Main Code revealed....sort of.
Gorf
What happens if each rule is individually broken?
It will fail every time. There is no room for error. Follow the rules and
the code never fails. Misalign one thing and it's 'game over man'.
Again the only exception is to rule #5. Owl says you can use certain single
register instructions as the first NOP. I think you need to make sure you are
not using a register that has been recently used before the jump. Owl can
clarify that though. I have never tried this yet so I can't honestly comment.
Welp, there you have it Seb. now think for a moment how difficult it would be to track
every address by hand with out having a tool like SMAC.
I can tell you, if I had SMAC, I could have written Surrounded! in a day or two.
Instead I had to globalize EVERY jump placement and destination and add nop's to
pad them to the proper alignment. I then would have ALN output a list of symbols
to track those addresses. Night mare indeed.
Its true, i routinely break rule 5. I'd have to check if its a recently modified reg, i would suspect not, its always been single reg operand commands too.
In addition as i mentioned on JSII theres and extra safeguard recommended to be used when jumping to/from local/main. There's a particular instruction which is known to affect pre-fetch and which somehow helps to align the pipeline. I've found it helpful to use this immediately prior to the Jump
In regards how i discovered the methods too, it was even less methodical than gorf, i found out completely by mistake because i wrote some code on the GPU which i transferred to the DSP, but i switched back and forth a bit and suddenly one day i noticed it was running slower, i looked for why and suddenly i saw that it was the GPU running from DSP Ram - from there it was possible to move it to main ram and from there i set up a few guidelines for myself and then just tried trial and error - there was a lot of stumbling about though and Gorf's rules are far more rigorous and useful than the ones i originally set myself.
Edited by Atari_Owl
Yep, tricky little beast that Jag is.
Nonetheless: Congratulations to Seb for sticking with me and figuring it out on his own.
Rdemming got it on JSII as well. Nice job guys!
Well, we got some help.
But still, I am happy to have guessed the rules correctly.
Thanks for having been an oracle.
Edited by SebRmv
Now let's see you put it to some good use. :)
I am also glad that some of my (few) assumptions about the cause of the problems seem to have been correct :)
The great thing about these bugs are they are consistant. If it were truly a random fail
you would never be able to workaround it this easily....or at all for that matter. Now try
to write a useful app WITHOUT SMAC/SLN and you'll see it's not easy. Most of the
projects I have for the Jaguar are main coded written by hand. I suppose I could convert
them all over but Im too far in to too many. There are also still issues with SMAC/SLN that
yet need rectifying as well, but for the most part it will still work. In fact SubQMod is doing
that with Donkey Kong as we speak. (Easy now Walter.... ;) )
Im not sure how Owl feels about using SMAC as I am sure he did most if not all the GPU
main coding in his app by hand as well. I no for my self, If I were one of you, I'd be happy
with SMAC and not really even care why main code works or not. ;P
Edited by Gorf
Hi I use SMAC sometimes, but Gorf is right, since my main code was already done by hand i haven't converted it to use the SMAC macros, though i really should as there are definitely more Main code sections to be done.
Mine is of the form though of a framework which runs in main and which calls subroutines which run from local.
Yes I imagine perfectly the nightmare it should be to write this correct by hand.
Actually, I thought it was possible to write madmac macros and conditionnals to circumvent the bug but unfortunately, since it is a one-pass assembler, it cannot work completely.
Fortunately, now there is SMAC!
Thanks again for this thread.
Hopefully it does illustrate why it was thought that SMAC would be a more useful method to enable it to be used than just explaining - since even explained its irritatingly picky... and labour intensive
Following the rules is what allows it to work but keeping track of everything by hand is quite a pain in the hind quarters.
My guess is it starts to get unpredictable when you try using some of those instructions after a jump.
  • 2 months later...
  • 8 months later...
I'll post this in the programming section as well.
To jump around in main RAM.....
1 ) Within a 256 byte page boundary...ie..The address range of a page starts at $XXXXXX00 and ends at $XXXXXXFF.
a ) JR can jump from anywhere to anywhere within its range and inside the page.
b ) JUMP must be aligned on a long address and jump to a word offset long address...ie...adresses ending in 2,6,A and E
2 ) From one 256 byte page to another
a ) JR (if it can reach the destination) can jump from anywhere but MUST land on a long aligned address to the other page.
b ) JUMP must be aligned on a long address and jump to a long aligned address...ie...adresses ending in 0,4,8 and C.
3 ) To jump from main to local or local to main(from one way to the other is the same).
a ) The JUMP must be long aligned. The desination must be long aligned. However, phrase aligment is reccomended for saftey.
b ) Preceed the JUMP with a MOVEI not related to the JUMP register(although I've had success with, Owl says its not safe.)
c ) Obviously JR can not reach main RAM from the GPU local address so it will not work for this
JR/JUMP must be followed by 2 NOP's OR 1 single register instruction not associated with anything recent and then NOP.
I do not think the single instruction and 1 NOP will work between local to main
or main to local but I'll leave that up to Owl to answer.
Hello Gorf!
Thanks for the quick response!
Kind regards
Matthias
PS: I think we (all) should keep the discussion of this topic here, while using the sticky thread in the Programming Section for the results of the discussion (if there are any new results).
Hello Gorf!
Kind regards
Matthias
My pleasure Matthias...but I fear you might be the only one outside of a handful that ever even attempt to use
the main code workaround. Lots of people like to talk the talk and bitch and moan that no one likes to share
this and that, but I have found out that the reason for this is those people are usually not coders and are
hoping some other coder makes use of it for their own greedy selfish desires, forgetting the hard work that
goes into these projects.
Its good to see the rules laid out again :)
To comment on specifics...
  • The preceding MOVEI can be the jump register or an independent register - i often use the jump register.
  • I've also used the single register instruction plus 1 NOP for jumps between local & main.
Even following the guidelines there can STILL be unexpected difficulties with Main/Local jumps if the jump to/from occurs many times in quick succession - try to space out the jumps as much as possible. My own code only jumps between main & local <5,000 times a second atm.
Edited by Atari_Owl
Hopefully SubQ's assembler macros handle this more or less automatically.
Someone needs to put it through its paces.
Some of have and there are still bugs where it blows up but I think SubQ mod is moving on to the N64
so I see little hope of it ever being completed.
I think SubQ mod is moving on to the N64 so I see little hope of it ever being completed.
That would truly be a great pity :(
Well I do believe the source is available to SLN and SMAC so that's some hope. Then again,
Who knows what direction SQM will take in his escapades. I wish him well either way. He's
a good dude.
Hello Gorf!
Even if it'll disappoint you, i am afraid it will take a while before i will start using the given RISC-Execution-In-Main-RAM-rules. I probably would try it out immediately, and i am a master of adding NOPs to code sequences, but the necessary adress-alignments (with differences for page/non-page jump) seem to be a too high hurdle for me.
But could you or AtariOwl (or who else has the necessary experience) please add some info about the speed advantages or disadvantages of running RISC-code in main RAM to the sticky thread in the Programming section? Thanks in advance!
Kind regards
Matthias
Hello Gorf!
Kind regards
Matthias
Main code ram execution can run almost as fast as in the local or not depending on the bus activity. In its worse case
it is by far faster then the 68k. The idea is to run your AI out in main and do all your drawing in local in that order.
If you use tight loops you will notice a serious drop inperfromance so it is recommended to unroll loops so that each
iteration of a loop from begining to end has several instructions between them and the loop jump. If you abide by these
quidelines you will increase your perfomance greatly over using the 68k by leaps and bounds.
Hello!
For relative jumps (JR):
Those jumps are calculated on the processor counter (PC) being already incremented,
so what if a JR is the very last command in a page?
Is it then a page-miss if the jump is backwards? (based on the PC)
Or is it a page-miss if the jump is forwards? (based on the address where the JR is placed)
Kind regards
Matthias
