ten-four #1 Posted August 7, 2009 Howdy Are there any Y adaptors out there ? I'm looking for a set of 4 DB9-Joystick Y cables, and shall be the following: 1 female & 2 male. They must be fully mounted. Quote Share this post Link to post Share on other sites
Murph74 #2 Posted August 8, 2009 (edited) Like these? http://www.amazon.com/DB9-Serial-Y-Cable-M...ref=pd_sim_hi_2 $3 https://www.atari2600.com/item--Joystick-Y-...--PROD1556.html $14.25 Edited August 8, 2009 by Murph74 Quote Share this post Link to post Share on other sites
ten-four #3 Posted August 8, 2009 Thank you Murph74... I will take a closer look... Quote Share this post Link to post Share on other sites
OldSchoolRetroGamer #4 Posted August 8, 2009 Excuse my ignorance, do those allow 1 controller to 2 ports Or 2 controllers to 1 port? THANKS. Quote Share this post Link to post Share on other sites
ten-four #5 Posted August 8, 2009 Hi OldSchoolRetroGamer... I'm looking for cables for 1 port and 2 Controllers. Quote Share this post Link to post Share on other sites
doubledown #6 Posted August 8, 2009 (edited) If you are looking for a y-cable to plug 2 controllers into 1 controller port, than you want 1 female end, and 2 male ends. The male/female description for the end refers to the pins/sockets and not the housing. So while for example, the end on the controller itself fits into the controller jack on the console, the thought would be that this is the male, but in fact it is a female, because the "male" pins are in the controller jack, and the "female" sockets are on the controller's cable. Presumably you are looking for this cable to connect a standard Atari or similar joystick, and a CV controller (for the use of the keypad), into one controller port. Also just at a glance the cable linked to above from Amazon won't work on a ColecoVision, if that what this is for, due to the overall size of the female connector's housing. The one linked to from Atari2600.com would be what you want for 2 controllers plugged into 1 port as long as all of the pins connected. If you were looking to plug 1 controller into 2 ports, (sharing 1 controller for both players not playing simuletaneously), then you would want a "reverse y-cable". Edited August 8, 2009 by doubledown Quote Share this post Link to post Share on other sites
