Sign in to follow this
amiman99
Atari sf354 Drive question
Hi,
Can I format ds/dd disks in that drive? SF354
I know that the drive is ss/dd, but I'm having some problems formating ds/dd disks as ss/dd.
Do I need to cover some hole? or the disks are the same?
Does anyone has some pictures of ss/dd disks, front and back?
The drive is recognizing that is write protected
Thank you
Hi,
Thank you
Yes you should be able to use DSDD disks as SSDD and format to 360k.
I took the drive a part, and is not spinning. Looks like a newer model, because it uses 34 pin ribbon. I have couple old drives with disk select option, I will try to replace it and see what it does.
I replaced the drive with Epson SMD-320, and I can format and access the disks now as a SS/DD. The SMD-320 is a Flexible Drive capable HD/DD drive, but I can't format DS/DD 720k on the atari 520STm. Is it the limitation of the SF354 PCB or there is something else I can do to make it DS/DD? Did some one attempted to do that?
