ROM is loaded, continually reloading (with Ctrl-r) will cycle through each game, simulating an off-on toggle. Edited June 12, 2009 by stephena Quote Share this post Link to post Share on other sites
+stephena #15 Posted June 14, 2009 Now that Stella has native 32in1 support, I started looking at the other multicarts. I have three 4in1 (16K total, 4K per game) and one 8in1 (64K total, 8K per game). In almost all cases, manually splitting the ROM produces binaries that are valid (except for two of the 8K pieces in the 8in1). So I'm looking to do this automatically in Stella. My question is, how do these carts work on a real system? Do they use a power-cycle to switch through each game, just like the 32in1? I can go ahead and have them operate like the 32in1, but it would be nice to know exactly how they work on a real system. Quote Share this post Link to post Share on other sites
+Omegamatrix #16 Posted June 15, 2009 Now that Stella has native 32in1 support, I started looking at the other multicarts. I have three 4in1 (16K total, 4K per game) and one 8in1 (64K total, 8K per game). In almost all cases, manually splitting the ROM produces binaries that are valid (except for two of the 8K pieces in the 8in1). So I'm looking to do this automatically in Stella. My question is, how do these carts work on a real system? Do they use a power-cycle to switch through each game, just like the 32in1? I can go ahead and have them operate like the 32in1, but it would be nice to know exactly how they work on a real system. Alot of them use dip switches, it depends on the multicart. With the dipswitches if it's a 4 in 1 you have 2 dipswitches to give you the four valid choices. Quote Share this post Link to post Share on other sites
tremoloman2006 #17 Posted June 15, 2009 Was/Is there a NTSC release/conversion of this available? Quote Share this post Link to post Share on other sites
Thomas Jentzsch #18 Posted June 15, 2009 Was/Is there a NTSC release/conversion of this available? Not me, no way! Quote Share this post Link to post Share on other sites
+Omegamatrix #19 Posted June 15, 2009 He's being sarcastic, of course. Thomas did you make it more authentic by erasing the logos out of Space Jockey, Checkers, Freeway, Fishing Derby, Tennis, Skiing, Boxing, and Laser Blast? Also did you make the sprite hacks of Freeway and Fishing Derby? I started to make this conversion myself when I saw your "cryptic" post. I'm not going to do this if it's already been done. Quote Share this post Link to post Share on other sites
tremoloman2006 #20 Posted June 15, 2009 If it has been done I couldn't find it under the conversions page. I did look before I asked! http://www.atariage.com/software_conversions.html Quote Share this post Link to post Share on other sites
Thomas Jentzsch #21 Posted June 15, 2009 He's being sarcastic, of course. No, not this time. Sorry. Quote Share this post Link to post Share on other sites
+stephena #22 Posted June 19, 2009 Hello,I just aquired the 32 in 1 Game Cartridge for the Atari 2600. It works, but I have noticed the colors in most games are quite off... E.g. The Court in Activision Tennis is blue, not green. Could this be the NTSC version (I'm from Germany, therefore normally it's PAL)? I thought this cartridge was only released in Europe, so why should there be a NTSC version at all? Or maybe colors have been altered in some of the games like they altered graphics in some? I can't test it in Stella because it won't work (you can only play Fun with Numbers). Just an FYI that I just released Stella 2.8.1, which includes a fix for this. Basically, I added 32in1, 8in1 and 4in1 as bankswitching schemes, with the reload ROM action (Control-r) tied to switching between each ROM. So you open the ROM, and it always starts at game 0. Then pressing Control-r multiple times switches to each game in sequence. You can get it from the 2.8.1 thread. Quote Share this post Link to post Share on other sites
