BioKupo #1 Posted October 7, 2002 I've recently, as in yesterday, obtained an atari 520ST, and apart from it not having the language disk or mouse, it seemed to work. Problem being that I can't do anything within games! They will load up, but I can't do anything. In one game I could mute the sound and suicide. But I can't move or even start the actual game past the "press fire" instruction. Anyone know whats up? Quote Share this post Link to post Share on other sites
Inky #2 Posted October 7, 2002 Forget about a game for a minute. First, can you put a blank floppy in the drive and double click the drive A icon fine? Can you access all the drop-downs fine? Quote Share this post Link to post Share on other sites
BioKupo #3 Posted October 7, 2002 all the ones I should have access to I do. Obviously I can't access the "advanced" functions as I don't have the language disk. Apart from that I can open the floppy icons up, see whats on discs, access preferences. etc Quote Share this post Link to post Share on other sites
Inky #4 Posted October 7, 2002 What joystick are you using for the games, and what port do you have the mouse and joysticks plugged into? Quote Share this post Link to post Share on other sites
LinkoVitch #5 Posted October 7, 2002 The language disk is just some generic tools, like ST BASIC, you don't actually need it to use the computer. Quote Share this post Link to post Share on other sites
BioKupo #6 Posted October 7, 2002 I know that about the language disc not being important. I don't have a mouse and my joystick was plugged in port one. The joystick is a "Quickshot 2 turbo, model no:QS-111" Quote Share this post Link to post Share on other sites
LinkoVitch #7 Posted October 7, 2002 Plug the joystick into the rightmost port (I think it's port 2). the left most port is for the mouse and treats controllers in that as being a secondary controler. You can move the mouse in GEM desktop by holding down the ALT key and using the cursors, but turn down the volume unless you like a ringing sound Quote Share this post Link to post Share on other sites
BioKupo #8 Posted October 7, 2002 my typical luck. The joystick won;t go back ^_- but I can now play some games!! although plaing platformers is kinda hard thanks 4 ur help Quote Share this post Link to post Share on other sites
Gunstar #9 Posted October 7, 2002 Plug the joystick into the rightmost port (I think it's port 2). the left most port is for the mouse and treats controllers in that as being a secondary controler. You can move the mouse in GEM desktop by holding down the ALT key and using the cursors, but turn down the volume unless you like a ringing sound your right about the left/right with the mouse and joystick, but the ports are actually labeled 0 and 1, not 1 and 2. At least on my 1040st. Quote Share this post Link to post Share on other sites
BioKupo #10 Posted October 8, 2002 same on mine, ports 0 and 1. wish I had a joystick that works properly, I can't play Rambo III or gauntlet -_- Quote Share this post Link to post Share on other sites
