Tjohoo! #1 Posted July 31, 2009 Hello! Now I'm growing sicktired of trying to get the Channel F running the roms in the MESS emulator. I have done this before but I had to reinstall my computer so the old channel f directory is gone now so I had to do this from scratch again but I don't remember how to be doing... sl90025.rom sl31254.rom This file's missing! I have seen another topic at this forum and tried the links from there but no one works for me. The "Telecharger" site doesn't allow me to download the bios from there and there was no files left from rapidshare. Where can i found these bios now? I have the latest update of the MESS. /Nick Quote Share this post Link to post Share on other sites
Nukey Shay #2 Posted July 31, 2009 Planetemu? Works fine for me. Active scripting needs to be on. Zip below. BTW you could have "rolled yer own". sl90025.rom differs from sl31253.rom by only 3 bits... Byte offset $E0 (numbering from zero) is $74 in sl90025, $75 in sl31253.rom. Byte offset $145 is $7F in sl90025, $7C in sl31253.rom. All other bytes are identical. channelf.zip Quote Share this post Link to post Share on other sites
Tjohoo! #3 Posted July 31, 2009 Planetemu? Works fine for me. Active scripting needs to be on. Zip below. BTW you could have "rolled yer own". sl90025.rom differs from sl31253.rom by only 3 bits... Byte offset $E0 (numbering from zero) is $74 in sl90025, $75 in sl31253.rom. Byte offset $145 is $7F in sl90025, $7C in sl31253.rom. All other bytes are identical. Thanks thanks a lot Nukey Shay! Now, let's see. I have to unzip these files into the MESS bios folder right and then the channel f roms into the roms folder? Is there anything more I have to do? Thanks again! /Nick Quote Share this post Link to post Share on other sites
Robbbert #4 Posted August 10, 2009 Put the zipfile as is into the mess roms folder. The channel F games go into the software\channelf folder (which you will probably have to create) Quote Share this post Link to post Share on other sites
Tjohoo! #5 Posted August 19, 2009 Ok, that's why I couldn't found it! Thank you Robbbert! Quote Share this post Link to post Share on other sites
