Sign in to follow this
atari_aaron
Can anyone tell me what I'm doing wrong
I'm currently trying to work my way through "Nick Bensema's playfield primer" for the 2600... but when I try to run my assembled code through Stella all I get is a blank screen.
One problem I see... and I'm not sure if it's a typo in the primer:
Primer Reads - cut and past from HTML document:
; Clear all registers here to prevent any possible bleeding.
LDA #2
STA WSYNC ;Finish this scanline.
STA VBLANK ; Make TIA output invisible,
; Now we need to worry about it bleeding when we turn
; the TIA output back on.
; Y is still zero.
STY PF0
STY PF1
STY PF1 <---Notice repeated line - I wrote "STY PF2" instead
STY GRP0
STY GRP1
STY ENAM0
STY ENAM1
STY ENABL
RTS
Should I have left it as "STY PF1"?
The bin file I assembled, the code as I copied it into a txt file, and the vcs.h file I am using can all be found at the following URL:
[url="http://testserv.archaeology.ndsu.nodak.edu/~abergstr/atari/"]http://testserv.archaeology.ndsu.nodak.edu...gstr/atari/[/url]
I don't understand it... the thing assembles using dasm, but all I get is a black screen when I run the bin in stella. I realize the problem is my fault, but I can't seem to find my mistake.
Any help would be appreciated.
Thanks,
Aaron
Are you using the -f3 option for DASM? You should assemble your code using <filename> -f3 -o<filename>.bin
No that's an old typo. STY PF2 is correct.
Well... I got it to work... I tried 5 things at once... and one of them worked anyway... Can't say that the result was very pleasing to the eye. I think I wasn't turning on the VBlank... I think I was trying to turn on "VSYNC" oops... Anyway, something good came out of it... I think I finally understand the basic graphics concepts behind the TIA.
In an odd sort of way, I like how it works... 60fps... no if's, and's, or but's... I'm use to the java3d way of doing things... that is "oops, 0.4 fps... I guess I have too many polygons".
I actually have gotten my own playfield to draw... but it's increadibly crappy... besides just repeating itself with no regard to stopping or starting at the top or bottom of the screen... it's doing this annoying flicker thing.
I guess I need some scanline discipline... I've got time to work on it... I'm going to India tomorrow morning for two weeks... nothing like being in the air on and off for 24hrs (both ways) to help you think about things... nothing else to do really. At least I'll have a laptop... might comeback with something to show... wouldn't that be nice.
Thanks for the suggestions everyone,
Aaron
There is no way to program the 2600 without the stella programmers guide... GET IT! :-)
When I decided the only way to get my program to work the way I wanted was an ASymetrical Reflected playfield I for the life of me could not get it going... It's a super tight kernel but the Stella Programmers guide got me through it ;-)
Thanks for the compliment... I'll keep everyone posted on the programming environment. Now it's back to work and school related stuff... probably until after Christmas. Though I'll probably do some more work on CAG befor then. I've got more research to do on scrolling playfields before I do more work on EB KC-135.
Aaron
