Sign in to follow this
w1k
How to install SIO2SD to Atari
Hello,
can you help me with install sio2sd to my atari?
Some tips or tricks
Thank you
Photo - http://podstromami.com/atari800xe-320kb/PIC_0076.jpg.php
You need to connect the header pins to the correct points on the SIO bus... Either by connecting dirrectly to the legs (inside the Atari) OR by making a cable with SIO plug on one end...
SOmeone else will probably chime in with the pin outs before I get to it... but if not I'll follow up in a couple hours
