Poopopyo #1 Posted July 14, 2009 does anybody know what games are compatible with it? And what does the door on the front of the module do? Quote Share this post Link to post Share on other sites
JamesD #2 Posted July 14, 2009 I'm sure there is a complete list on one of the TI-99 sites. The most popular one that uses it is probably Parsec. It seems to me the front door allowed plug in ROMs with different voices. I'm not sure if any of those actually appeared. Quote Share this post Link to post Share on other sites
S1500 #3 Posted July 14, 2009 The door did nothing. It was planned for plug-in roms, probably like the Speak & Spell. But I see no sockets inside the door. The games: Parsec(duh) Star Trek Moon Mine Okay there has to be others. Quote Share this post Link to post Share on other sites
Dan Iacovelli #4 Posted July 14, 2009 there was also Alpine I believe that used the speech also don't forget about Extended basic cart which will allow you to program games that will use speech which I loved adding to my own games I did. Quote Share this post Link to post Share on other sites
Tempest #5 Posted July 14, 2009 I believe Lasso and Star Trek also use it. Tempest Quote Share this post Link to post Share on other sites
darthkur #6 Posted July 14, 2009 Some versions of Super Demon Attack did as well. Here's where you can find a copy of it that does for certain plus Lasso and a whole lot more: http://tigameshelf.net/asm.htm Quote Share this post Link to post Share on other sites
Wickeycolumbus #7 Posted July 14, 2009 But I see no sockets inside the door. IIRC, only the very early units had the sockets. Quote Share this post Link to post Share on other sites
Poopopyo #8 Posted July 15, 2009 This isn't a bad game, actually one of my all-time favorite NES games, Gyruss. That game had awesome music. Quote Share this post Link to post Share on other sites
Tempest #9 Posted July 15, 2009 This isn't a bad game, actually one of my all-time favorite NES games, Gyruss. That game had awesome music. Huh? Tempest 1 Quote Share this post Link to post Share on other sites
Tursi #10 Posted July 15, 2009 It's all nicely covered above. The door was meant for plug-in ROM carts. The Speech Synthesizer is actually just an LPC-10 decoder (most of them were, this is normal), and has ROMs inside with a hundred or so words pre-recorded. They planned to release ROM carts containing other words. A few of the early synths did get released with the cart port, at the Yahoo TI-99/4a group in the archives somewhere should be a pinout. To my knowledge no carts were ever released. In addition to the numerous games (almost all first party) which used speech, most (all?) of the MBX games also used speech, as well as Extended BASIC (which was limited to the built-in ROM vocabulary) and Terminal Emulator II (which added true text-to-speech to TI BASIC. A version of the TTS code was released in disk format for loading into Extended BASIC later). The speech chip used is mostly compatible with the 5220 used in many arcade games (Gauntlet, Star Wars), and most TI emulators actually use that core. The tool for compressing the speech, a Windows 3.1 tool, is called QBox and was found and released, again, check the Yahoo group for links (I forget which archive has it up ). It's non-trivial to use, but Mark Wills has a number of videos on YouTube demonstrating it (hey, a link this time: http://www.youtube.com/watch?v=wVDE-6TtmFQ) 1 Quote Share this post Link to post Share on other sites
Poopopyo #11 Posted July 18, 2009 This isn't a bad game, actually one of my all-time favorite NES games, Gyruss. That game had awesome music. Huh? Tempest Oops. Sorry I accidentally posted that in the wrong topic . Quote Share this post Link to post Share on other sites
Toucan #12 Posted July 18, 2009 Check here for a complete listing: http://www.videogamehouse.net/speech.txt Quote Share this post Link to post Share on other sites
Tempest #13 Posted July 18, 2009 Fathom has voice? Really? Interesting, I'll have to try that. Tempest Quote Share this post Link to post Share on other sites
oracle_jedi #14 Posted July 18, 2009 (edited) The door did nothing. It was planned for plug-in roms, probably like the Speak & Spell. But I see no sockets inside the door. The games: Parsec(duh) Star Trek Moon Mine Okay there has to be others. Microsurgeon "paging Dr. Lavine" MASH Edited July 18, 2009 by oracle_jedi Quote Share this post Link to post Share on other sites
Kurt_Woloch #15 Posted October 6, 2009 In addition to the numerous games (almost all first party) which used speech, most (all?) of the MBX games also used speech, as well as Extended BASIC (which was limited to the built-in ROM vocabulary) and Terminal Emulator II (which added true text-to-speech to TI BASIC. A version of the TTS code was released in disk format for loading into Extended BASIC later). Sorry, but you're wrong here. Extended Basic is NOT limited to the built-in ROM vocabulary. As far as I know, the "CALL SAY" command which makes the TI talk accepts numerous arguments, out of which the 1st, 3rd and so on are strings that are broken up into their respective words and said out of the built-in vocabulary. However, the 2nd, 4th... argument is expected in another format, the strings put in here are treated as raw speech data with a header that gives the number of bytes to put out. The manual of Extended Basic gives an example of how to use this to truncate certain words and then add suffixes. The only bad thing about this is that the format in which the data has to be given isn't documented (at least it wasn't back then), so although you theoretically would be able to feed custom data, you aren't able to generate it - which of course has changed in the meantime thanks to QBox. I remember doing some experimenting back then, but I couldn't figure out which bytes generate which sounds. And in fact, it's not as simple as that, since the "frames" of speech data actually are a variable number of bits long which is not dividable by 8 (there are different frame lengths) and thus can end at any bit position inside of a byte. By the way, you can also read out the speech information of words with the CALL SPGET command, which gives you the raw speech data. This is useful if you want the speech to be more fluent, since when feeding your data as a string, the speech noticeably pauses after each word for a split second, probably in order to decode and find the next word to say. If you retrieve the speech data for the words you want to say beforehand and chain them together in your program, in contrast, the words get said immediately after each other. That's at least what I did in an attempt to convert "Track & Field" to the TI. Quote Share this post Link to post Share on other sites
Shannon #16 Posted October 6, 2009 Do any emulators support this voice synthesizer? Quote Share this post Link to post Share on other sites
S1500 #17 Posted October 6, 2009 Do any emulators support this voice synthesizer? I think one or two did, but the speech sounded rather different than the original. Maybe MESS? Quote Share this post Link to post Share on other sites
Tursi #18 Posted October 6, 2009 Sorry, but you're wrong here. Extended Basic is NOT limited to the built-in ROM vocabulary. No need to be rude here. I am perfectly aware of the internals of the system, but it is fair to simplify for the sake of a summary. All things are always possible depending on the lengths you go to. As far as I know, the "CALL SAY" command which makes the TI talk accepts numerous arguments, out of which the 1st, 3rd and so on are strings that are broken up into their respective words and said out of the built-in vocabulary. However, the 2nd, 4th... argument is expected in another format, the strings put in here are treated as raw speech data with a header that gives the number of bytes to put out. The manual of Extended Basic gives an example of how to use this to truncate certain words and then add suffixes. You are correct here. Using CALL SPGET(), which returns the speech data for a string in the built-in vocabulary, you can get the raw LPC data, and CALL SAY can speak it. By manipulating these strings, you can cause additional effects, such as truncating words and adding suffixes. It is an inexact art but it can be done. This string can also be generated externally, although the only known example for XB is the "Bert and Ernie" demo. I went so far once as to try and extract all the alophones and string them back together for completely new words. It worked, but not overly well. It's not really "text-to-speech", more of a magic shuffle. (Though some might argue all text to speech is just a magic shuffle, and I wouldn't disagree ). By the way, you can also read out the speech information of words with the CALL SPGET command, which gives you the raw speech data. This is useful if you want the speech to be more fluent, since when feeding your data as a string, the speech noticeably pauses after each word for a split second, probably in order to decode and find the next word to say. If you retrieve the speech data for the words you want to say beforehand and chain them together in your program, in contrast, the words get said immediately after each other. That's at least what I did in an attempt to convert "Track & Field" to the TI. Nice! How far did you get on that? Quote Share this post Link to post Share on other sites
Tursi #19 Posted October 6, 2009 Do any emulators support this voice synthesizer? I think one or two did, but the speech sounded rather different than the original. Maybe MESS? MESS does pretty well. Win994A does as well. Classic99 has it but needs some timing fixes. It works for the games for the most part. MESS and Classic99 use the 5220 tables, so it's not a perfect reproduction. Win994A's author claims to have reversed the chip himself but won't release details or source so nobody knows for sure what he did. Quote Share this post Link to post Share on other sites
jaybird3rd #20 Posted October 6, 2009 (edited) This question has probably been answered elsewhere, but I've always wondered: is it possible to permanently install the speech synthesizer components internally? I have a 99/4A devoted entirely to gaming (which I think I bought from you years ago, Tursi; it's one of the later beige systems). The speech synthesizer is the only "sidecar" peripheral I use with it, and I'd like to mount it internally to reduce clutter. EDIT: Never mind, I found this article, which describes the process in detail. Edited October 6, 2009 by jaybird3rd Quote Share this post Link to post Share on other sites
Tempest #21 Posted October 6, 2009 This question has probably been answered elsewhere, but I've always wondered: is it possible to permanently install the speech synthesizer components internally? I have a 99/4A devoted entirely to gaming (which I think I bought from you years ago, Tursi; it's one of the later beige systems). The speech synthesizer is the only "sidecar" peripheral I use with it, and I'd like to mount it internally to reduce clutter. I know you could mount it on a card for the PEB, but I've never heard of an internal one. Tempest Quote Share this post Link to post Share on other sites
S1500 #22 Posted October 6, 2009 I remember an article in MicroPendium that made the speech synthesizer do bizarre noises. You could do like 100 variations of each word in the XB vocab. I remember doing trial and error trying to find cool sounds with different words. Quote Share this post Link to post Share on other sites
Kurt_Woloch #23 Posted October 9, 2009 No need to be rude here. Sorry, I didn't know this was considered to be rude, although I have to admit it wasn't particularly friendly. Nice! How far did you get on that? Well, it was one of the many things I did in XBasic as a child... and which I didn't finish. I think you see the track at the bottom, but nothing else. Then, out of timing reason, you don't see the athlete run. I started with the "Long Jump". In contrast to the arcade version, the perspective is fixed, so you don't see the athlete while he's gaining speed, but only the track at the bottom. After wiggling the joystick for a few seconds for speed, the athlete comes running in from the left, and then you have to hit the fire button for the correct duration like in the arcade, and then you see the athlete doing his jump. After he lands, the width gets announced. I can't remember how many other events I did for that... This was one of many simple projects which never got quite done. I also tried to do "Summer Games" and got a bit farther with that one... there I did the opening ceremonies, the main menu and the Pole Vault. Quote Share this post Link to post Share on other sites
TI-Sissy #24 Posted March 5, 2014 and now ti-scramble 1 Quote Share this post Link to post Share on other sites
Omega-TI #25 Posted March 5, 2014 and now ti-scramble I see you finally found your way out of the usual section... Quote Share this post Link to post Share on other sites
